POV-Ray : Newsgroups : povray.unix : Pause and restart rendering Server Time
22 Apr 2025 15:23:18 EDT (-0400)
  Pause and restart rendering (Message 1 to 3 of 3)
Subject: Pause and restart rendering
Date: 4 Jan 2001 04:04:02
Message: <3a543c82@news.povray.org>
is it possible to pause a render and than restart it at the same position
like it is possible in the Win9x-version of PovRay?
Thanks,
Jan
Subject: Re: Pause and restart rendering
Date: 4 Jan 2001 07:01:58
Message: <3A54667E.43D0DA8F@atos-group.com>
> Hi,
If like W9x you mean keeping the memory allocated and the process present
 (and no reboot!), any decent shell should be able to do it.
Assuming Ctrl-Z is set to susp, and that the render is run in foreground,
then hitting Ctrl-Z on the shell should put povray in a suspended state.
restart in ksh (and some other shells) is usually done with 'fg',
see your shell man page.
Date: 4 Jan 2001 08:24:11
Message: <3a54797b@news.povray.org>
You can stop povray with ctrl-c and later continue the same render by
giving the +C command line option.
