POV-Ray : Newsgroups : povray.unix : To the Unix gurus ! Server Time
5 Apr 2026 11:08:58 EDT (-0400)
  To the Unix gurus ! (Message 1 to 9 of 9)
Subject: To the Unix gurus !
Date: 23 Jul 2002 12:19:58
Message: <3D3D7FA6.90709@caramail.com>
I need some help about terminals.
For Pyvon, I would like to use a script to start boths Pyvon and a
terminal to which the verbose, errors, stats ( in short all the normal
output) of POV is redirected; with Pyvon taking up 2/3 of the upper
screen and the terminal the 1/3 left.
For the time being, I start konsole (KDE terminal), resize it so that it
takes up about 1/3 (at the bottem ) of the screen, type python pyvon.py
( to start Pyvon), and then resize Pyvon to fill up the rest to the screen.
The best would be a script that test the screen resolution and does the
rest automatically.
Something else :
How do you send a command into a terminal ( like Xterminal ) which is
already created so that the output of the command goes back to Xterminal
? It's the end of the day's work I am not sure my english is clear
enough .............
Thanks
Fabien
Subject: Re: To the Unix gurus !
Date: 23 Jul 2002 13:20:53
Message: <slrnajr41c.k4k.steve@zeropps.org.uk>
How about something a bit more standard like Xterm rather than something that's
desktop specific.
> rest automatically.
Maybe the X man page or Xresorces man page would be a good place to start
here, also look at the xterm man page there is the "-geometry" option this
is explained in more detail in the X man page.
> Something else :
Example:
Open your Xterm like this:
xterm -e tail -f some.file.to.be.read
And start POV something like this:
povray -whatever -option -All_File=some.file.to.be.read
I havn't tested anything here and there are probably better solutions
but it may get you started.
#local i=.1;#local I=(i/i)/i;#local l=(i+i)/i;#local ll=(I/i)/l;box{<-ll,
-((I/I)+l),-ll><ll,-l,ll>pigment{checker scale l}finish{ambient((I/l)/I)+
(l/I)}}sphere{<i-i,l-l,(I/l)>l/l pigment{rgb((I/l)/I)}finish{reflection((
I/l)/I)-(l/I)specular(I/l)/I}}light_source{<I-l,I+I,(I-l)/l>l/l} // Steve
Date: 24 Jul 2002 03:28:24
Message: <3D3E5718.580CDDB7@imag.fr>
I think this will work only if some.file.to.be.read is a FIFO (otherwise
tail will end because the file is empty).
so first do :
mknod some.file.to.be.read p
and this should work.
Yann
Yann Remond (mailto:Yan### [at] imagfr)
Date: 24 Jul 2002 04:13:35
Message: <3d3e61af@news.povray.org>
  Not if you use tail -f
Date: 24 Jul 2002 05:10:37
Message: <3D3E6F0D.1060708@free.fr>
> rest automatically.
	Just a little quick hack in c-shell demonstrating this with
two konsole windows. Cons: this is csh, any other shell would be
for sure much better; it does not take into account the size of
windows decorations and other toolbars; some applications (xterm)
do not resize properly. Pros: none  ;o)
#!/bin/csh
set width  = `xwininfo -root | grep Width | cut -d: -f2`
set height = `xwininfo -root | grep Height | cut -d: -f2`
set twothird = `echo "scale = 0; $height * 2./3" | bc -l`
set onethird = `echo "scale = 0; $height - $twothird" | bc -l`
konsole -geometry ${width}x${twothird}+0+0 &
konsole -geometry ${width}x${onethird}+0-0 &
Date: 24 Jul 2002 05:12:31
Message: <slrnajsrhu.m7q.steve@zeropps.org.uk>
> so first do :
You don't need to do this, as my example says use tail -f.
sphere{z*5,1pigment{rgb.5}finish{reflection.3specular.5}}box{<-50,-3,-50>
<50,-2,50>pigment{checker/*\__\\__/  * \_\\__*/scale 2}finish{ambient.7}}
light_source/*__\\__\\__\\__\\__\(    ~ )\__\\__\\__\\__\\*/{<2,5,1>*4,1}
/*\\__\\__\\__\\__\\__\\__\\__\\__\~  -/__\\__\\__\\__\\__\\*//* Steve */
Date: 25 Jul 2002 03:39:54
Message: <3D3FAB4A.80134500@imag.fr>
Ok, I just miss it !
But the file must exist. So either you launch PoV before xterm or you
use something like "touch some.file.to.be.read".
This works : this time I try before posting stupids tricks :-)
Yann
Date: 25 Jul 2002 13:24:54
Message: <slrnak0csq.onv.steve@zeropps.org.uk>
> Yann
Yes touching the file every time Pyvon is started is a good idea, it'd
be nice to purge the file after it reaches a certain size too - and keep
previous output and let the file grow to a size specified by the user in
the config file, maybe default to something like 1 Meg.  And if the file
is over 1 Meg when render is pressed then use > rather than >> and maybe
even copy the old some.file.to.be.read to a backup file.
Date: 27 Jul 2002 07:33:37
Message: <3D42844B.2020309@caramail.com>
I'll try that one, because Python for once does not seem to fit the bill.
Fabien HENON
>> the rest automatically.
> #!/bin/csh
