POV-Ray : Newsgroups : povray.unix : Compiling 3.5 on IRIX 6.5 Server Time
22 Apr 2025 08:19:27 EDT (-0400)
  Compiling 3.5 on IRIX 6.5 (Message 1 to 10 of 22)
Subject: Compiling 3.5 on IRIX 6.5
Date: 5 Aug 2002 14:35:12
Message: <3D4EC559.4DB91631@scripps.edu>
I am having problems getting povray 3.5 to compile on my SGI with IRIX
6.5. I get the following errors:
gmake[1]: Entering directory `/home/didonato/temp/povray-3.50a/src'
g++ -DPREFIX=\"/home/didonato/bin/povray\"
-DPOV_LIB_DIR=\"/home/didonato/bin/povray/share/povray-3.5\"
-DCOMPILER_VER=\".Linux.gcc\"
-DSYSCONFDIR=\"/home/didonato/bin/povray/etc\"
-I/usr/freeware/include  `if [ "Xgcc" = "Xgcc" ]; then echo
"-Wno-multichar"; fi ` -c atmosph.cpp
atmosph.cpp: In function `void do_rainbow(RAY*, INTERSECTION*, float*)':
atmosph.cpp:502: `max' undeclared (first use this function)
atmosph.cpp:502: (Each undeclared identifier is reported only once for
each
   function it appears in.)
atmosph.cpp: In function `double constant_fog(RAY*, double, double,
FOG*,
   float*)':
atmosph.cpp:688: `min' undeclared (first use this function)
gmake[1]: *** [atmosph.o] Error 1
gmake[1]: Leaving directory `/home/didonato/temp/povray-3.50a/src'
gmake: *** [all-recursive] Error 1
Has anyone successfully compiled it for IRIX?
Mike
Michael DiDonato, PhD
The Scripps Research Institute
Department of Molecular Biology
Maildrop MB4
10550 North Torrey Pines Road
La Jolla, CA, 92037
Tel: (858) 784-9261
FAX: (858) 784-2277
http://www.scripps.edu/~didonato
Download 'us-ascii' (2 KB)
Subject: Re: Compiling 3.5 on IRIX 6.5
Date: 5 Aug 2002 14:39:27
Message: <3d4ec65f@news.povray.org>
What about reading some older messages in this group?
http://objects.povworld.org - the POV-Ray Objects Collection
Date: 5 Aug 2002 14:50:56
Message: <3D4EC910.B3E0A228@scripps.edu>
That was my first thought, but since I was out of tough with my
email/newsgroups for the last week I have no access to any messages
before today. Is there a link or something you can point me to?
Mike
Maildrop MB4
La Jolla, CA, 92037
Tel: (858) 784-9261
FAX: (858) 784-2277
Download 'us-ascii' (1 KB)
Date: 5 Aug 2002 14:53:35
Message: <3d4ec9af$1@news.povray.org>
1. Open up src/config.h.
2. Find the #include <algorithm> line.
3. Add this below that line.
    using std::min;
    using std::max;
4. Save and make.
--josh
  "Michael DiDonato" <did### [at] scrippsedu> wrote in message
news:3D4EC910.B3E0A228@scripps.edu...
  Mike
Maildrop MB4
La Jolla, CA, 92037
Tel: (858) 784-9261
FAX: (858) 784-2277
Download 'iso-8859-1' (3 KB)
Date: 5 Aug 2002 14:54:46
Message: <3d4ec9f5@news.povray.org>
I think there are some threads further down talking about namespaces and the
STL (the STL provides generic templates for min/max which work with any
comparable types).  I of course neglected to read these suggestions before
I compiled and took a more brute-force approach by changing all calls to
min/max to fmin/fmax (and you also have to change min3 and max3).  Not sure
if fmin/fmax will be available on IRIX though.
Ken
> each
> FOG*,
>    float*)':
> Mike
> Maildrop MB4
> La Jolla, CA, 92037
> Tel: (858) 784-9261
> FAX: (858) 784-2277
Date: 5 Aug 2002 14:54:53
Message: <3d4ec9fc@news.povray.org>
for people with crappy newsreader there is the webinterface:
http://news.povray.org
Date: 5 Aug 2002 15:26:33
Message: <3D4ED169.93766903@scripps.edu>
OK I got by that problem, but now I get another error:
g++ -DPREFIX=\"/home/didonato/bin/povray35\"
-DPOV_LIB_DIR=\"/home/didonato/bin/povray35/share/povray-3.5\"
-DSYSCONFDIR=\"/home/didonato/bin/povray35/etc\"   -I/usr/freeware/include  `if
[ "Xgcc" = "Xgcc" ]; then echo "-Wno-multichar"; fi ` -c unix.cpp
unix.cpp: In function `void UNIX_Abort_Start()':
unix.cpp:655: cannot convert `void (*)(int)' to `void (*)()' for argument `2'
   to `void (* signal(int, void (*)()))()'
unix.cpp:658: cannot convert `void (*)(int)' to `void (*)()' for argument `2'
unix.cpp:661: cannot convert `void (*)(int)' to `void (*)()' for argument `2'
gmake[1]: *** [unix.o] Error 1
Thanks for the help.
Mike
Maildrop MB4
La Jolla, CA, 92037
Tel: (858) 784-9261
FAX: (858) 784-2277
Date: 5 Aug 2002 21:56:56
Message: <3d4f2ce7@news.povray.org>
That's pretty wierd!  Not really familiar with IRIX, but I though it was
standard for signal handlers to be called with an integer parameter - maybe
they just have their protypes mixed up.  You could try explicit casting to
make the compiler happy:
  signal(SIGTERM, ((void (*)()) UNIX_Abort_Handler);
...although no promises on whether the signal handling will behave as
expected.
Ken
>> the STL (the STL provides generic templates for min/max which work with
>> any
>> before I compiled and took a more brute-force approach by changing all
>> calls to
>> sure if fmin/fmax will be available on IRIX though.
>  `if
> `2'
> `2'
> `2'
> Mike
> Maildrop MB4
> La Jolla, CA, 92037
> Tel: (858) 784-9261
> FAX: (858) 784-2277
Date: 7 Aug 2002 00:44:52
Message: <mzvg6ns2ez.fsf@zefiro.peace.co.nz>
Ken Cecka <cec### [at] alumniwashingtonedu> writes:
> expected.
> Ken
From the IRIX signal(2) manpage
     C:
       void (*signal (int sig, void (*func)()))();
     C++:
       void (*signal (int sig, void (*func)(int)))(int);
     #if _XOPEN_SOURCE
     #endif
So it looks like an additional test in the configure script and
setting _XOPEN_SOURCE should get the right proto.  Not that I've
tested this nor checked with other things _XOPEN_SOURCE affects.
Alternatively...
     #define _BSD_SIGNALS or _BSD_COMPAT before including <signal.h>
and you get the slightly different and non-SYSV-compatible BSD proto:
     int (*signal(int sig, int (*func)(int, ...)))(int, ...);
Rohan
Date: 7 Aug 2002 14:28:40
Message: <3D5166D1.6A78DC2C@scripps.edu>
> > expected.
> > Ken
>      C:
>      C++:
>      #if _XOPEN_SOURCE
>      #endif
> Alternatively...
> Rohan
Tried -D_XOPEN_SOURCE and then got the following error:
g++ -D_XOPEN_SOURCE -DPREFIX=\"/home/didonato/bin/povray35\"
-DCOMPILER_VER=\".Linux.gcc\" -DSYSCONFDIR=\"/home/didonato/bin/povray35/etc\"
-I/usr/freeware/include  `if [ "Xgcc" = "Xgcc" ]; then echo "-Wno-multichar"; fi
` -c unix.cpp
unix.cpp:297: aggregate `timeval hstart' has incomplete type and cannot be
   initialized
unix.cpp:297: aggregate `timeval hstop' has incomplete type and cannot be
   initialized
unix.cpp: In function `void UNIX_Timer_Start()':
unix.cpp:500: `gettimeofday' undeclared (first use this function)
unix.cpp:500: (Each undeclared identifier is reported only once for each
unix.cpp: At global scope:
unix.cpp:297: storage size of `hstart' isn't known
unix.cpp:297: storage size of `hstop' isn't known
Mike
Maildrop MB4
La Jolla, CA, 92037
Tel: (858) 784-9261
FAX: (858) 784-2277
Download 'us-ascii' (4 KB)
