POV-Ray : Newsgroups : povray.unix : Does AutoClock Modifier work on POV-Unix? Server Time
22 Apr 2025 23:11:38 EDT (-0400)
  Does AutoClock Modifier work on POV-Unix? (Message 1 to 3 of 3)
Subject: Does AutoClock Modifier work on POV-Unix?
Date: 26 Jan 2000 01:15:52
Message: <388E9140.12345EF5@mm.ewha.ac.kr>
Dear POV'ers:
 I've just installed the POV-ray on the Unix. I really appreciate all
the help from the POV experts.
Now, I'd like to know if I could run the ClockModifier by Chris Colefax
on this POV-ray on Unix.
(http://www.geocities.com/SiliconValley/Lakes/1434/clockmod.html)
Do I have to wait until the ClockModifier Unix version released?
Better yet, do I simply copy the source and compile as I did for the POV
unix?
I am quite new to this Unix system.
Thanks in advance,
Jong
Subject: Re: Does AutoClock Modifier work on POV-Unix?
Date: 26 Jan 2000 02:01:56
Message: <388E9B1C.8AB9CD28@pacbell.net>
"J. Kim" wrote:
> Dear POV'ers:
> unix?
> Thanks in advance,
> Jong
Chris Colefax's ClockModifier file is in the same language as regular
.pov files. To use it you need to follow the directions for that
particular file and then use the #include directive to access the
functions of that file. There is no reason that ClockMod will not
work on any platform that POV-Ray operates on because all it is
is a .pov file with a .inc extention. There is no way to compile
it.
For an excellent tutorial on using the ClockMod include file follow
this link - http://www.puzzlecraft.com/cm/ClockMod.html
Date: 26 Jan 2000 04:10:20
Message: <388EBA0D.8EB597B9@mm.ewha.ac.kr>
Thanks a lot, Ken.
 It's running really flawless.
Jong
> [deleted...]
> Ken Tyler -  1300+ Povray, Graphics, 3D Rendering, and Raytracing Links:
