POV-Ray : Newsgroups : povray.unix : Pyvon 0.95 - Pov-Ray editor for Linux Server Time
4 Oct 2024 23:59:20 EDT (-0400)
  Pyvon 0.95 - Pov-Ray editor for Linux (Message 1 to 10 of 24)
Subject: Pyvon 0.95 - Pov-Ray editor for Linux
Date: 29 Aug 2002 14:09:32
Message: <3D6E6285.4050109@caramail.com>
Thanks to all those who sent me email about suggestions, debugging,....
For those who still use emacs + pov-mode, I just wonder what keeps them
from trying.
I was about to give it a higher release number, but there might be bugs
lurking in the code lines.....
I developped a pre-compiled version which is about 10-15 % faster, but I
could not send both the normal and the pre-compiled version in the
package. For those you are interested, just let me know.
http://pyvon.sourceforge.net
(the screenshots of the website are not updated yet)
Here are the changes : There are quite a few
c85 - 29/08/2002 - Pyvon 0.92
Optimized the code. It is now about 10-15 % faster
c82 - 29/08/2002 - Pyvon 0.92
Completely changed the About menu (now with working link)
c81 - 21/08/2002 - Pyvon 0.92
Rebuild the help menu
c80 - 28/08/2002 - Pyvon 0.92
Fix a bug about the insertions. Now a line is added at the beginning and
at the end
c79 - 28/08/2002 - Pyvon 0.92
Added the possiblity for multilanguage support (menu_eng.py, menu_fra.py)
c78 - 27/08/2002 - Pyvon 0.92
Added comments for easy reading of source
c77 - 27/08/2002 - Pyvon 0.92
Rebuild the povray executable options
c76 - 27/08/2002 - Pyvon 0.92
Rebuild the font menu
c75 - 26/08/2002 - Pyvon 0.92
Added a few shortcut keys (Ctrl+o : Open, Ctrl+q : Quit,....)
c72 - 26/08/2002 - Pyvon 0.92
Changed the interface font
c70 - 25/08/2002 - Pyvon 0.92
Added file/replace/replace all menu
C67 - 22/08/2002 - Pyvon 0.92
Added file history in the file menu ( up to 7 files )
C62->c65 - 22/08/2002 - Pyvon 0.92
Fixed minor bugs
C61 - 21/08/2002 - Pyvon 0.92
Syntax coloring is by default turned on, but when opening files larger
than 500 Kb,
it is automatically turned off.
Line syntax coloring (where the cursor is located) is still effective.s
C60 - 20/08/2002 - Pyvon 0.92
pyvon.ini is now replaced by pyvonrc which is located in your home
directory.
C58 - 20/08/2002 - Pyvon 0.92
Fixed a the slowdown when matching brace inside a very large file
C57 - 19/08/2002 - Pyvon 0.92
Improved the opening file speed by ~ 100. Especially useful when opening
large file.
It now takes 25 seconds to open, tag and colorize a 1 Mb large file on a
PIII 1 Mghz.
(compared to minutes with a 200 Ko file)
Added a scale for the quality setting
Subject: Re: Pyvon 0.95 - Pov-Ray editor for Linux
Date: 29 Aug 2002 18:02:23
Message: <3d6e99ef$1@news.povray.org>
> from trying.
I for one like to be able to get around without using the mouse in an
application, but I'll be sure to give it a try.
Unrelated question:
 From the website:
The name Pyvon comes from a mixture of Python, Povray and Linux.
Why did you reject the n in Python and opted to mix in the n from Linux?
Rob
Date: 30 Aug 2002 04:50:09
Message: <3D6F310C.2000900@caramail.com>
For the name I just scrambled all the letters found in these three
words, and Pyvon was the one I liked the most.
>> from trying.
The point is that you always have to go to and back between the terminal
and your editor.
I come from a 'windows' world where mice are a common pet. I now use
terminals quite a lot now, but I am grateful when a mouse is available
in an application. I find it much faster.
It sometimes saves you from typing a '120-letter-long command line in a
terminal with the inherent mistakes you might do.
Fabien
> Unrelated question:
>  From the website:
> Rob
Date: 30 Aug 2002 05:29:07
Message: <3D6F3A2E.60902@caramail.com>
I forgot one thing :
Pyvon now supports multilanguage.
I am looking for good-will to translate the file 'menu_english.py' or
'menu_francais.py' into german, italian, spanish,... My german is not up
to it anymore.
The file contains about 40 words.
> from trying.
> at the end
> Fixed minor bugs
> than 500 Kb,
> directory.
> large file.
> PIII 1 Mghz.
Date: 30 Aug 2002 08:19:31
Message: <3d6f62d3$1@news.povray.org>
> to it anymore.
I'm willing to do the translation into German. But where can I find the
file 'menu_english.py'?
Bonsai
    ___ __ __  _ ___ ___  _
   | _ )  \  \( )  _) _ )( )
   | _ \() |\ \ |\ \/ _ \| |
   |___/__/_)\__)___)/ \_)_)
        www.b0n541.net
Date: 30 Aug 2002 08:40:11
Message: <qhpumus7a101pjnc634t3jk6k3e7u2euui@4ax.com>
On Fri, 30 Aug 2002 11:26:06 +0200, Fabien HENON <fab### [at] caramailcom>
> to it anymore.
I did that for Polish but:
1. I have no Python do test it
2. I'm not sure I can use language specific characters
3. no idea what 'CPU PAL' means
4. have added Trans_POLISH entry
so what now ?
ABX
Date: 30 Aug 2002 08:41:28
Message: <3d6f67f8@news.povray.org>
 > to it anymore.
Bonsai
         www.b0n541.net
Date: 30 Aug 2002 08:47:14
Message: <v1qumuo5dcchhe0oslv9s4pa37pk2oaael@4ax.com>
On Thu, 29 Aug 2002 20:05:57 +0200, Fabien HENON <fab### [at] caramailcom>
I have one suggestion, convert file from http://www.abx.art.pl/pov/bonus
and add it to this.
Currently there is strange last modification listed at
http://pyvon.sourceforge.net/readme.txt placed in the future.
ABX
Date: 30 Aug 2002 09:13:02
Message: <3d6f6f5e$1@news.povray.org>
> so what now ?
O.k., I'm at the same point as ABX is now. Just change Polish into
German... :-)
So long,
Bonsai
        www.b0n541.net
Date: 30 Aug 2002 10:05:17
Message: <3D6F7816.9090107@caramail.com>
>> up to it anymore.
> Bonsai
The file menu_english.py can be found in the latest Pyvon_0.95.tgz
archive at the Pyvon homepage.
Once you have it
the german language option.
Fabien HENON
