![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I recently compiled povray 3.5c (Unix: gcc@alphaev56-dec-osf5.1) -
that is HP(Compaq) Tru64 v5.1b and it runs for the most part just fine.
However it crashes when it starts *parsing* meshes !
Parsing...Floating exception
// Here is an example to illustrate it:
location <0,0,-10>
look_at <0,0,0>
right x * 1.0
background { color rgb <1,1,0> }
light_source {
< 0.000, 2.000, -5.000 >
color rgb <1.000, 1.000, 1.000 >
sphere { <0,0,0>, 0.3
texture { pigment { color rgb z }
finish { ambient 0.2 diffuse 0.7 specular 0.3 }
#declare xxT1 = texture {
pigment { color rgb x }
mesh {
triangle {
<-1, -1, 0>, <1,-1,0>, <0,0,0>
texture { xxT1 }
// end of the example.
I ran dbx :
Parsing...signal Floating point exception at
[_Z12Mesh_Hash_UVPiS_PPA2_dPd:6
+0x32dc,0x1200901cc] * This module was written by Dieter Bayer [DB]
When I type in a couple of conts it eventually gets through and renders
a correct image !
Does anyone know what might be wrong ?
Again this is only on Compaq Alpha Tru64 ( 600au and ES40 ). This thing
runs fine on Irix and Linux.
Ah, gcc version : gcc (GCC) 3.2.3
Thanks,
Lothar
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3EAB0698.AA29884A@helix.nih.gov> , Lothar Esser
A bug in the compiler? Turn off all optimsations to see what iis wrong.
And also lok at the generated code if it still crashes.
Thorsten
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Lothar Esser wrote:
> I ran dbx :
Please compile with debugging symbols and find out in which source
code line (inside Mesh_Hash_UV, mesh.cpp) the SIGFPE is triggered.
Wolfgang
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wolfgang Wieser wrote:
> Lothar Esser wrote:
> > I ran dbx :
Sorry it took me a while. I kind of suspected that it is a gcc problem so
I decided to spend some time to recompile gcc 3.2.3 and see whether I see
a problem there. I did not. Here is the output from gdb
$gdb ./povray
{ here comes the usual header from povray, no problem there}
Statistics Stream to console....On
Warning Stream to console.......On
Parsing...
Program received signal SIGFPE, Arithmetic exception
0x00000001200c9b28 in Mesh_Hash_UV(int*, int*, double (**) [2], double*)
(Number=0x11fffb9b4, Max=0x11fffb9c8, Elements=0x11fffbb50,
aPoint=0x11fffbb08) at mesh.cpp:1972
1972 hash = (unsigned)((int)(326.0*P[U])^(int)(694.7*P[V])) %
HASH_SIZE;
(gdb) where
#0 0x00000001200c9b28 in Mesh_Hash_UV(int*, int*, double (**) [2],
double*) (Number=0x11fffb9b4, Max=0x11fffb9c8, Elements=0x11fffbb50,
#1 0x00000001200e1ed8 in Parse_Mesh() () at parse.cpp:3320
#2 0x00000001200e9258 in Parse_Object() () at parse.cpp:5832
#3 0x00000001200e9fa0 in Parse_Frame() () at parse.cpp:6180
#4 0x00000001200d9090 in Parse() () at parse.cpp:293
#5 0x00000001201381c8 in FrameRender() () at povray.cpp:876
#6 0x0000000120137f88 in FrameLoop() () at povray.cpp:786
#7 0x0000000120137c14 in povray_render(int, char**) (argc=2,
argv=0x1400d4420) at povray.cpp:497
#8 0x00000001201376f8 in main (argc=2, argv=0x11fffc018) at
povray.cpp:286
(gdb) list
286 ret = povray_render(argc, argv);
287 #endif
289 /* Finish */
290 povray_terminate();
292 return ret;
293 }
294 #endif
(gdb)
-- I am not terribly good at debugging. Does anyone have an idea what to try next?
(again I use gcc 3.2.3 on alphaev68 (this time, same problem with ev56) )
Thanks for any pointers ...
Lothar
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> HASH_SIZE;
> (gdb) where
What I found out in the meantime is that apparently absurdly small values are passed
on to Mesh_Hash_UV in form of UV_VECT aPoint. That is
aPoint[U] = 1.0e-311 ; aPoint[V] = 1.0e-322;
The following recasting to int or even multiplication with another double leads to a
SIGFPE. I suspect that somehow these numbers are too small. So I allowed myself to
do:
P[U] = rint(P[U]); P[V] = rint(P[V]); after the Assign_UV_Vect(P, aPoint) statement
and then it worked.
Is this a unique problem of Tru64 or is there a switch or directive that takes care
of numerical underflow issues like these ?
( Ah, the puzzle somehow is now, why is aPoint so small ... this I have no clue about
- something uninitialized maybe ?)
Thanks for any information.
Lothar
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
More precisely the values passed on to
Mesh_Hash_UV
are FP_POS_DNORM which probably points to some uninitialized variable problem.
Unfortunately I cannot track that down.
So instead of rounding to the nearest integer, I check the fp_class and when it is
DNORM then I arbitrarily set it to 0.0;
if ( fp_class(P[U]) < 8 ) P[U] = 0.0; if ( fp_class(P[V]) < 8 ) P[V] = 0.0;
This works perfectly so far.
Any other ideas ?
Lothar
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
