Subject: Benchmark tests for different UltraSPARC compiles of POV-Ray
Date: 15 Jun 2001 09:26:20
Message: <3b2a0cfc@news.povray.org>
I compiled povray for (Solaris) UltraSPARC with different architecture
options and tested its speed with four povray files. The files I used were:
- Parsing benchmark: A very complicated SDL which takes very long to parse
and just a few seconds to render. Requires some memory too.
- Rendering benchmark 1: A plane and 5 glass spheres.
- Rendering benchmark 2: 10000 spheres, each one with its own texture.
Parse time is just a few seconds.
- Rendering benchmark 3: An isosurface and an area light
(http://iki.fi/warp/pics/lftest1.jpg).
I rendered them in a Sun Ultra 5 and here are the results:
Parsing benchmark:
gcc: 6 min 10 sec
v8: 5 min 39 sec
v8plus: 5 min 37 sec
v8plusa: 5 min 25 sec
v9: 6 min 34 sec
v9a: 6 min 35 sec
gcc: 4 min 8 sec
v8: 3 min 50 sec
v8plus: 5 min 6 sec
v8plusa: 3 min 44 sec
v9: 4 min 8 sec
v9a: 4 min 57 sec
gcc: 4 min 8 sec
v8: 3 min 55 sec
v8plus: 4 min 0 sec
v8plusa: 3 min 40 sec
v9: 3 min 52 sec
v9a: 3 min 49 sec
gcc: 4 min 51 sec
v8: 4 min 51 sec
v8plus: 6 min 30 sec
v8plusa: 4 min 53 sec
v9: 5 min 40 sec
v9a: 5 min 31 sec
The v8plusa seems the winner.
I think that the v9 compiles are slower because it generates 64-bit code,
which is larger, stresses more the memory bus and overflows caches more
quickly and POV-Ray doesn't get any advantage of 64-bit code.
7382340,3358,3900569407,970,4254934330},0)}// - Warp -
I thought I was being detailed! You must have spent all day at this. :o
> Parsing benchmark:
> gcc: 6 min 10 sec
> v8: 5 min 39 sec
> v9: 6 min 34 sec
> v9a: 6 min 35 sec
> gcc: 4 min 8 sec
> v8: 3 min 50 sec
> v8plus: 5 min 6 sec
> v9: 4 min 8 sec
> v9a: 4 min 57 sec
> gcc: 4 min 8 sec
> v8: 3 min 55 sec
> v8plus: 4 min 0 sec
> v9: 3 min 52 sec
> v9a: 3 min 49 sec
> gcc: 4 min 51 sec
> v8: 4 min 51 sec
> v9: 5 min 40 sec
> v9a: 5 min 31 sec
OK. I agree but not because I did the same mix of tests. I'm not surprised at
the v8plusa winner because that is what I found as well. I did test with other
scene files and the v8plusa was always a bit faster. I don't believe the -fast
option really is the optimal settings for my system. Not simply because it
seems to be too easy to implement without thinking but primarily because I think
a compile built for an Ultra5 or Ultra10 is at best a close fit for an E450 or
Ultra2. A non-portable binary just doesn't seem right and the generic build is
horrible. The middle ground is a binary built for systems with reasonably fast
processors and at least 1Mb of L2 cache. That would cover most Sun systems
quite easily.
Who knows what the future holds. I am certainly waiting to see what a new
version of Pov-Ray will look like. Multi-threaded and Client-Server will be a
lot of fun to run. :)
Dennis Clarke
