Hi. I have a POV-Ray book("Ray Tracing Creations") by the Waite group.
It is fairly old now but I was wondering if I can still use it as a
guideline for POV-Ray 3.1g. I just discovered to my delight that
POV-Ray is available for Linux. I typed in the first example from my
book and tried to render it, and I get the error:
"Bad option syntax or error opening ..INI/.DEF file 'camera{'. "
I installed the pre-compiled version in the default directories,
/usr/local/lib/povray31. By the way I am running RedHat 5.1 kernel
2.2.5
The first.pov listing looks like this:
location<>
look_at<>
object{}
object{}
object{}
I left it blank for brevity's sake but you get the idea. Am I
seriously out of touch here? Any help would be greatly appreciated. I
also dlded the source and I am going to try compiling it myself to see
if that makes any difference.
Preacher <nig### [at] hotmail com> writes:
> [...] I typed in the first example from my
I bet you types the command-line "povray first.pov" or something like
that. Well, don't. You have to type "povray -i first.pov", so that
POV-Ray knows first.pov is a POV scene file and not a parameters file.
I suggest you have a look at "man povray", to know the basic switches
to use when you invoke POV.
Roland.
Roland Mas
> Roland.
> Roland Mas
Thanks for the advice. My bad, I didn't read the man page... I read
everything but. thanks again.
Subject: Re: question about different versions
Date: 21 Jun 1999 10:26:52
Message: <376e4bac@news.povray.org>
In article <m3n### [at] casimir rezel enst fr> , rol### [at] email enst fr
"povray -i first.pov" works, but is not documented. For future compatibility
you may want to get used to (the documented) "povray -ifirst.pov".
Thorsten
