POV-Ray : Newsgroups : povray.unix : Install script Server Time
11 Jun 2026 00:10:40 EDT (-0400)
  Install script (Message 1 to 5 of 5)
Subject: Install script
Date: 19 Mar 2002 10:33:20
Message: <3C975AF6.4060101@gmx.net>
since I removed some files, I had to re-install POV-Ray. When running
the install script I got an error that the povray-3.4.13 directory in
/usr/local/share/doc already exists (generated by mv). I found a
directory /usr/local/lib/povray-3.4.13/povray-3.4.13, which should be
moved to /usr/local/share/doc. So it would be a great improvement if the
install script deleted the documentation directory firstly (so that it's
possible to re-install the beta).
Thanks in advance,
Felix Wiemann
Subject: Re: Install script
Date: 19 Mar 2002 13:34:22
Message: <slrna9f0ue.ain.steve@zero-pps.localdomain>
On Tue, 19 Mar 2002 16:36:22 +0100, Felix Wiemann wrote:
> Hi,
> Thanks in advance,
> Felix Wiemann
From all the betas I've installed I've never seen this problem.
                                             or http://start.at/zero-pps
  6:30pm  up 13 days, 20:28,  1 user,  load average: 1.00, 1.03, 1.04
Date: 19 Mar 2002 19:53:21
Message: <3c97dd81$1@news.povray.org>
On Tue, 19 Mar 2002 10:36:22 -0500, Felix Wiemann wrote:
> Hi,
> Thanks in advance,
> Felix Wiemann
The current install script does have the potential to clutter up
/usr/local/share/doc a bit.  I'll make sure the next version cleans up
old doc directories.
-Mark Gordon
Date: 20 Mar 2002 08:36:13
Message: <3C989109.5040502@gmx.net>
Oh, sorry, I haven't been clear enough. I talked about re-installing the
*same* beta, so what actually wanted to suggest is deleting the doc
directory of the *current* (not the old) beta.
Just try running the installation script twice and have a look at
/usr/local/lib/povray-3.4.13. The doc directory hasn't been moved to
/usr/local/share/doc and is still in the povray directory.
Felix Wiemann
Date: 25 Mar 2002 06:20:11
Message: <3C9F08B5.4060709@gmx.net>
Works fine now, thank you! :)
