POV-Ray : Newsgroups : povray.unix : emacs povmode Server Time
11 Jun 2026 00:19:18 EDT (-0400)
  emacs povmode (Message 1 to 8 of 8)
Subject: emacs povmode
Date: 7 Mar 2002 18:19:16
Message: <3c87f574@news.povray.org>
anyone knows where i can get pov mode for emacs outside of
www.acc.umu.se/~woormie/povray/
please reply
%segmentation fault
Subject: Re: emacs povmode
Date: 7 Mar 2002 20:02:40
Message: <slrna8g32j.bk6.steve@zero-pps.localdomain>
> please reply
It downloads fine from there.  What problems are you having?
#local i=.1;#local I=(i/i)/i;#local l=(i+i)/i;#local ll=(I/i)/l;box{<-ll,
-((I/I)+l),-ll><ll,-l,ll>pigment{checker scale l}finish{ambient((I/l)/I)+
(l/I)}}sphere{<i-i,l-l,(I/l)>l/l pigment{rgb((I/l)/I)}finish{reflection((
I/l)/I)-(l/I)specular(I/l)/I}}light_source{<I-l,I+I,(I-l)/l>l/l} // Steve
Date: 7 Mar 2002 20:40:01
Message: <3c881671@news.povray.org>
>> please reply
 I cannot access the server due to 403
%segmentation fault
Date: 7 Mar 2002 20:51:12
Message: <slrna8g681.c6f.steve@zero-pps.localdomain>
pov-mode.el:
http://users.zeropps.btopenworld.com/bits/pov-mode.el
and my .emacs file that workis in Linux and windows, but you'll have
to rename it:
http://users.zeropps.btopenworld.com/bits/winemacs
Date: 7 Mar 2002 20:55:00
Message: <slrna8g6fe.c86.steve@zero-pps.localdomain>
> pov-mode.el:
Oops that should be:
http://zeropps.users.btopenworld.com/bits/pov-mode.el
> to rename it:
http://zeropps.users.btopenworld.com/bits/winemacs
Date: 7 Mar 2002 21:07:07
Message: <3c881cca@news.povray.org>
>> pov-mode.el:
>> to rename it:
thanks man
%segmentation fault
Date: 8 Mar 2002 09:21:03
Message: <3c88c8ce@news.povray.org>
By the way, it's a good practice to remove unnecessary parts from quotes
in order to shorten the article and make it more readable.
  (At least you didn't answer at the beginning of the article, which is a
mistake most people do.)
Date: 14 Mar 2002 12:57:40
Message: <3c90e493@news.povray.org>
<posted & mailed>
While wandering in povray.unix, cinder was heard to expound:
> please reply
And perhaps more importantly, when will it be updated for 3.5 (assuming it
hasn't already)
