POV-Ray : Newsgroups : povray.unix : Linux version is slower than windows version? Server Time
6 Oct 2024 15:24:27 EDT (-0400)
  Linux version is slower than windows version? (Message 1 to 10 of 21)
Subject: Linux version is slower than windows version?
Date: 30 Jul 2002 11:07:51
Message: <3D46AC6C.3070703@web.de>
Hi there
I just compared the rendering speed of the official windows and linux
version of POV3.5 and got the very strage result that the linux version
takes the double amount of time (2.11x) the windows version needs to
render the benchmark scene (scenes/advanced).
For both OSes I used the scene from the linux version and the ini
settings given in the file (benchmark.pov).
Result:
_Windows_:
Ray->Shape Intersection          Tests       Succeeded  Percentage
Box                           79358745         9334253     11.76
Cone/Cylinder                 78379572         6515873      8.31
CSG Intersection             162923001        55142852     33.85
CSG Merge                       741865           34312      4.63
Fractal                        1831644          104482      5.70
Height Field                   3901191          105560      2.71
Height Field Box               3901191          707900     18.15
Height Field Triangle          3376757          108905      3.23
Height Field Block             5889587         1742423     29.58
Height Field Cell             23435856         1852284      7.90
Isosurface                    11669415          721134      6.18
Isosurface Container          12154734        11669868     96.01
Isosurface Cache                176199           42446     24.09
Mesh                          12295275           64396      0.52
Plane                         85284171         1281858      1.50
Sphere                       260332524       153124522     58.82
Superellipsoid                  620681           43704      7.04
Torus                          2887283          411263     14.24
Torus Bound                    2887283          480972     16.66
True Type Font                  838010           80727      9.63
Clipping Object                2557372         1524945     59.63
Bounding Box                 653803865       124207145     19.00
Vista Buffer                  21535803        11650388     54.10
Isosurface roots:         11664259
Function VM calls:       169416006
Roots tested:               480972   eliminated:              274031
Calls to Noise:         4512422082   Calls to DNoise:     2404216638
Media Intervals:          36350371   Media Samples:        327887642 (9.02)
Shadow Ray Tests:        118768042   Succeeded:             48914570
Reflected Rays:             223228   Total Internal:             470
Refracted Rays:             145054
Transmitted Rays:           602889
Number of photons shot:          74025
Surface photons stored:          64488
Priority queue insert:         2226874
Priority queue remove:          163988
Gather function called:         659394
Smallest Alloc:                 25 bytes   Largest:          1440024
Peak memory used:          6401076 bytes
Time For Parse:    0 hours  0 minutes   6.0 seconds (6 seconds)
Time For Photon:   0 hours  1 minutes  59.0 seconds (119 seconds)
Time For Trace:    1 hours 16 minutes  13.0 seconds (4573 seconds)
     Total Time:    1 hours 18 minutes  18.0 seconds (4698 seconds)
POV-Ray finished
_Linux_:
Box                           77632067         9442332     12.16
Cone/Cylinder                 76120049         6536461      8.59
CSG Intersection             161344159        55414898     34.35
CSG Merge                       807486           34776      4.31
Fractal                        1764372          102306      5.80
Height Field                   3820218          105458      2.76
Height Field Box               3820218          705167     18.46
Height Field Triangle          3369358          108722      3.23
Height Field Block             5876169         1734582     29.52
Height Field Cell             23360039         1850304      7.92
Isosurface                    11757862          728681      6.20
Isosurface Container          12260392        11758389     95.91
Isosurface Cache                148786           41647     27.99
Mesh                          12352449           65016      0.53
Plane                         85650538         1287339      1.50
Sphere                       261625223       155438827     59.41
Superellipsoid                  633727           44548      7.03
Torus                          3018587          424283     14.06
Torus Bound                    3018587          496226     16.44
True Type Font                  816332           80799      9.90
Clipping Object                2572219         1535917     59.71
Bounding Box                 501031242       147127728     29.36
Vista Buffer                  22076619        12692365     57.49
Isosurface roots:         11752486
Function VM calls:       170441799
Roots tested:               496226   eliminated:              280279
Calls to Noise:         4531067372   Calls to DNoise:     2415593890
Media Intervals:          36494048   Media Samples:        329183857 (9.02)
Shadow Ray Tests:        119312109   Succeeded:             49156296
Reflected Rays:             224291   Total Internal:            1066
Refracted Rays:             146314
Transmitted Rays:           602466
Surface photons stored:          63352
Priority queue insert:          724352
Priority queue remove:          136937
Gather function called:         666007
Smallest Alloc:                  9 bytes   Largest:          1440008
Peak memory used:          5442716 bytes
Time For Parse:    0 hours  0 minutes   8.0 seconds (8 seconds)
Time For Photon:   0 hours  3 minutes  39.0 seconds (219 seconds)
Time For Trace:    2 hours 41 minutes  44.0 seconds (9704 seconds)
     Total Time:    2 hours 45 minutes  31.0 seconds (9931 seconds)
I use an Athlon900Mhz with 312M Ram
Windows 98SE
SuSE Linux 8.0 (Kernel 2.4.18 is this important???)
Under Linux I ran POV as a user and shut down nearly all other tasks (X,
network, etc.) so top said pov uses 98% CPU power.
Under Windows I used the gui to load the ini and the benchmark file.
(Resolutions and AA are the same :-) () )
My question
Does anyone has similar problems so it is in the binaries or is it just
me and my sytem?
10000/4700 Sekonds is a very bad result!
Sebastian H.
Subject: Re: Linux version is slower than windows version?
Date: 30 Jul 2002 11:41:19
Message: <3d46b39e@news.povray.org>
Sebastian H. <seb### [at] webde> wrote:
> _Windows_:
> _Linux_:
  Are you completely and absolutely 100% sure that you are using the exact
same benchmark scene and the exact same ini file settings (and I mean *all*
settings)?
  If everything was exactly identical, I don't see any reason for those
numbers to be different.
Date: 30 Jul 2002 11:53:54
Message: <8hddku0gvu2nbj9ngfrhg88j28p4f4bg4o@4ax.com>
Jitter for AA ?
ABX
Date: 30 Jul 2002 12:56:10
Message: <3d46c529@news.povray.org>
Maybe you should make sure that the general POV-Ray configuration files are
the same for both OS. What about copying povray.ini to $HOME/.povrayrc ?
Also note that they aren't compiled by the same compiler. The windows
version may be much more optimized than the linux version. When sources are
available you can compile your own version with gcc -O3 and some system or
processor specific optimizations.
light_source{0#macro L(K,H,W)sphere{H.5}sphere{K.5}sphere{W.5}cylinder{
H,K.5}cylinder{H,W.5}#end 3}union{L(0v*-2<2,-2>)L(y*-3z-v*5z*3-y)L(-y*3
0u*3)L(y*-3v*-5-z,z*-3-y)rotate-v*clock pigment{rgb.5}translate<0,2,9>}
// +KFF200 +KF720 +W120 +H90 -F -A -GA -P
Date: 30 Jul 2002 17:48:30
Message: <3D470A56.3010100@web.de>
>>_Windows_:
>>_Linux_:
> settings)?
It was definitly the same .pov file I copied it into a seperate
directory as the .ini file.
The differences you mentioned above made me wonder too but the deviation
here wasn't very high.
A real huge difference is in "Priority queue insert:"
2226874 (Windows)
  724352 (Linux)
But what does that mean ?:-)
The other stuff of the POV output of both renderings were quite similar
but I'am not sure about jitter (to ABX) (But since it was the same .ini
file...).
Yup this it what makes me wonder too.
A friend of mine who has a bit more knowledge about computer stuff in
general (whatever that means)
said that an optimization that gives you half rendering time would be
_very_ good (to Felix).
I don't know much about this stuff but I like linux and would prefer to
play with POV here (Dualboot sucks if you can't share data without
bending everything to fat).
I'll comapare it again take care of the parameters (hopefully a fault of
mine :-) ), we'll see...
Thanks for comments
Sebastian H.
Date: 30 Jul 2002 17:50:42
Message: <3D470ADA.5000101@web.de>
Woops! Should have gone as a reply to Warp (Using Mozilla is so
difficult :-) ).
Sebastian H.
Date: 30 Jul 2002 18:12:46
Message: <pan.2002.07.30.22.16.38.415787.1479@povray.org>
> are the same for both OS. What about copying povray.ini to
> $HOME/.povrayrc ?
Yes, default run-time settings are different between Windows and
Linux.  Maybe I should change that.
> are available you can compile your own version with gcc -O3 and some
> system or processor specific optimizations.
This binary was built with gcc.  I may release a binary built with the
Intel compiler at some point.
-Mark Gordon
Date: 31 Jul 2002 00:27:33
Message: <pan.2002.07.31.04.26.56.185250.230@gte.net>
On Tue, 30 Jul 2002 11:10:36 -0400, Sebastian H. quoth:
> Hi there
> Windows 98SE
> My question
> me and my sytem?
Yes, it's a very real effect.  I got 10 seconds to render Skyvase under
Windows, and 24 seconds under Linux.  The reason for this is the
different compilers used: in the Windows version, the compiler produced
several versions of parts of the code, each version optimized for a
different CPU.  This gives a larger but faster binary than the Linux
compiler, which appears to have optimized for a generic x86 processor.
Mark
Date: 31 Jul 2002 02:42:18
Message: <cg1fkukd110urnbat44jov6q7ceot6lass@4ax.com>
On Tue, 30 Jul 2002 23:51:18 +0200, "Sebastian H." <seb### [at] webde> wrote:
> file...).
From documentation: "Note: the jittering noise is random and non-repeatable"
From benchmark.pov: Jitter_Amount=1 Jitter=On
ABX
Date: 31 Jul 2002 07:03:38
Message: <3D47C4B2.1050108@web.de>
Nice and not nice to know...
Would a for the specific (linux) system optimized compilation gain the
speed of the windows bins?
