POV-Ray : Newsgroups : povray.unix : Difficulty with gd and hf-lab Server Time
11 Jun 2026 03:10:39 EDT (-0400)
  Difficulty with gd and hf-lab (Message 1 to 3 of 3)
Subject: Difficulty with gd and hf-lab
Date: 11 Dec 2000 02:59:11
Message: <3a34894f@news.povray.org>
I'm trying to get HF-Lab installed on my RedHat 6.2 box. Initial attempts at
compile revealed that gd-1.3 wasn't providing the support for PNGs that
HF-Lab needs.
So I'm trying to install gd-1.7.3. I've tried making it from the tarball and
I've tried installing the RPM. Neither errored out, but nor does gd-1.7.3
seem to be installed on the system. RPM -V tells me not installed.
make on hf-lab still tries to get gdImagePng out of gd-1.3
There is an option to make it without current gd support... editing the
config.h file to #define OLD_GD. Of course, that removes all imaging support
from hf-lab, or I assume that is why I get a seg fault when trying the
'show' command that displays the image.
I am farily new to Linux, but pick up quick, quick enough to be dangerous,
and I hope I haven't hosed my system :)
Any experienced input?
Subject: Re: Difficulty with gd and hf-lab
Date: 11 Dec 2000 04:12:12
Message: <slrn9394hu.fns.steve@zero-pps.localdomain>
>HF-Lab needs.
With 1.7.3 try
# rpm --freshen gd-1.7.3.rpm
Also this might be a libpng problem rather than a gd problem.  My libpng
version is 1.0.5 (recently upgraded), and I have no problems with it.
  8:26am  up 61 days, 10:51,  3 users,  load average: 1.24, 1.08, 1.02
Date: 11 Dec 2000 15:15:34
Message: <3A3535E6.3EF0531A@ij.net>
> HF-Lab needs.
	You have a suggestion from Steve. Does that work for you? I have it
compiled. I have not played with it much. But I find an original version
of fftn.c with a modified version. I have no memory if I changed it or
it came that way. But I can send it to you if you like.
If you quit smoking now you can live long enough
to get Altzheimer's.
           -- The Iron Webmaster, 24
