POV-Ray : Newsgroups : povray.unix : nice (thought?) Server Time
10 Jun 2026 15:00:05 EDT (-0400)
  nice (thought?) (Message 1 to 10 of 11)
Subject: nice (thought?)
Date: 11 Jan 2000 15:24:36
Message: <387B76DE.466B6FE9@bahnhof.se>
Hewwo folks.
I'd like to know if it was at all possible to make a certain program
(POV) run with a nice value other than 0 as default? I use my machine
for single user tasks, and I'd like to have pov running at -5 (or such)
as default withouth having to work as root and renice it all the time.
Then I'd be able to set it to something like 15 for longer renders..
possible? dumb?
//Spider    --  [ spider@bahnhof.se ]-[ http://darkmere.wanfear.com/ ]
And the devil in black dress watches over
    My guardian angel walks away
Life is short and love is always over in the morning
    Black wind come carry me far away
            --"Sisters of Mercy" -- "Temple Of Love"
Subject: Re: nice (thought?)
Date: 11 Jan 2000 20:18:23
Message: <387BD69E.F907B2EE@mailbag.com>
Spider wrote:
> Hewwo folks.
> possible? dumb?
It's easily possible to automatically set a lower priority with an alias
or a front-end script.  It sounds like that's not what you have in mind,
though. ;-)
It should be possible to write a script to get the PID (assuming you
only have one render going) and renice it using "su -c".  It will
require password verification, but it should be much less painful than
doing this manually.  Sound useful, or never mind?
Nice thought, yes. ;-) And nice seeing you again, BTW.
-Mark Gordon
Date: 12 Jan 2000 03:52:23
Message: <387c40c7@news.povray.org>
I don't know if there's any other way to set a negatice nice other than
running it as root or setting the effective UID of the program to root
(and the program changes its own nice to the desired value). The latter one
is very dangerous if there are other users in the same system.
  Perhaps theres another way (there's so much I don't know about unix...).
Date: 12 Jan 2000 09:15:36
Message: <387C0236.32ED8D33@bahnhof.se>
> though. ;-)
Not really :) A lower priority wouldn't really speed things up.. :I
it does sound useful, yes.
(re)nice ;-) to see you as well
(nope, no more pov crashes :)
Hm, should probably do something like that on X as well.. should be
easier since it leaves .pid files.. then perhaps a root cron job to exec
it once every 15 mins...
oh. while on the matter of X ... is there a way to restart the XFree86
server without killing all programs that run through it? I've noticed
that it does increase quite a lot in memory consumption after some use,
and running a long time task or such through it leaves you in a bit
bothered situation...
Date: 12 Jan 2000 09:38:04
Message: <387C91AA.AB9400AE@usit.net>
According to the man page for "nice", only the superuser can request
a negative "nice" value (i.e. higher priority). Any user can request
a positive value (i.e. lower priority).
You might build a script that invokes the renderer with appropriate
arguments and make that script setuid root. As pointed out above,
though, this would be dangerous if there are other users on the box.
Is this a single-user computer?
Setting the nice value might not be necessary, though. If you're the
only user and nothing else is going on in the background, it just
might be that POV will get the lion's share of cycles anyway. Try
running "top" to see what is running on the box. Anything that's
in a sleeping state won't be taking cycles, as they're waiting on
an external event before being scheduled to run again, so no CPU
time is going to those processes anyway. I just opened up a shell
on my machine at home with X and Netscape running (plus loads of
support stuff), and everything except "top" was sleeping, waiting
for input.
If you're not running anything computationally intensive (number-
crunching, downloading a file, whatever) at the same time you're
running POV, I doubt you'll see any significant speedup from the
negative "nice" setting.
Date: 12 Jan 2000 12:55:12
Message: <387CC000.8E9A0C6D@numerik.uni-kiel.de>
Check out sudo. This gives you quite some opportunities.
Just configure it such that you can access renice as root.
Axel
Date: 12 Jan 2000 20:12:31
Message: <387D26C3.704C03B1@mailbag.com>
Start programs nohup, and they ought to survive bouncing X.  Not much
you can do once they're started, though, but good for future reference I
hope.
-Mark Gordon
Date: 12 Jan 2000 20:15:09
Message: <387D2760.B6A758B6@mailbag.com>
Some systems don't allow scripts to be run SUID root.  It wouldn't be
too big a deal to rewrite it in C, but I wouldn't recommend it.
> for input.
I see my share of CPU drop when my nightly cron jobs start chugging
away, but outside of that, I pretty much agree.
-Mark Gordon
Date: 12 Jan 2000 21:02:47
Message: <387D2D61.976CFC80@bahnhof.se>
> hope.
How do I do that?
(ignorance at work here)
Date: 13 Jan 2000 06:29:45
Message: <387DB72A.CF432C23@numerik.uni-kiel.de>
> > hope.
> How do I do that?
a) RTFM (oops, reads man nohup)
b) nohup povray foobar &
Note:
XWindows programs won't do this. If you quit the X-server and want to
restart it, all programs with graphical output need to be terminated.
Axel
