POV-Ray : Newsgroups : povray.unix : kpovmodeler + povray 3.7 Server Time
23 Dec 2024 11:33:59 EST (-0500)
  kpovmodeler + povray 3.7 (Message 1 to 6 of 6)
Subject: kpovmodeler + povray 3.7
Date: 6 Apr 2011 10:08:51
Message: <20110406110850.28a92506.john@johncoppens.com>
Hello people...
The SVN version of kpovmodeler compiles well, but isn't really
compatible anymore with 3.7 (only recognizes 3.1 and 3.5). In
particular, the +QR option is not recognized by the newer povray.
I'm no great C++ programmer, and even less knowledgeable about Qt,
so I solved the options issue by gluing bothe KPM and povray together
with a small Tcl script which removes unwanted options (see below).
That works fine, but the TGA image generated by povray, and sent to
stdout, is not recognized by KPM. I tried to write it to disk, and
only Gimp actually reads it (GQview, Geeqie, and other don't).
Is the TGA generated by povray some special variant?
John
#!/usr/bin/tclsh
set cmd "exec -ignorestderr -- povray"
foreach arg $argv {
  if {$arg == "-QR"} continue
  if {$arg == "+QR"} continue
  append cmd " " $arg
append cmd " > /tmp/test.tga"
exec echo $cmd >> /tmp/povlog
eval $cmd
exit 0
Subject: Re: kpovmodeler + povray 3.7
Date: 6 Apr 2011 10:21:08
Message: <4d9c76d4$1@news.povray.org>
Le 06/04/2011 16:08, John Coppens a écrit :
> Hello people...
I think, and I might be wrong, that the default file format for 3.7 on
unix is PNG, not TGA anymore.
(and to have edited the TGA file format lately (was before RC1, IIRC, to
add comments),... well it's Truevision Targa, and the version of format
evolved from very old 1 to 2.0 specification of 1991.
http://www.dca.fee.unicamp.br/~martino/disciplinas/ea978/tgaffs.pdf
And there is 2 TGA formats output for povray (the uncompressed one, and
the compressed one. (+FC vs +FT)
If you have imagemagick installed, ask "identify output.file" what it
think about the rendered image.
Software is like dirt - it costs time and money to change it and move it
around.
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Date: 6 Apr 2011 19:12:17
Message: <20110406201216.1e6312e7.john@johncoppens.com>
On Wed, 06 Apr 2011 16:21:04 +0200
Thanks... But I forgot to mention that indeed, the command line
contains +FT, so the format imposed on povray _is_ actually TGA.
Didn't know that trick! Identify gives:
test.tga TGA 640x480 640x480+0+0 8-bit DirectClass 922KB 0.060u 0:00.070
Maybe some spurious character gets inserted somewhere in the stdin
path. I'll have to investigate a bit more, it seems.
Thanks,
John
Date: 7 Feb 2012 07:10:00
Message: <web.4f31148421e92224a4ff49b00@news.povray.org>
John Coppens <joh### [at] johncoppenscom> wrote:
> Hello people...
> John
> #!/usr/bin/tclsh
> foreach arg $argv {
>   append cmd " " $arg
> eval $cmd
> exit 0
hallo
in kpovmodeler source find file "pmrendermode.cpp", at line 190
change
   if( m_radiosity )
      cl.append( QString( "+QR" ) );
   else
      cl.append( QString( "-QR" ) );
to
/* mod for povray 3.7
   if( m_radiosity )
   else
and recompile
all work except render preview, i'v black image during rendering but think that
this is another problem infact preview not appear using povray command from
konsole.
installed kpm_patch.txt ?
http://ubuntuforums.org/archive/index.php/t-968207.html
Date: 9 Feb 2012 13:55:01
Message: <web.4f34163721e9222488466d3c0@news.povray.org>
> Hello people...
> John
> #!/usr/bin/tclsh
> foreach arg $argv {
>   append cmd " " $arg
> eval $cmd
> exit 0
hallo
change
   if( m_radiosity )
   else
to
   if( m_radiosity )
   else
and recompile
konsole.
Date: 19 Jun 2012 12:37:54
Message: <20120619133751.9998468d.john@johncoppens.com>
Hello all,
Instead of patching KPovModeler, I wrote a small script, which calls
povray and removes the command line options which are not valid for
PovRay 3.7. This works fine it seems - if someone is interested.
I'm sure I haven't detected all incompatibilities, but the script is
easier to adapt than the source code.
As far as I can tell, all functions work well in the modeler... except
for a few lingering bugs which aren't pov-related.
John
