anyone knows where i can get pov mode for emacs outside of
www.acc.umu.se/~woormie/povray/
please reply
%segmentation fault
> please reply
It downloads fine from there. What problems are you having?
#local i=.1;#local I=(i/i)/i;#local l=(i+i)/i;#local ll=(I/i)/l;box{<-ll,
-((I/I)+l),-ll><ll,-l,ll>pigment{checker scale l}finish{ambient((I/l)/I)+
(l/I)}}sphere{<i-i,l-l,(I/l)>l/l pigment{rgb((I/l)/I)}finish{reflection((
I/l)/I)-(l/I)specular(I/l)/I}}light_source{<I-l,I+I,(I-l)/l>l/l} // Steve
>> please reply
I cannot access the server due to 403
%segmentation fault
pov-mode.el:
http://users.zeropps.btopenworld.com/bits/pov-mode.el
and my .emacs file that workis in Linux and windows, but you'll have
to rename it:
http://users.zeropps.btopenworld.com/bits/winemacs
> pov-mode.el:
Oops that should be:
http://zeropps.users.btopenworld.com/bits/pov-mode.el
> to rename it:
http://zeropps.users.btopenworld.com/bits/winemacs
>> pov-mode.el:
>> to rename it:
thanks man
%segmentation fault
By the way, it's a good practice to remove unnecessary parts from quotes
in order to shorten the article and make it more readable.
(At least you didn't answer at the beginning of the article, which is a
mistake most people do.)
<posted & mailed>
While wandering in povray.unix, cinder was heard to expound:
> please reply
And perhaps more importantly, when will it be updated for 3.5 (assuming it
hasn't already)
