POV-Ray : Newsgroups : povray.text.scene-files : fish_with_pipes.zip Server Time
1 Jul 2025 14:39:39 EDT (-0400)
  fish_with_pipes.zip (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: fish_with_pipes.zip
Date: 8 Mar 2023 00:25:01
Message: <web.64081bb690d041e2a30d213ddabc9342@news.povray.org>
yesbird <sya### [at] gmailcom> wrote:
> On 08/03/2023 08:09, Mike Miller wrote:
> > Fish underwater blob topo with pipes and flanges.
> > Needs a bit of cleanup to remove some parsing errors.
> > Mostly a material and scene idea study.
> It's seems to me that attachment missed.
> YB
Yep...had to resample the bitmaps. Posted a new file. Should be on its way. :)
Date: 8 Mar 2023 00:40:00
Message: <web.64081f2290d041e2a30d213ddabc9342@news.povray.org>
> YB
Also, a bit of warning.
The 'populate' macros are slow to process with the amount of objects I'm using.
Not well optimized - could us some type of culling to remove unseen plants.
The random scale factor needs tweaked. I messed it up but like the size
variations, so I left it for this rendering. :)
Date: 8 Mar 2023 02:11:01
Message: <a7b55eb3-40c9-3754-a25e-02672ad5612d@gmail.com>
I will think about it, some optimization is always necessary.
Write now I can suggest bounded_by:
https://wiki.povray.org/content/Reference:Bounded_By_Object_Modifier
if you still not using it. It's very effective for the scenes with large
amount small objects with complex shapes.
YB
Date: 8 Mar 2023 05:10:00
Message: <web.64085e4290d041e29b4924336e066e29@news.povray.org>
> ..some optimization is always necessary.
It's possible that certain versions of POV-ray mistakenly remove any manual
bounding shapes that a user adds. I remember reading something about this in old
newsgroup posts, but I am not knowledgeable on the subject. Maybe someone else
can give a more definitive answer?
Date: 8 Mar 2023 06:25:00
Message: <web.6408703a90d041e21f9dae3025979125@news.povray.org>
I tried something like this - I determined what the view frustum was, and then
IIRC did some my own home-brew insidedness tests.
http://news.povray.org/povray.binaries.images/message/%3Cweb.587ce70b1652a4dcc437ac910%40news.povray.org%3E/#%3Cweb.587
- BW
Date: 8 Mar 2023 09:00:00
Message: <web.640894a590d041e2a30d213ddabc9342@news.povray.org>
87
> - BW
Thanks BW.
I like that idea - using the cameras frustum shape for an inside/outside test.
Using the cameras' hither and yon planes for space partitioning. BSP?
Date: 8 Mar 2023 10:41:32
Message: <6408acac$1@news.povray.org>
Op 8-3-2023 om 14:59 schreef Mike Miller:
> 87
>> - BW
> Thanks BW.
In another age, long, long ago early in this century, Gilles Tran wrote
a macro doing just that. I have always used it since then. I attach it
here. I must have a demo scene somewhere too... I shall try to find it
tomorrow.
Note: The prefix GT_ is a code referring to the original author. It is a
way I use to remember who wrote the code ;-)
Download 'gt_visibilitytest.mcr.txt' (2 KB)
Date: 8 Mar 2023 11:40:00
Message: <web.6408b9e290d041e2a30d213ddabc9342@news.povray.org>
b.5
> > 87
> >> - BW
> > Thanks BW.
> tomorrow.
> Thomas
Thanks Thomas. Very nice - big help.
Objects not seen by the camera but reflecting in visible surfaces could present
a problem. I guess you could 'add-back' objects not seen but within a distance
of the frustum - if that object type was important to the reflections in the
view.
Mike.
Date: 8 Mar 2023 13:45:00
Message: <web.6408d6bf90d041e21f9dae3025979125@news.povray.org>
> Thanks BW.
Nope.  I'm currently too ignorant and unskilled to implement a BSP.  ;)
IIRC, it was just a check to see which side of the 6 planes that bounded the
View Frustum the selected point was on.  Simple.  Fast.
I suppose there might be a way to convert the frustum into a signed distance
function (SDF) and do it that way.   It would be slick, and then you'd have the
distance calculation integrated into each check as well.
- BW
Date: 9 Mar 2023 02:55:35
Message: <640990f7$1@news.povray.org>
Op 08/03/2023 om 17:37 schreef Mike Miller:
> view.
> Mike.
Indeed. It does not happen often, but then... ;-)
Found the demo. Attached (the macro is written out in the scene again;
can be replaced by a call to the external macro file of course).
Download 'gt_visibilitytest.pov.txt' (5 KB)
