POV-Ray : Newsgroups : povray.unix : my animations are too big for the web. What to do ... Server Time
10 Jun 2026 16:17:02 EDT (-0400)
  my animations are too big for the web. What to do ... (Message 1 to 4 of 4)
Subject: my animations are too big for the web. What to do ...
Date: 5 Aug 1999 22:13:05
Message: <37AA44B3.31469A0B@interlog.com>
I am having a lot of fun creating animations by taking advantage of the
internal clock feature.  The problem is that the images are all 24 bit TGA files
at 320x240 and when I put 64 frames together I end up with a 14Mb QuickTime mov
file.  Is there a simple utility that will convert a tga file to a 8bit gif or
do I need to RTFM for cjpeg or libpng and write my own?
Dennis Clarke
ps: Yes I know that I am being lazy but if someone else has jumped through the
hoops to get a mov to mpg convertor or something like that then why re-invent
the wheel?
Subject: looks like the libpng tools include a dither RGB to 8bit example ...
Date: 5 Aug 1999 22:50:25
Message: <37AA4D72.69593F13@interlog.com>
I may have to break down and code a utility to convert 24bit png format to 8bit
bmp format ...
Is this really necessary just to shrink a mov file down to size ?
Dennis
Download 'us-ascii' (1 KB)
Subject: Re: my animations are too big for the web. What to do ...
Date: 6 Aug 1999 00:47:14
Message: <37AA6948.750A4749@geocities.com>
> Dennis Clarke
> the wheel?
Well, if you have a Quicktime movie, just try using Cinepak or one of the other
codecs.
Or create an MPEG. Look to http://www.mpeg.org/ for software.
BTW, it is very helpful if you mention what platform you are on.
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
Date: 6 Aug 1999 06:30:03
Message: <37aab92b@news.povray.org>
In article <37AA44B3.31469A0B@interlog.com> , Dennis Clarke
files
mov
All you need to do is to select a different compression algorithm in the
QuickTime settings. You can do that easily with the Movie Player that comes
with QuickTime. Try fro example Sorensen compressor or the Motion JPEG ones
with reasonable compression settings.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
