What tool would you use to assemble a series of stills into an mpg movie
under Linux ?
> under Linux ?
There will be probably some answers about concrete solutions but meantime look
at http://www.visiblelight.com/mpeg/software/linux.htp
ABX
disc{z,-z 5#macro O()asc(substr("-+((1*(,1,/.-,*/(,&.323/'1"e,1))*.1-4#declare
e=e-1;#end#local e=26;pigment{#local g=function(_){ceil(_)-_}function#local//X
k=function{pattern{object{sphere_sweep{linear_spline 13#while(e>0)<O(),O()//AB
>.01#end}}}}{k(g(atan2(x,y)),g(ln((y+x)^2+1e-5)),0)}}finish{ambient 1}}//POV35
> under Linux ?
I would probably use the toolkit at http://mjpeg.sourceforge.net/ but only
because it's what I've been using.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
I'am using mpeg2encode, try
http://www.gadegast.de/frank/mpegfaq/mpe7908.html
> under Linux ?
I'm using mpeg2encode, though I use GIMP to create the .par file, and it
also creates a script which you can use to generate the animation
> under Linux ?
David
smuchrusher <at> ameritech <dot> net
ICQ#: 118347772
10:41pm up 2 days, 19:24, 0 users, load average: 0.59, 0.18, 0.05
>>under Linux ?
Gimp creates .par files? HOW?
I've used mepg2encode and mpeg2decode, but how the heck do you create par
files with Gimp ??
Imran
> > under Linux ?
> David
> ICQ#: 118347772
>>>under Linux ?
All you have to do is open one of the franes, preferably the first one,
right click on it, and select video/encode/mpeg[1,2]. This brings up a
dialog which lets you modify the options, and then generates a .par-mpg
file, and a script that runs mpeg_encode or mpeg2encode depending on what
you are generating. I did notice, though, that it assumes that you have 4
numeric characters at the end of the file, though this is easily fixed by
editing the .par file.
David
ICQ#: 118347772
6:05pm up 1 day, 14:48, 0 users, load average: 0.33, 0.25, 0.16
Oh, I use v 1.2.1
David
ICQ#: 118347772
>>>>under Linux ?
ah thanks!
