POV-Ray : Newsgroups : povray.unix : Image Packager/GIF Animation program? Server Time
6 Oct 2024 23:21:49 EDT (-0400)
  Image Packager/GIF Animation program? (Message 1 to 10 of 12)
Subject: Image Packager/GIF Animation program?
Date: 22 Jun 1999 01:45:31
Message: <377073DC.F794E70A@sitc.net>
I know in DOS there is DTA (yay! :) and various other programs to create
AVI and GIF animations. However, I am looking for a program that can do
the same thing, plus, maybe MPEG creation. At this moment, I really
could use the GIF animatino smoosher as I'm trying to make animated GIFs
on my web-page....
If you can give me any hints to where such a program might be, I'd
apreciate the help
Tim Soderstrom
TigerHawk
Subject: Re: Image Packager/GIF Animation program?
Date: 24 Jun 1999 13:44:14
Message: <37726E68.E1BA79EC@t-online.de>
> on my web-page....
The latest versions of GIMP (www.gimp.org) are capable of handling
animated GIFs.
Date: 24 Jun 1999 23:33:07
Message: <37744960.15ABE3FB@sitc.net>
Actually I use GIMP just for that (figured it out after actualyl getting off
my butt to look up stuff, hehe). It's not very easy to do, though....at least
I don't know how to do some things - like reverse the playback of an animated
GIF (I think there's a plugin that may help with they, but the newer version
of GIMP doesn't seem to have it - unless GIMP has been upgraded to include
it).
Now all I need is an MPEG encoder and I'm all set :)
Thanks for the help,
Tim Soderstrom
TigerHawk
> > on my web-page....
> animated GIFs.
Date: 25 Jun 1999 04:44:46
Message: <m3674c3dod.fsf@casimir.rezel.enst.fr>
TigerHawk <Tig### [at] sitcnet> writes:
I always recommend the Berkeley MPEG Tools.  Command-line interface,
highly configurable, really handy.  Search for "Berkeley MPEG Tools"
on <http://www.freshmeat.net/>.
Roland.
Roland Mas
Clef publique GnuPG / GnuPG public key
<URL:http://www.302-consulting.fr.eu.org:8080/~roland/gpg-public-key.asc>
Date: 25 Jun 1999 05:45:01
Message: <37734F9D.7904457F@ica.uni-stuttgart.de>
> on my web-page....
> apreciate the help
> Tim Soderstrom
> TigerHawk
For gif animations I use gifmerge.
http://www.tu-chemnitz.de/~sos/GIFMERGE/
together with giftrans to make non transparent gifs transparent
http://waldo.wi.mit.edu/WWW/tools/graphics/giftrans/
I found them very useful. For mpeg creation I used the mpeg tools on my
LINUX box at home (I found them difficult to handle) and at work I use
dmconvert but this is a program made by SGI and is not free (but very
convenient).
Marc
Marc Schimmler
Date: 25 Jun 1999 15:52:31
Message: <37752EFB.CEC7F18E@sitc.net>
Thanks, I'll be sure to check that out. I've done MPEG searched on freshmeat
before, but the results were always about MP3 software....
Apreciate the help!
Tim Soderstrom
TigerHawk
> Roland.
> Roland Mas
Date: 25 Jun 1999 15:54:01
Message: <37752F53.388387CA@sitc.net>
Do these utilities have control over playback direction? (Ie can I reverse
the order of the frames without doing it by hand, like I must do with GMIP?)
I'll be sure to check them out, though. GIMP is great, but is very
time-consuming to make a simple animation (at least, it is without a script)
Thanks for the info,
Tim Soderstrom
TigerHawk
> > on my web-page....
> > apreciate the help
> > Tim Soderstrom
> > TigerHawk
> convenient).
> Marc
> Marc Schimmler
Date: 28 Jun 1999 08:55:34
Message: <377770C6.EFAE90BF@ica.uni-stuttgart.de>
AFAIK this is not the case ... sorry!
If you are familiar with shell scripts or perl you could write a small
script that would change the numbering. Just an idea.
Marc
Marc Schimmler
Date: 28 Jun 1999 14:35:00
Message: <37791158.4A21518@sitc.net>
Well, I know a script when I see it, and I can do real simple things...I just
don't know the syntax of a script. Suppse I can get off lazy behind and go look,
hehehe....anyways, thanks for the help!
Tim Soderstrom
> Marc
> Marc Schimmler
Date: 29 Jun 1999 22:36:48
Message: <37798267.D9661085@t-online.de>
TigerHawk wrote:
When doing animated gifs, I use the following trick:
1. Create a long variable, e.g.
    a='1 2 3 4 5 6 7 8 9 10 9 8 7 8 9'
   containing the frame numbers in the right order.
   (writing shell functions like reverse() help doing this)
   It is often useful to have several of them and to
   combine them in various ways.
2. Say somthing like
   frames=''; for i in $a ; do frames=${frames}frame{$i}'.gif '; done
Having this in a shell script allows easy experimentation
(I often find out after looking ath the result that
some frames should be duplicated, skipped or even rerendered
for better results).
Ralf
PS: Please delete old quoted lines at the end of your postings.
AFAIK Netscape has even settings to correct this (Netscape 4.5*
comes with almost all default settings wrong).
