POV-Ray : Newsgroups : povray.unix : Linux offline newsreader problem. Server Time
6 Oct 2024 21:16:01 EDT (-0400)
  Linux offline newsreader problem. (Message 1 to 6 of 6)
Subject: Linux offline newsreader problem.
Date: 17 Dec 1999 12:27:40
Message: <385A720A.81AA00F5@ndirect.co.uk>
I've asked around in the usenet groups and have had some
help, but not enough to get the thing working.
I need an off-line newsreader, and will go with leafnode and
slrn if I can get them to work.
What I think I need is a copy of someone else's slrn.rc
preferably with comments so that I know what's going on.
I keep getting the message that it's failed to initialize
the server.
Any help appreciated.
Also think I need the change the host name of my box in a
few other files that I can't find, Gnome tells me it can't
find the internet host (of my local machine) and says that
it may not work properly.
I've doen away with M$ completely and don't want to go back,
but at the moment this News problem is getting me down.
  1:27am  up 1 day,  2:48,  7 users,  load average: 1.12,
1.22, 1.25
Subject: Re: Linux offline newsreader problem.
Date: 17 Dec 1999 13:28:17
Message: <385a80c1@news.povray.org>
You should read the README that comes with slrnpull.  It seems
pretty comprehensive.  Here's what it says you need in your
.slrnrc, assuming you've gotten slrnpull working:
|Assume that the SLRNPULL_ROOT refers to the directory
|/var/spool/slrnpull.  Then the following .slrnrc lines should be
|sufficient to tell slrn how to deal with the news provided by
|slrnpull:
|    set spool_inn_root          "/var/spool/slrnpull"
|    set spool_root              "/var/spool/slrnpull/news"
|    set spool_nov_root          "/var/spool/slrnpull/news"
|    set read_active             1
|    set use_slrnpull            1
|The 'use_slrnpull' variable must be set to 1 to tell slrn to post the
|file to the out.going directory.  Also note that 'spool_root' and
|'spool_nov_root' must be set to the same value.
|In addition, it is a good idea to include the `hostname' and
|`username' lines, e.g.,
|    hostname                    "your.host.name"
|    username                    "your.user.name"
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 17 Dec 1999 15:10:53
Message: <385A984A.C5432092@ndirect.co.uk>
Thanks Ron I'll give it a try.
  6:08pm  up  2:59,  4 users,  load average: 1.32, 1.30,
1.18
Date: 20 Dec 1999 19:34:41
Message: <slrn85tii7.719.sjlen@zero-pps.localdomain>
Thanks Ron I gave up with leafnode after a few days and got slrnpull to work
straight away.
I've got a hell of a lot to learn, I'm using the total submersion method,
I've deleted all the M$ stuff and moved over to Linux, it's a steep learning
curve, but I'm getting there
>|slrnpull:
>|    set read_active             1
>|    set use_slrnpull            1
 11:53pm  up 2 days, 23:30,  7 users,  load average: 1.00, 1.17, 1.28
Date: 21 Dec 1999 03:04:02
Message: <PTRfOLyZCFgM=hjSutbUcaHC2BF2@4ax.com>
On 20 Dec 1999 19:34:41 -0500, sjl### [at] zero-ppslocaldomain (Steve)
>straight away.
Outside!" sticker on your PC :)))
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 21 Dec 1999 06:07:38
Message: <slrn85ukbr.8gv.sjlen@zero-pps.localdomain>
Peter this is no laughing matter, I havn't got it to view images in p.b.i yet,
and havn't even unpacked POV yet never mind get it running properly.
Hope I've got the headders sorted out now.  Oh I don't know how to get out of
this editor?! I think I'm going to be stuck here for ever!
>>straight away.
>Peter Popov
>pet### [at] usanet
>ICQ: 15002700
  8:38am  up 3 days,  8:15,  6 users,  load average: 1.00, 1.02, 1.00
