POV-Ray : Newsgroups : povray.unix : icc anyone? Server Time
11 Jun 2026 00:19:32 EDT (-0400)
  icc anyone? (Message 1 to 4 of 4)
Subject: icc anyone?
Date: 29 Jan 2002 10:45:00
Message: <3c56c37c@news.povray.org>
Hello!
Has anyone tried the intel compiler for Linuxfor compiling Povray?
(http://www.intel.com/software/products/eval/)
If so, I would be interested to see the parameters. According to
 http://www.open-mag.com/754088105111.htm
and
 http://www.heise.de/newsticker/data/hes-11.11.01-000/ (german)
it produces much faster code. Unfortunately, I wasn't able to reproduce
this!
The rendering times I got are:
gcc 2.95.3: 4min 48s
gcc 3.0.1:  3min 41s
icc:        4min 41s
The compiler options were:
gcc 2.95.3:
-O3 -Wall -finline-functions -ffast-math -c -ansi -march=i686 -DCPU=686
gcc 3.0.1:
-O3 -Wall -finline-functions -ffast-math -foptimize-sibling-calls -c -ansi
icc:
-O3 -c -ip -tpp6 -rcd -axK -xK -ansi
I've used a patched version of MegaPov 0.4 with the scene furrytorus.mpg
at http://www.grafik.willhalm.de, but this shouldn't matter.
Any ideas?
Subject: Re: icc anyone?
Date: 29 Jan 2002 16:08:37
Message: <3c570f55@news.povray.org>
In article <3c56c37c@news.povray.org> , Thomas Willhalm
> and
> this!
> icc:
iX, issue 11/2001 on page 70 lists these three:
icc -O2
icc -O2 -xW
icc -O2 -tpp7
icc -O2 -xW -ipo
Unfortunately, i don't know anything about the Intel compiler or its options
as I never used it myself, but these parameters are a good hint I think.
BTW, the iX article is much more informative and technical than a similar
article in c't at about the same time, which is very interesting as apparently
they wrote those article independently.  This is strange as iX and c't are
still in the same office and have the same publisher...
    Thorsten
e-mail: tho### [at] trfde
Date: 30 Jan 2002 10:13:37
Message: <3c580da0@news.povray.org>
>> and
>> this!
>> icc:
Thanks for the hint. I've now read this article, too. Even with this
knowledge, gcc 3.0 produces faster code than icc. The reason might be
that I use only a Pentium III and the big improvement holds only for
Pentium 4. Another reason might be the rather special scene that contains
mainly a slow media container.
So far, I have tested some combinations of options that make sense. I will
try different scenes and maybe a different processor later.
Thanks again
Date: 30 Jan 2002 14:00:57
Message: <3c5842e9@news.povray.org>
In article <3c580da0@news.povray.org> , Thomas Willhalm
It is probabbly the media container.  Overall, that is with more than just a
few different objects the Intel compiler will be much faster.  It might also
be that some particular (math) library you are linking against is no as well
suited unless it is compiled with icc as well.
You may also want to try to contact the authors, maybe they know something we
don't about the configuation...  BTW, did you make sure you are using the same
version they tested?
    Thorsten
