Coming in on the heels of everyone else's compiling woes and optimized
builds, I just got around to doing my own, and thought I'd post my results.
I don't have the official linux build or the windows build installed to do
comparisons with, but I did a default build and an optimized build, and
have results for each on my system:
povray.unopt +a0.3 +w320 +h240 +v +D +ibenchmark.pov
Time For Parse: 0 hours 0 minutes 6.0 seconds (6 seconds)
Time For Photon: 0 hours 3 minutes 2.0 seconds (182 seconds)
Time For Trace: 1 hours 4 minutes 41.0 seconds (3881 seconds)
Total Time: 1 hours 7 minutes 49.0 seconds (4069 seconds)
povray +a0.3 +w320 +h240 +v +D +ibenchmark.pov
Time For Parse: 0 hours 0 minutes 4.0 seconds (4 seconds)
Time For Photon: 0 hours 1 minutes 30.0 seconds (90 seconds)
Time For Trace: 0 hours 34 minutes 54.0 seconds (2094 seconds)
Total Time: 0 hours 36 minutes 28.0 seconds (2188 seconds)
Quite a significant improvement! OK, so this sucks compared to you Athlon
XP 1900 people, but I'm quite happy with it on my Athlon tbird 1.1 GHz.
Some notes on the build:
- Hadn't read the thread on the min/max problem, so I ended up changing all
calls to min/max to fmin/fmax, and calls to min3/max3 to
fmin(fmin(),)/fmax(fmax(),).
- Configured as follows based on random suggestions scattered across usenet:
CXX='/usr/local/gcc-3.1.1/bin/g++ -O3 -march=athlon-tbird
-mcpu=athlon-tbird -fomit-frame-pointer -falign-functions=6 -funroll-loops
-ffast-math -malign-double -m3dnow -mmmx' LDFLAGS='-static' ./configure
Note that I linked this as a static binary so if anyone else wants to give
it a try, I can put it up for download - just let me know.
Ken
Oh, for reference:
$ cat /proc/cpuinfo
processor : 0
vendor_id : AuthenticAMD
cpu family : 6
model : 4
model name : AMD Athlon(tm) Processor
stepping : 2
cpu MHz : 1109.921
cache size : 256 KB
fdiv_bug : no
hlt_bug : no
f00f_bug : no
coma_bug : no
fpu : yes
fpu_exception : yes
cpuid level : 1
wp : yes
flags : fpu vme de pse tsc msr pae mce cx8 sep mtrr pge mca cmov
pat pse36 mmx fxsr syscall mmxext 3dnowext 3dnow
bogomips : 2215.11
$ cat /proc/meminfo
total: used: free: shared: buffers: cached:
Mem: 261648384 247451648 14196736 1597440 33746944 153714688
Swap: 388575232 92811264 295763968
MemTotal: 255516 kB
MemFree: 13864 kB
MemShared: 1560 kB
Buffers: 32956 kB
Cached: 132836 kB
SwapCached: 17276 kB
Active: 110336 kB
Inact_dirty: 70904 kB
Inact_clean: 3388 kB
Inact_target: 4 kB
HighTotal: 0 kB
HighFree: 0 kB
LowTotal: 255516 kB
LowFree: 13864 kB
SwapTotal: 379468 kB
SwapFree: 288832 kB
NrSwapPages: 72208 pages
Your flags do not mention SSE instructions. My Duron does not either.
I sometimes get an error with Micha'compile (which includes SSE
instructions).
I'd like to get my hand on your version to give it a try.
Thanks
Fabien HENON
> Ken
> Oh, for reference:
> $ cat /proc/cpuinfo
> processor : 0
> cpu family : 6
> model : 4
> stepping : 2
> cpu MHz : 1109.921
> cache size : 256 KB
> fdiv_bug : no
> hlt_bug : no
> f00f_bug : no
> coma_bug : no
> fpu : yes
> fpu_exception : yes
> cpuid level : 1
> wp : yes
> bogomips : 2215.11
> $ cat /proc/meminfo
> MemTotal: 255516 kB
> MemFree: 13864 kB
> MemShared: 1560 kB
> Buffers: 32956 kB
> Cached: 132836 kB
> Active: 110336 kB
> Inact_target: 4 kB
> HighTotal: 0 kB
> HighFree: 0 kB
> LowTotal: 255516 kB
> LowFree: 13864 kB
> SwapFree: 288832 kB
From what I understand, SSE support was not added to the Athlons until the
MP and XP variants. I'm pretty sure it's not available in the Thunderbird.
I've posted my build at http://home.attbi.com/~cecka2/pov35 . Let me know
how it works for you.
Ken
> instructions).
> Thanks
> Fabien HENON
>> results. I don't have the official linux build or the windows build
>> installed to do comparisons with, but I did a default build and an
>> optimized build, and have results for each on my system:
>> Athlon XP 1900 people, but I'm quite happy with it on my Athlon tbird 1.1
>> GHz. Some notes on the build:
>> all calls to min/max to fmin/fmax, and calls to min3/max3 to
>> usenet: CXX='/usr/local/gcc-3.1.1/bin/g++ -O3 -march=athlon-tbird
>> -funroll-loops -ffast-math -malign-double -m3dnow -mmmx'
>> give it a try, I can put it up for download - just let me know.
>> Ken
>> Oh, for reference:
>> $ cat /proc/cpuinfo
>> processor : 0
>> cpu family : 6
>> model : 4
>> stepping : 2
>> cpu MHz : 1109.921
>> cache size : 256 KB
>> fdiv_bug : no
>> hlt_bug : no
>> f00f_bug : no
>> coma_bug : no
>> fpu : yes
>> fpu_exception : yes
>> cpuid level : 1
>> wp : yes
>> cmov pat pse36 mmx fxsr syscall mmxext 3dnowext 3dnow
>> bogomips : 2215.11
>> $ cat /proc/meminfo
>> MemTotal: 255516 kB
>> MemFree: 13864 kB
>> MemShared: 1560 kB
>> Buffers: 32956 kB
>> Cached: 132836 kB
>> Active: 110336 kB
>> Inact_target: 4 kB
>> HighTotal: 0 kB
>> HighFree: 0 kB
>> LowTotal: 255516 kB
>> LowFree: 13864 kB
>> SwapFree: 288832 kB
Hi Ken.
I ran the Athlon version on my machine and got the following error:
Parsing...Scene File Parser Initialization Error: I/O restriction prohibits read
access to file 'benchmark.pov'.
Refer to the platform specific documentation for details.
The only thing I changed was the executable. The original 3.5 version gave:
Time For Photon: 0 hours 2 minutes 46.0 seconds (166 seconds)
Time For Trace: 1 hours 7 minutes 18.0 seconds (4038 seconds)
Total Time: 1 hours 10 minutes 10.0 seconds (4210 seconds)
quite similar to your run.
Ideas?
John
This has come up in a couple of threads already - it is a new feature in pov
3.5 with rather confusing defaults. Basically, (as I understand it), Pov
3.5 prevents you from accessing any files outside the directory where you
perform the render from (or something like that), unless you explicitely
allow otherwise in your povray.conf. Here's what I put in my
/usr/local/etc/povray.conf:
[File I/O Security]
none
[Shellout Security]
allowed
And in my ~/.povrayrc:
Library_Path=/usr/local/share/povray-3.5/include
Not quite sure why it worked for you with the official version and not with
mine (maybe they've changed the defaults in the official binary?).
Ken
> Hi Ken.
> prohibits read access to file 'benchmark.pov'. Refer to the platform
> gave:
> Ideas?
> John
It works fine. The only problem I had is the one you mentionned.
Thanks for the speed it brought.
Fabien HENON
That was it, Ken, Thanks!
Results:
Time For Photon: 0 hours 1 minutes 24.0 seconds (84 seconds)
Time For Trace: 0 hours 33 minutes 12.0 seconds (1992 seconds)
Total Time: 0 hours 34 minutes 40.0 seconds (2080 seconds)
Just under 50% of the unoptimized version... Amazing!
Ken Cecka <cec### [at] alumni washington edu> wrote:
> [File I/O Security]
> none
> [Shellout Security]
> allowed
This is mentioned over and over... But no-one has mentioned which *other*
options you have which you can put there. Perhaps not everyone wants to
allow everything.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
Certainly - it just didn't particularly matter to me, and I haven't taken
the time to research it yet. It did occur to me when I read your other
post on this subject that making everything read-only but not writable
might be a more sensible default since it's not like PovRay is running as a
server or in any way revealing data to others. And this would still
protect against malicious scripts which try to trample data. Anyway, just
my 2 cents.
Ken
>> [File I/O Security]
>> none
>> [Shellout Security]
>> allowed
> *other*
> allow everything.
