POV-Ray : Newsgroups : povray.unix : POV-ray problems under Linux Server Time
22 Apr 2025 15:23:17 EDT (-0400)
  POV-ray problems under Linux (Message 1 to 10 of 10)
Subject: POV-ray problems under Linux
Date: 6 Sep 2001 14:40:26
Message: <3b97c31a@news.povray.org>
I have previously used POV unders Windows and got on quite well with it.
I am new to Linux and thought having POV on it would encourage me
to use it. I installed the system following the instructions provided.
I created very simple scene (copied from 'Ray Tracing Creations') and
ran this command line:
  x-povray +W120 +H90 +Ifirst.pov +Ofirst.tga +V (also from the book)
Everything appeared to work but the resulting TGA could not be opened
with any image viewers under Linux or Windows. The same appears to be
true of PNG and JPG. I didn't try anything else.
Also, is x-povray supposed to give me a nice image to look at while its
working? Perhaps my test was too small/quick for this.
Thanks for any help.
Arnold the Aardvark
Subject: Re: POV-ray problems under Linux
Date: 6 Sep 2001 15:33:39
Message: <3b97cf93@news.povray.org>
This looks fine so far...
... but my guess is that POV-Ray actually did not save the image in TGA
format. If you do not especially specify the file format with the command
line or an .ini file POV-Ray takes the 'system default'... and this is PPM
with unix OS. You can set the output file format using the swith +F... e.g.
+FT or +FC for getting un/compressed targa. See the docs about this. Also
note that the -o switch just specifies the name and has nothing to do with
the file format; actually you better leave it away, then POV automatically
sets the appropriate file format extension.
Yes, it is. Maybe you need to set the '+D' switch. It's best to make a
default .ini file with the basic settings, e.g. I have a file 'pov31.ini'
which contains:
Display_Gamma = 2.4
Library_Path=/home/micha/povsources/include/
Output_File_Name= /home/micha/povpics/
-w320
-h240
+D
+FC
and then use on the command line:
x-povray pov31.ini -i myscenefile.pov
Hope this helps.
- Micha
Date: 6 Sep 2001 16:39:30
Message: <3B97DEFD.132F0D9A@geocities.com>
> which contains:
> Display_Gamma = 2.4
> -w320
> -h240
> +D
> +FC
I often like to add these when I'm working on a scene:
 +SP128 +EP8
That gives a nice mosaic at the begining.
Wind the Frog!
Date: 6 Sep 2001 16:53:27
Message: <3b97e247@news.povray.org>
Arnold the Aardvark <aar### [at] notthistubulidentatademoncouk> wrote:
:   x-povray +W120 +H90 +Ifirst.pov +Ofirst.tga +V (also from the book)
  Instead of having to write all this, you could write this to your
$HOME/.povrayrc file:
+fn +d +v +mb3
  Then you can render the image with just:
x-povray -i first -w120 -h90
  It will create a PNG with the same name as the pov file (ie. "first.png").
Date: 6 Sep 2001 17:52:00
Message: <3b97f000@news.povray.org>
> Arnold the Aardvark
any relation to C64 character of similar name?
PGP Public Key
Subject: Re: POV-ray problems under Linux [OT]
Date: 7 Sep 2001 07:57:25
Message: <3b98b625@news.povray.org>
If so then only indirectly because that's where someone else got it from.
I heard the name at college and it amused me - a weird animal and
comical alliteration all at once. I always use it in newsgroups because
I am a little sad.
Arnold the Aardvark a.k.a. Alan Chambers
Date: 7 Sep 2001 08:04:06
Message: <3b98b7b6@news.povray.org>
Thanks. I think you hit the nail on the head. I'll see when I get home.
Arnold the Aardvark
Date: 9 Sep 2001 17:13:25
Message: <iomnptc8jej2mdo5b9pmkjj7m6p700p8d7@4ax.com>
On Fri, 7 Sep 2001 12:59:48 +0100, "Arnold the Aardvark"
The first real (i.e. not "a") word in any respectable dictionary, too
Peter Popov ICQ : 15002700
Date: 12 Sep 2001 12:45:38
Message: <3B9F9108.5010900@reconfig.net>
The +O option to x-povray tells it to send its standard output to the
named file.  The standard output is the messages that scroll when
x-povray runs.  To send the image output to first.tga, use +ofirst.tga.
Read the manual page for more information (man x-povray or man povray).
I don't have x-povray on my system, but if it is supposed to display an
image window by default, make sure that you are running x-povray from an
X Window System display (not in a virtual terminal) and that you are
running the x-povray process as the same user who is logged in to the X
display.  Again, see the manual page for information on command line
options that may affect displaying.
Jeff Bonham
Date: 13 Sep 2001 04:59:32
Message: <3ba07574@news.povray.org>
Jeff Bonham <sil### [at] reconfignet> wrote:
: The +O option to x-povray tells it to send its standard output to the
: named file.  The standard output is the messages that scroll when
: x-povray runs.  To send the image output to first.tga, use +ofirst.tga.
  Why use the +O option at all? If anything, you will just shoot yourself
in the foot if you happen to specify a different file type name than what
povray is actually generating (eg. if povray generates a png image and you
save it as "first.tga", you'll end up having a png image named as a tga
image, and most programs will not work with that).
  Let povray save with the default name (which is the same name is the
.pov file but changing ".pov" with the proper image type).
: I don't have x-povray on my system, but if it is supposed to display an
: image window by default
  POV-Ray doesn't show the image by default. You have to enable it with +d
(eg. in $HOME/.povrayrc).
