POV-Ray : Newsgroups : povray.unix : abbrevs in pov-mode Server Time
31 Mar 2026 17:47:44 EDT (-0400)
  abbrevs in pov-mode (Message 1 to 5 of 5)
Subject: abbrevs in pov-mode
Date: 17 Sep 2000 18:29:51
Message: <39c545df@news.povray.org>
Hello all.
        I'm using Emacs under Windows 98 to edit my .pov files and when I'm
trying to implement some per-mode abbreviations using the command C-x-a-l I
get the message that there are no per-mode table for pov. Yet, I can clearly
see that the line (pov-mode-abbrev-table) does exist in my .abbrev_def file
in my home directory. So, what gives ?  The power of the minor abbrev mode
is mainly what makes me prefer Emacs over the Codemax editor that comes with
the distribution of POV for Windows.
Subject: Re: abbrevs in pov-mode
Date: 25 Sep 2000 16:59:31
Message: <39CFBCB2.C25D2F85@acc.umu.se>
JRM wrote:
>     Hello all.
I suppose this is something I should be able to answer, but I can't
since I
haven't played with the minor abbrev modes, I find that Alt-tab is
enough,
and with the latest (beta) release of pov-mode most keywords (I'm sure I
have
missed a few) have abbrev support by alt-tabbing. I'm not sure what you
really
want to do, so I'll stop mumbling now ;)
/Peter
Alpha Test Version:  Too buggy to be released to the paying public.
Beta Test Version:  Still too buggy to be released.
Release Version:  Alternate pronunciation of "Beta Test Version".
Date: 26 Sep 2000 17:54:44
Message: <39d11b24$1@news.povray.org>
39CFBCB2.C25D2F85@acc.umu.se...
> since I
> enough,
> have
> really
> /Peter
    Alt-tab have another binding in  Windows as you may know. Also,
abbreviations in emacs can be very exhaustive, leaving very little to edit.
They also are so easy to create that I have only little use for include
files now.
    Thanks for answerng anyway. I guess the subject is large enough to go to
some Emacs help group with it.
    BTW, I wonder what happened  to my original message which is not showing
here anymore.
JM
Date: 27 Sep 2000 02:39:58
Message: <7553ts0jc26cr0934g640ng7ash0kggo3b@4ax.com>
>here anymore.
  Likely a setting in that you're using in your newsreader. I just
retrieved messages in this group from the last ten days and your
original post is there:
Newsgroups: povray.unix
Date: Sun, 17 Sep 2000 18:29:56 -0400
X-Newsreader: Microsoft Outlook Express 5.50.4133.2400
X-MimeOLE: Produced By Microsoft MimeOLE V5.50.4133.2400
Message-ID: <39c545df@news.povray.org>
<snip..>
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 28 Sep 2000 15:15:52
Message: <39D398DA.4A2E1039@acc.umu.se>
> > since I
> > enough,
> > have
> > really
> > /Peter
> files now.
You can change line 1651 (or around there) in pov-mode.el and set some
other
key combo instead of alt-tab (or meta-tab as it's really written, but
windows
doesn't have meta so it's alt).
/Peter
