POV-Ray : Newsgroups : povray.tools.poser : Poser 6 for a bargain Server Time
7 Apr 2026 06:28:54 EDT (-0400)
  Poser 6 for a bargain (Message 9 to 18 of 38)
<<< Previous 8 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Poser 6 for a bargain
Date: 5 Dec 2008 04:26:19
Message: <4938f3bb@news.povray.org>
"Stephen" <mcavoysAT@aolDOTcom> schreef in bericht
news:7dhgj4tveo3tn8tmg54i74tfq92r1jqrn6@4ax.com...
>>I currently have Poser 5, and one of the most annoying things is that they
>>STILL do not have multiple levels of "undo".  Have they changed this in
>>Poser 6?  That alone would be a reason for me to spend $30.
> Hi Jeremy,
> I've got Poser 7 and had Poser 6. Without reinstalling Poser 6 to check
> I think that it is only Poser 7 that has multiple levels of "undo".
That is indeed and unfortunately correct. I mainly use Poser 7 but still
have Poser 6 sitting on my machine, so I checked this.
Date: 5 Dec 2008 04:29:09
Message: <4938f465$1@news.povray.org>
For some reasons (Poser 6 bargain; user survey at Content Paradise) I
suspect something is cooking at the factory. Either an upgrade to Poser 7 or
perhaps a Poser 8?
Date: 5 Dec 2008 04:52:11
Message: <4938f9cb$1@news.povray.org>
news:vbhgj4162v9ea6j2oellp0f4vkf5fgrrr9@4ax.com...
> Rats! I was hoping that you knew how to change the gravity in the clothes
> room.
> If that were possible then it would add some flexibility when using
> different
> frame rates in the final render (in Pov), I think.
Well... I suppose I take my wishes for reality :-)  Still, strangely enough,
there is something gnawing at the back of my mind. Kind of hunch...
Date: 5 Dec 2008 05:20:00
Message: <web.4938ffd47ecbb3382f5b7da70@news.povray.org>
> OK let me try. I may forget something but others will correct me.
> Daz, as you know, comes free. That is its major asset I believe, in the
> world of figure building and animating. It comes too with a set of free,
> basic, figures, some with morph possibilites, some very basic conforming
> clothes, and a set of 3D environments. Most everything else, if you want to
> expand, and you want very soon to expand (making/adding hair, clothes, etc)
> comes at a price. These are not very expensive, but in the end I believe you
> will spend more money in perfecting Daz than by investing initially in Poser
> and go on from there.
Interesting. I didn't know about DAZ. When I get the time, maybe I will try to
create bones for LDraw figures so that they can be posed like they are in many
Lego software. (This is one of the major disadvantages of LDraw.)
-Mike
Date: 5 Dec 2008 05:21:42
Message: <440ij4t2be4u32oleoqnpsbtfd1ff4j7gs@4ax.com>
On Fri, 5 Dec 2008 10:52:11 +0100, "Thomas de Groot"
>> room.
>> different
You make me think O_O
Maybe changing the animation frame rate in Poser will change the gravity
setting(?).
The higher the frame rate the lower the gravity. Does that make sense?
I'll do some testing after I've finished my current animation.
Regards
Date: 5 Dec 2008 11:30:56
Message: <49395740$1@news.povray.org>
Stephen wrote:
> On Thu, 4 Dec 2008 16:21:35 +0100, "Thomas de Groot"
>> Ah yes, good question. The real playground with gravity is by using Poser
>> Physics of course, as you know.
> Rats! I was hoping that you knew how to change the gravity in the clothes room.
> If that were possible then it would add some flexibility when using different
Change the cloth density. It can effectively change the gravity down to
almost zero.
FlyerX
Date: 5 Dec 2008 12:15:14
Message: <vboij4pnqmo350boson10seldt9tmcnkup@4ax.com>
>almost zero.
Cloth density is one of the parameters that I have difficulty using. Where can
you find which cloths weigh what? The gsm of cotton is easy to find but other
materials are more difficult :(
Later I will experiment.
Thanks for the suggestion, FlyerX.
Regards
Date: 5 Dec 2008 13:25:06
Message: <web.493971ae7ecbb3388ab7c9350@news.povray.org>
Here's another question: if I were to create the bones and keyframes using one
of these tools, could I then export the animation data back into POV?
-Mike
Date: 6 Dec 2008 04:00:33
Message: <493a3f31$1@news.povray.org>
news:vboij4pnqmo350boson10seldt9tmcnkup@4ax.com...
>>almost zero.
> can
> other
Knowing what a cloth weights is not enough as you have to translate that
info somehow to Poser parameter values. Also, I find that the density
settings work better in *reverse*! What I mean is: *high* density results in
a *light*  cloth behaviour; *low* density results in *heavy* or *stiff*
behaviour. Very weird...
I think this tutorial page will help:
http://my.smithmicro.com/tutorials/2313.html but see also the other pages.
Very helpful.
Date: 6 Dec 2008 04:59:25
Message: <77jkj41q4agg2edom6aedf9eefff1g8s62@4ax.com>
On Sat, 6 Dec 2008 10:00:33 +0100, "Thomas de Groot"
>Very helpful.
Thanks, Thomas that looks very useful. A good starting point.
Regards
