POV-Ray : Newsgroups : povray.unix : Slideshow player Server Time
10 Jun 2026 14:57:24 EDT (-0400)
  Slideshow player (Message 1 to 9 of 9)
Subject: Slideshow player
Date: 24 Feb 2000 14:01:52
Message: <38B5D532.6D0DD80B@home.nl>
Hi all,
I'm making an animation with a friend. I'm doing the povray work and he
makes the animation of the seperate frames. But for testing the .pov
files, I like to see some sort of animation. Does anyone know a
slideshow player for Linux or something equal?
Thank you in advance,
Remco Poelstra
Subject: Re: Slideshow player
Date: 24 Feb 2000 15:39:40
Message: <38B59712.5ABD2F53@numerik.uni-kiel.de>
animate is part of the ImageMagick package:
http://www.ImageMagick.org/
Axel
Date: 24 Feb 2000 15:53:42
Message: <38B5EF68.603A3641@home.nl>
Thanks.
Remco
Date: 25 Feb 2000 04:55:28
Message: <38B650EE.5D1851C7@pacbell.net>
Remco Poelstra wrote:
> Hi all,
> Remco Poelstra
I am not sure this is what you are looking for but it is worth a little
investigation - http://heroine.linuxbox.com/bcast2000.html
Date: 25 Feb 2000 05:53:18
Message: <38B65F1F.BCD77AEB@ica.uni-stuttgart.de>
Well Ken, bcast2000 is a bit of an overkill here?
It's a realtime video editing tool. This means you can edit and infeed
video stream the moment it runs. It's very professional and in this case
also very free!! :-)
Marc
Marc Schimmler
Date: 25 Feb 2000 06:44:08
Message: <38B66A69.FADC59D1@pacbell.net>
Maybe a little tiny bit.
I give good link :)
Date: 25 Feb 2000 11:01:31
Message: <slrn8bblv2.2bo.sjlen@zero-pps.localdomain>
On Thu, 24 Feb 2000 20:04:50 -0500, Remco Poelstra <rjp### [at] homenl> wrote:
>Hi all,
With Image Magic go into the directory where your images are
and type:
where 50 is the 100ths of a second that you want to wait between
images.
 12:34am  up 1 day, 14:16,  6 users,  load average: 1.09, 1.14, 1.08
Date: 26 Feb 2000 01:37:16
Message: <38B77403.83B16A1C@pacbell.net>
Serge LAROCQUE wrote:
> Ken, another link for you:
> http://www.photodex.com/downloads/download_cpic.html
> It's called Compupic, for Linux, Windows, Macintosh, FreeBSD, NetBSD, Solaris
> 7
I used Cpic for years until I found PSP :)
Date: 10 Mar 2000 18:03:13
Message: <38C95862.13656F21@email.com>
> Thanks.
> Remco
I use animate to quickly preview how an animation is going before I go
to the trouble of creating the Mpg.
I found that the best format to use from pov is ppm.
So to use it use
animate -delay 10 *.ppm where the delay is in 100ths of a second. Once
the frames are being played, there are commands you can use to slow down
the playing, speed it up, pause etc.
If I remember correctly, use the left (or was it the right) mouse button
to get a list of the commands that can be used.
Cheers Fran
