POV-Ray : Newsgroups : povray.unix : Command-line option to turn off #macro or #fopen or #write? Server Time
10 Jun 2026 19:12:30 EDT (-0400)
  Command-line option to turn off #macro or #fopen or #write? (Message 1 to 10 of 12)
Subject: Command-line option to turn off #macro or #fopen or #write?
Date: 13 Nov 2000 18:50:56
Message: <3A107E60.BE067E87@rap.ucar.edu>
Hello There.
I have an online povray rendering farm and I happened to be the victim
of a "hack" attempt already with it.  The user was quite intelligent and
used povray macros to edit my .login an .cshrc files on my machine.
<pout>  It actually worked and started to delete stuff, but thankfully I
caught it in time and saved everything.  So, kudos to whomever wrote it,
but in the future, I'd like to stop those types of attacks if possible.
Anyway, I'd like to bring the farm back online, but in order to do so, I
need to know if it's possible to remove the ability to do #fopen's and
#write's via the command line or something like that.  I don't want to
disable #macros because they're a powerful part of the povray 3.1
language, but I do want to make the renderer a little more secure.
Does anyone know?  I'm using povray 3.1g.
- Steve
EMAIL: (h) ste### [at] badcheesecom  WEB: http://badcheese.com/~steve
       (w) swe### [at] rapucaredu
           ste### [at] mailcom
Subject: Re: Command-line option to turn off #macro or #fopen or #write?
Date: 13 Nov 2000 20:52:02
Message: <chrishuff-152E04.20521413112000@news.povray.org>
In article <3A107E60.BE067E87@rap.ucar.edu>, Space Dude
Ouch. I would have liked to think the POV community was above this sort
of thing...recent posts show otherwise, though. :-(
I notice you are on Linux...can't you just restrict access to those
files?
I think you would only need to disable #write, but you can't do it by
the command line or .ini file in 3.1g or current MegaPOV. It would be
very easy to cripple it's functionality by modifying the source, making
a version that has this as an option would be a bit more difficult.
Christopher James Huff
Date: 13 Nov 2000 21:14:48
Message: <3A10A018.A2AB62BE@rap.ucar.edu>
> files?
> Personal: chr### [at] maccom, http://homepage.mac.com/chrishuff/
> TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
Ok, I suppose that I should just write a script for grep for #write
before rendering, huh?  I shoulda just thought of that.  Ok.  That's
cool.  Thanks!
- Steve
           ste### [at] mailcom
Date: 13 Nov 2000 22:58:54
Message: <3a10b87e$1@news.povray.org>
In article <3A10A018.A2AB62BE@rap.ucar.edu> , Space Dude
> cool.  Thanks!
When doing that, be aware that something like this is also valid:
#      write(.....)
and you may want to play around with it a bit to find out what else is or is
not valid.
     Thorsten
Date: 14 Nov 2000 00:13:43
Message: <3A10C9A7.DBF4D833@faricy.net>
It was IMBJR!
(kidding, kidding)
Date: 14 Nov 2000 08:31:09
Message: <slrn912fku.5q4.ron.parker@fwi.com>
You might try either modifying the source code to disable the ability to
do #write (and #fopen) or you might try just using chroot and/or file
permissions to restrict where the POV process is allowed to write.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 14 Nov 2000 18:25:17
Message: <3A11C9DD.662A9FF@rap.ucar.edu>
Hey!
Thanks for all of the input - All of the suggestions were very useful
and I'm proud to say that the povray renderer is back up and running and
should be much more hacker-proof!
http://www.badcheese.com/~steve/povray_form.shtml
P.S. I've added a few more more powerful machines to the farm so people
may feel happy to pound away.
- Steve
           ste### [at] mailcom
Date: 15 Nov 2000 08:33:10
Message: <3a129096@news.povray.org>
"Space Dude" <swe### [at] rapucaredu> wrote in message
news:3A1### [at] rapucaredu...
As a couple of extra suggestions:
1. Couldn't you institute a password/login?
2. Couldn't you search (and strip) the incoming pov script for fopen etc.?
Date: 15 Nov 2000 19:49:18
Message: <3A132E40.22660778@helixcode.com>
Initial reactions:
1) It sounds like POV-Ray was running as your user from some sort of
remotely executable script.  If you're going to do something like that,
run it as a special user made expressly for the purpose, perhaps even
one who can't log in.
2) It's not a bad idea to have it run within chroot.  That makes it
harder to clobber any files outside its isolated little sandbox (avoid
the myriad /tmp races, for instance, as well as keeping it out of your
own personal ~).  Give it a little piece of your filesystem to call home
and put everything it needs there.
I'm not sure how your rendering farm is set up, so I can't be much more
specific in my advice.
-Mark Gordon
Date: 16 Nov 2000 06:52:55
Message: <3A13CB95.4B68D987@free.fr>
> -Mark Gordon
	Hey ! Mark is back :-)
	How was your moving ? Hope all was fine for you.
	Well, are we now almost able to use the "official" unofficial
MegaPOV for UNIX/Linux ? {hehehehehe}
	Glad to *see* you again on n.p.o !
*** Nicolas Calimet
*** http://pov4grasp.free.fr
