POV-Ray : Newsgroups : povray.unix : Build optimisation flags? Server Time
12 Mar 2026 21:40:40 EDT (-0400)
  Build optimisation flags? (Message 1 to 9 of 9)
Subject: Build optimisation flags?
Date: 22 Aug 2002 11:33:28
Message: <3D65208A.9000304@tuna.nl>
I've been running the Linux povray binary under linux emulation on
(NetBSD 1.6_BETA4) without any problems but I decided trying to
compiling from source to see if there would be a significant speed
defference. The thing is there seems to be,... only the linux binary is
faster than my (statically linked!) compile.
Does anyone know the optimisation settings/ other performance tweaks
used to compile the linux binary distributed from the pov site?
Rob
Subject: Re: Build optimisation flags?
Date: 22 Aug 2002 13:06:47
Message: <3d651a27@news.povray.org>
  There was a thread about that issue, I think it was in this same group,
and there were good compiler flag suggestions there. I don't remember
the name of the thread, but you should browse previous threads here.
  Anyways, the usual gcc optimization flags (which are not platform-specific)
used are something like "-O6 -ffast-math -fomit-frame-pointer".
  Besides these, you should use the optimization flags dependant on your
system. IIRC these include several -m* flags, such as -mcpu=(your cpu type)
and other similar ones.
  "gcc -v --help |& less" should give you a full list of options.
Date: 22 Aug 2002 14:40:42
Message: <3D654C6B.9020906@tuna.nl>
I already had a look around but haven't been able to find anything, but
I'll have a closer look.
Those are the obvious ones and the ones I used already, my gcc is at
2.95.3 is gcc 3+ used for the pov builds and could this result in a
significant speed gain?
I'm not talking about a small increase, for illlustration a simple scene
( FWIW: 4 panes of glass on a checkered floor using photons )
linux precompiled binary:
	2 secs parse 55 secs trace
native build:
	2 secs parse 201 secs trace
Something is _really_ strange here, this can't be only optimisation flags?
System Athlon TB 1Ghz, 512Mb CAS2.5 DDR SDRAM
Rob
Date: 22 Aug 2002 23:42:24
Message: <3D65AF65.1090008@netscape.net>
gcc 3.1.1 did show a pretty good speed boost over gcc 2.96 (those are
the versions I tested). For instance, rendering benchmark.pov produced
the following times using the same optimization settings:
gcc 2.96:  28m 1s
gcc 3.1.1: 25m 14s
The prebuilt binary from 8/7/02 took 34m 10s (the earlier prebuilt binary
was MUCH slower).
> native build:
You need to place the optimization flags in 2 places; at least that worked
for me. What I did was run the ./configure then edited the src/Makefile
and changed the CXXFLAGS and CFLAGS to the following:
CXXFLAGS = -g -O3 -s -mcpu=athlon -march=athlon -finline-functions
-ffast-math \
-fomit-frame-pointer -Wall -funroll-loops -fexpensive-optimizations \
-malign-double -foptimize-sibling-calls -minline-all-stringops
$(NOMULTICHAR)
CFLAGS = -g -O3 -s -mcpu=athlon -march=athlon -finline-functions
-ffast-math \
You'll notice that they're almost identical except for the NOMULTICHAR part.
Hope this helps!
-Roz
Date: 22 Aug 2002 23:52:12
Message: <3d65b16c@news.povray.org>
Roz <Rzl### [at] netscapenet> wrote:
> CXXFLAGS = -g
  Don't use -g.
  That flag is for debugging purposes only. Since you are compiling a final
version with extreme optimizations, -g is not only useless and cause the
binary to be uselessly large (until stripped), but it even *might* contradict
with some optimizations, thus resulting in a slightly less optimized binary
(perhaps this is not the case, but it could be).
Date: 22 Aug 2002 23:56:54
Message: <3D65B2CC.3020304@netscape.net>
>>CXXFLAGS = -g
>   Don't use -g.
That's what I get for piecing together everyone's suggestion for flags :P
Thanks Warp, I'll do some test renders without that debugging flag!
-Roz
Date: 23 Aug 2002 00:16:55
Message: <3D65B77C.6040209@netscape.net>
Roz wrote:
>>> CXXFLAGS = -g
>>   Don't use -g.
>> final
>> contradict
>> binary
Strangely, it didn't make any difference. The file size is the same and
the rendering times didn't really change. Perhaps the -s flag overrides
the -g flag? Either way, it might as well not be there.
-Roz
Date: 23 Aug 2002 08:16:29
Message: <3d66279c@news.povray.org>
  Ah, I didn't notice that you had a -s flag as well. If I had, I would have
also said that "the -g is even more useless since you are removing all the
debugging information it produces with -s".
  AFAIK -s does not turn off -g, but it simply tells the linker to strip the
final binary. The compiler still adds the extra debugging information when
you specify -g (you can see this from the difference in size of the .o files).
  If -g does not have any negative effect in speed, then that's good. However,
it's still useless to specify it, and you only get a lot larger object files,
wasting your disk space.
  (Note that -s still makes a difference even when you don't specify -g; the
binary still has some debugging information which can be stripped; what -g
does is to add *extra* debugging information.)
Subject: gcc 2.95.3 vs. 3.2 [ Was: Re: Build optimisation flags?]
Date: 23 Aug 2002 10:19:14
Message: <3D6660A7.4010007@tuna.nl>
>>CXXFLAGS = -g
>   Don't use -g.
NetBSD does not have a gcc 3+ packages yet but I compiled it from source
using the compiler glags suggested by you and Roz.
This turns out to give a major speed gain, I've attached some data in
case anyone is interested.
Rob
Download 'us-ascii' (2 KB)
