POV-Ray : Newsgroups : povray.unix : Pentium 3 optimized binary Server Time
22 Apr 2025 07:50:33 EDT (-0400)
  Pentium 3 optimized binary (Message 1 to 10 of 28)
Subject: Pentium 3 optimized binary
Date: 1 Aug 2002 12:46:39
Message: <3d4965ef@news.povray.org>
I have compiled a version of pov-ray with gcc 3.1, optimized for pentium 3
cpus. I have also applied a small patch which potentially increases
performance. If you want to try it out, you can get it from
http://www.povworld.org/povray/povray.bz2
I have not had time to do too much testing but it should be quite a bit
faster than the official binary. Please someone test against windows binary.
- Micha
http://objects.povworld.org - the POV-Ray Objects Collection
Subject: Re: Pentium 3 optimized binary
Date: 1 Aug 2002 13:59:05
Message: <3D497728.6030603@netscape.net>
> - Micha
Bless you Micha! This worked like a charm. Comparison rendering times of
the balcony.pov sample scene are as follows:
Windows prebuilt binary = 505s
Linux prebuilt binary = 785s
Micha's p3 optimized binary = 444s
I'll do some more thorough testing with other scenes such as the
benchmark.pov one later today.
I don't have gcc 3.1 yet. Would the small patch you applied help
performance in a gcc 2.96 compiled version?
-Roz
Date: 1 Aug 2002 14:44:41
Message: <3d498198@news.povray.org>
Great! What CPU do you have btw?
Yeah, it is an algorithmic change and therefore compile independant. I'll
post details later. It's is national holiday here in Switzerland today...
- Micha
Date: 1 Aug 2002 15:41:36
Message: <3d498ef0@news.povray.org>
Wow! That's great, Micha!
light_source{0#macro L(K,H,W)sphere{H.5}sphere{K.5}sphere{W.5}cylinder{
H,K.5}cylinder{H,W.5}#end 3}union{L(0v*-2<2,-2>)L(y*-3z-v*5z*3-y)L(-y*3
0u*3)L(y*-3v*-5-z,z*-3-y)rotate-v*clock pigment{rgb.5}translate<0,2,9>}
// +KFF200 +KF720 +W120 +H90 -F -A -GA -P
Date: 1 Aug 2002 18:15:08
Message: <3D49B220.7E6851EF@caramail.com>
Thanks for it
File : orient.pov
parameters : +w800 +h600 -f +a +dgt +v
Linux Mandrake 8.2 Kernel 2.4.18
Windows 2000 Pro
It is also optimized for my Duron !
AMD Duron 700 Mhz 512 Mo Memory
Official binary :        262 seconds
Optimized version :      121 seconds
Windows version :        121 seconds
But the optimised version does not work with soft.pov
I get an error
Fabien HENON
> - Micha
Date: 1 Aug 2002 18:34:49
Message: <3D49B6BF.7040508@caramail.com>
> Thanks for it
> File : orient.pov
> Windows 2000 Pro
> I get an error
> Fabien HENON
>>- Micha
Date: 1 Aug 2002 18:36:47
Message: <pan.2002.08.01.22.40.44.486740.1550@povray.org>
I'll look into adding easier support for various optimizations to the
build, as well as multiple binaries with different optimizations.
Building from source will probably remain the best way to get better
performance.  For something like POV-Ray (CPU-intensive, fairly low build
time), that's probably reasonable.
-Mark Gordon
> 3 cpus. I have also applied a small patch which potentially increases
> binary.
> - Micha
Date: 1 Aug 2002 18:36:54
Message: <3d49b806@news.povray.org>
> Thanks for it
> File : orient.pov
> Windows 2000 Pro
Nice to hear.
> I get an error
Works fine here with soft.pov. This is probably because amd duron does not
support 'SSE' instruction what pentium 3 does. (Athlon XP does it). I can
try to make a version for amd duron as well - though if I don't have such a
processor I cannot test it..
- Micha
Date: 1 Aug 2002 19:04:06
Message: <3D49BEA4.5030700@netscape.net>
It's an AMD Athlon XP 1900+ with 512meg DDR RAM.
I ran benchmark.pov through its paces and these are the rendering times:
Windows prebuilt binary = 25m 48s (1548s)
Linux prebuilt binary = 55m 40s (3340s)
Micha's p3 optimized binary = 25m 14s (1514s)
Not bad :)
> - Micha
Happy Holiday and thanks for posting the p3 optimized binary :)
-Roz
Date: 1 Aug 2002 19:15:56
Message: <pan.2002.08.01.23.19.53.321103.1550@povray.org>
Hmm... I found a gcc 3.2 in rawhide.  Maybe I should give that a whirl...
-Mark Gordon
