POV-Ray : Newsgroups : povray.unix : superpatch and unix Server Time
10 Jun 2026 17:47:28 EDT (-0400)
  superpatch and unix (Message 1 to 10 of 12)
Subject: superpatch and unix
Date: 21 May 1999 12:55:30
Message: <374585D0.DA89293E@image.bien.mu.edu>
Hi folks,
has anybody compiled the Superpatch for POVRay in an Unix
enviroment. Can anybody give me advice how to do this?
I will appreciate any help
Thanks
    chris
Subject: Re: superpatch and unix
Date: 21 May 1999 15:08:13
Message: <3745a10d.0@news.povray.org>
On Fri, 21 May 1999 11:12:00 -0500, Christian Wietholt wrote:
>Hi folks,
It took me a while, but I succeeded in getting the superpatch
to build with the Unix sources and the Cygwin toolkit under
Windows NT.  You should be able to use my makefiles and other
modifications to build it with the standard GNU tools under
your favorite Unix.  I can't maintain my website from here,
so you'll have to go over to povray.binaries.programming to
get the patch.  Just unzip it in your source directory (it
should replace frame.h, parse.h, and unix/makefile) and make
it as you usually would.
For obvious reasons, I haven't tested this with the X or SVGA
versions.  If anyone has any problems with those, let me know.
This does not include the shared library support, as far as I
know.  I need to consult the original isosurface materials to
figure out how that's supposed to work, and those are at home.
Date: 21 May 1999 17:58:41
Message: <3745CCE0.AF8E30BA@image.bien.mu.edu>
Ron,
Thank yoy very much for helping me. I really apreciate that.
At this time I am trying to compile your sources, but I found
some errors. Two of them I could fix, but about the third I am
not sure what to do exactly, I do not much about the sources,
perhaps you can help with this problem.
Bug report :
First:
In the makefile there is a little error. I think the two
lines beginning with C:\.... are there accidently.
radiositDEP =  $(SRCDIR)/radiosit.c \
C:\Cygnus\B19\H-i386-cygwin32\lib\gcc-lib\i386-cygwin32\egcs-2.91.57\..\..\..\..\i386-cygwin32\include\string.h
 C:\Cygnus\B19\H-i386-cygwin32\lib\gcc-lib\i386-cygwin32\egcs-2.91.57\..\..\..\..\i386-cygwin32\include\_ansi.h
 $(SRCDIR)/frame.h config.h $(SRCDIR)/lighting.h $(SRCDIR)/point.h
$(SRCDIR)/vlbuffer.h $(SRCDIR)/bbox.h $(SRCDIR)/vector.h \
 $(SRCDIR)/povray.h $(SRCDIR)/atmosph.h $(SRCDIR)/camera.h
$(SRCDIR)/media.h
Second:
file f_func.c line 207
    //*(calc_stack_top)= pow(
ABS(*(calc_stack_top)),*(calc_stack_top+1));
An ansi C Compiler does not understand the // - comment and it is
confusing
because of the * after the // to. I changed it that way :
    /* *(calc_stack_top)= pow(
ABS(*(calc_stack_top)),*(calc_stack_top+1)); */
otherwise I had some errors
Third:
Here I don't know exactly what to do.
"../f_param.c", line 78: error(1164): argument of type "OBJECT *" is
          incompatible with parameter of type "PARAMETRIC *"
     if (! Intersect_Par_Box (Ray, Object, &Depth1, &Depth2, &Side1,
&Side2))
I put here a cast in like :
     if (! Intersect_Par_Box (Ray, (PARAMETRIC*)Object, &Depth1,
&Depth2, &Side1, &Side2))
"../f_param.c", line 501: error(1143): declaration is incompatible with
          "PRECOMP_PAR_DATA *Precompute_Parametric_Values(PARAMETRIC *,
char,
          int)" (declared at line 158 of "../isosrf.h")
  PRECOMP_PAR_DATA *Precompute_Parametric_Values (Par, flags, depth)
This problem I think I fixed by changing the line from
PARAMETRIC *Par;
char flags;
int depth;
to
PRECOMP_PAR_DATA *Precompute_Parametric_Values (PARAMETRIC * Par, char
flags, int depth)
Now it finished compilation but I am not sure if the cast will do the
job
during runtime. What do you think about that?
I am looking forward to hearing from you.
    chris
> >Hi folks,
Date: 21 May 1999 18:13:28
Message: <3745cc78.0@news.povray.org>
Yes, they are.  cpp -MMD is supposed to ignore system headers, but
apparently it missed some (I'm using egcs 1.1).  The dependencies
were generated automatically and massaged by a Perl script, so
while they're accurate, it's easy for bugs like that to sneak in.
>Second:
You are correct.  I had to fix that one, too, but I forgot to add
it to my zip file.
>Third:
I'm sure this is okay.  I'm surprised my egcs didn't complain about it.
OBJECT is the generic superclass to PARAMETRIC.  You got to that line
through the POV equivalent of a virtual function pointer, so you know
Object is in fact a PARAMETRIC.  The cast should be completely safe.
>PARAMETRIC *Par;
>char flags;
>int depth;
>to
>flags, int depth)
This should be fine, too.  I need to go eradicate the last vestiges of
K&R from all this code someday; does anyone know a warning that I can
enable to point out K&R-style function headers?
Date: 21 May 1999 18:30:36
Message: <3745D451.2CA1D2EE@image.bien.mu.edu>
Ron,
I just tested povray and x-povray both with shapes.pov and
with skyvase.pov. Both versions are working normaly. But
I could not test the new functions yet, I hope they will work
too.
I am not using the egcs. I am using the original SGI C-Compiler, and
I had similar experiences that the SGI Compiler is very sensitiv.
> >Third:
Good to know that my suggestion was correct, so I don't have to recompile
everything again.
> >PARAMETRIC *Par;
> >char flags;
> >int depth;
> >to
> >flags, int depth)
Sorry, but I don't know anything about such warnings. Strange is that was
the only error of this kind although there are many more function declared
like this. But now it is working and I think we don't have to worry about
it.
Again I wish to thank you very much for your support. I hope I can render
my volumetric data soon.
Take care
    chris
Date: 21 May 1999 18:38:36
Message: <3745d25c.0@news.povray.org>
On Fri, 21 May 1999 16:46:57 -0500, Christian Wietholt wrote:
>Ron,
>too.
You can get some demo files that Gilles Tran just posted in
povray.binaries.scene-files to test the isosurface functionality.
It should work okay; I tested my cygwin build with his iso_egg.pov
script and it looked just like the output from my MSVC build.
The fun might be just beginning.  You still have to figure out how
to build i_dat3d.so on Unix, or how to take the code from it and
shoehorn it into isofunc.c.  I'll look around and see what I can
find in the original (3.0) isosurface source on this problem.
Date: 21 May 1999 19:44:44
Message: <3745E5BC.553B5D6B@image.bien.mu.edu>
Ron,
I am just testing the superpatch with the demo files from Gilles
Tran and it seems to be working fine. That are great news.
Not so great is your last section. You mean we are not ready with
it. I suppose that the dat3d library is exactly what I need for my
volumetric data.
I think I can't be very helpful with porting the i_dat3d.so to Unix.
I have no idea what povray or the isosurface patch exactly does.
I am a beginner with povray. But I will take a look on that 3d
thing.
Thanks again
    chris
> >Ron,
> >too.
Date: 22 May 1999 20:12:48
Message: <374739EB.F5081648@uni-paderborn.de>
Hi
Hmmm...I can't find a group with that name on news.povray.org. Do you
use another server ?
CU
	Dodger
Date: 22 May 1999 23:04:01
Message: <374861ff.165546362@news.povray.org>
On Sun, 23 May 1999 01:12:43 +0200, Bjoern Jaeger
<joe### [at] uni-paderbornde> wrote:
>Hi
Nope, there are no other servers carrying povray.*.  It's definitely
on news.povray.org.  You might have to do whatever your newsreader
does to retrieve new groups.
Date: 23 May 1999 00:41:30
Message: <374777e3.33353640@news.povray.org>
  The name of the group is actually 'povray.programming'.
Alan
news.povray.org - where POV-Ray enthusiasts from around the world
                - get together to exchange ideas and experiences
