POV-Ray : Newsgroups : povray.unix : Makefile problem with 3.1e Server Time
7 Oct 2024 01:13:34 EDT (-0400)
  Makefile problem with 3.1e (Message 1 to 4 of 4)
Subject: Makefile problem with 3.1e
Date: 28 May 1999 14:07:55
Message: <374ECD69.8DEDF9E9@jila.colorado.edu>
I'm trying to compile POV-ray 3.1e on Digital UNIX 4.0D and Solaris
2.6.  libpng and zlib compile fine, but when I try "make newxwin" in the
source/unix directory, I get:
=> make newxwin
make: Fatal error in reader: makefile, line 1577: Macro assignment on
dependency line
for both DU and Solaris.
Has anyone seen this or know what might be causing it?
Thanks,
Peter
Peter Ruprecht                  UNIX Distributed System Support
JILA, Room S220                 phone: (303) 492-8255
Campus Box 440                  fax: (303) 492-5235
University of Colorado          email: rup### [at] jilacoloradoedu
Boulder, CO 80309-0440          http://jilawww.colorado.edu/~ruprech
Subject: Re: Makefile problem with 3.1e
Date: 29 May 1999 01:19:50
Message: <374F6AEE.D129C4F2@mailbag.com>
This sounds like the bug that was caused by some extraneous blank spaces
at the end of the line defining the X11 path.  This will be fixed in
future versions.
Mark Gordon
mtg### [at] povrayorg
Subject: R: Makefile problem with 3.1e
Date: 31 May 1999 06:34:25
Message: <375257a1.0@news.povray.org>
Peter,
try GNU-Make (gmake) instead of make.
I had the same error output on Solaris, and this fixed it.
HTH,
                                - Marco
> Hi,
> => make newxwin
> dependency line
Date: 1 Jun 1999 17:07:02
Message: <37543D64.CA2DDEC8@jila.colorado.edu>
Thanks for the above suggestions.
In addition, I had to remove the continuation
marker ( \ ) from the last line of the bcylDEP section of the makefile in
order for "make" to like the syntax.  Finally, the DEC C compiler
complained that several #define statements in polysolv.c were indented.
After that, it compiled fine and seems to be working.
  -Peter
