POV-Ray : Newsgroups : povray.unix : problems with python-script Server Time
22 Apr 2025 03:51:24 EDT (-0400)
  problems with python-script (Message 1 to 3 of 3)
Subject: problems with python-script
Date: 28 Aug 2002 01:42:53
Message: <3d6c62dc@news.povray.org>
I was recommended a python-script (
http://www.janw.gothere.uk.com/Download/Python/povexport.py ) to export the
objects to povray
( http://www.janw.gothere.uk.com/ )
But unfortunately always an error is displayed in the bash when I start the
script (P+ALT) in the blender-text-editor:
PYTHON SCRIPT ERROR:
Traceback (most recent call last):
  File "povexport.py", line 364, in ?
AttributeError: getCurrentScene
I think I have followed the instructions on the web-page correctly. (See
Usage && Install/Unix)
Has anyone an idea what the problem could be?
I entered the following lines in the blender-text-editor: (See Jan
Walter`Blender page - Installation-Unix)
import sys
print sys.path
Output in the bash:
['/usr/lib/python2.0/', '/usr/local/lib/python2.0/',
'/home/strubi/develop/lib/linux-glibc2.1.3-i386/python/lib/python2.0/
plat-linux2',
lib-tk',
'/home/strubi/develop/lib/linux-glibc2.1.3-i386/python/lib/lib-dynload',
'/home/ganymed/blender-creator-2.23-linux-glibc2.1.2-i386-static/.', '']
(Why strubi? There is no user strubi on my system! Is this the cause for
the problem? How can I change that?)
Besides:
>python
>>>import sys
>>>print sys.path
Output in the bash:
['', '/usr/local/Python-2.0', '/usr/local/lib/python2.0',
'/usr/local/Python-2.0/moreDirectories', '/usr/lib/python2.2',
'/usr/lib/python2.2/plat-linux-i386', '/usr/lib/python2.2/lib-tk',
'/usr/lib/python2.2/lib-dynload', '/usr/lib/python2.2/site-packages']
thanks for your responses!
Ps.: I use blender-creator-2.23-linux-glibc2.1.2-i386-static //
Mandrake 8.2
Subject: Re: problems with python-script
Date: 28 Aug 2002 23:27:09
Message: <3D6D94D9.9040602@netscape.net>
> objects to povray
It's been a while since I've messed around with this script and Blender. I
had it working back then but have since gotten a newer verion of Blender
(2.22)
and a newer version of Python (2.2). So I tried out the script tonight
and did
run into a problem, just not exactly the same as yours. However, the
workaround I did may also solve your problem.
> Output in the bash:
> plat-linux2',
> lib-tk',
I also had the strubi message. I suspect some hard coding in the
Blender program. It seems to expect to find python modules in
/usr/lib/python2.0 (and other amazing paths ;) and isn't trying to
look in /usr/lib/python2.2 which is where I needed it to look. I'm sure
there's more elegant solutions but I went brute force and moved the
/usr/lib/python2.0 one to a save directory then made a symlink for
python2.0 to point to python2.2 like this:
ln -s /usr/lib/python2.2 /usr/lib/python2.0
I then followed the same instructions you did, exported the chevy.blend
sample file, rendered it in POV and voila!
Hope this works for you too!
-Roz
Date: 29 Aug 2002 02:28:32
Message: <3d6dbf0f@news.povray.org>
>> the objects to povray
>> the script (P+ALT) in the blender-text-editor:
> (2.22)
> and did
>> Output in the bash:
>> plat-linux2',
>> lib-tk',
> -Roz
