POV-Ray : Newsgroups : povray.text.scene-files : negative strength blobs Server Time
13 Sep 2025 17:13:49 EDT (-0400)
  negative strength blobs (Message 1 to 7 of 7)
Subject: negative strength blobs
Date: 23 Feb 2023 01:25:00
Message: <web.63f706167d062486a30d213ddabc9342@news.povray.org>
POV scene file using negative strength blobs to form cavities within the blob
definition.
Mike
Download 'blob_neg_pos.pov.txt' (7 KB)
Subject: Re: negative strength blobs
Date: 23 Feb 2023 09:35:51
Message: <63f779c7$1@news.povray.org>
> definition.
> Mike
Using current POV-Ray, max_intersection is pretty much obsolete.
Then, you should use assumed_gamma 1, and set file gamma to sRGB. That
should be the default value.
No issue with lowering the ambient_light multiplier.
New with version 3.8 :
In the camera, the right vector now defaults to the aspect ratio of the
output image and can be omitted.
In the finish, with fresnel on, you need an interior statement setting
the IOR to something different than 1. Otherwise, there will be NO
reflection at all. In the present case, for M_gold_paint, using
reflection{.2 .5 metallic} would be a better option.
Then, redefine your floor like this :
//--- floor with fresnel reflection
plane { <0,1,0> 0 material{M_floor_paint}
	interior{ior 1.5}
conserve_energy only work with transparent pigments. In this scene, it
have no effect as there are no transparent pigment.
Happy and good poving
Date: 24 Feb 2023 15:15:00
Message: <web.63f91a171817a14aa30d213ddabc9342@news.povray.org>
> > definition.
> > Mike
>  interior{ior 1.5}
Thanks. I'll clean that up. Sorry, some of this is carry over from old files and
ignorance. :)
is there an output flag for sRGB? thx
Date: 24 Feb 2023 15:50:50
Message: <63f9232a$1@news.povray.org>
>>> definition.
>>> Mike
>>   interior{ior 1.5}
> ignorance. :)
Now, by default, POV-Ray output is of the .PNG format and include the
information telling that the image should get displayed in the sRGB
colour space. You don't need to change anything.
File gamma default to sRGB unless you change it.
Date: 25 Feb 2023 08:00:00
Message: <web.63fa04721817a14aa30d213ddabc9342@news.povray.org>
> >>> definition.
> >>> Mike
> >>   interior{ior 1.5}
> > ignorance. :)
Got it, thanks.
Also, I there a way to capture an 8 bit alpha channel in rendering?
Creating a matching scene with matt objects, no lights, rendered against a
white BG is an option. I guess you could use that method with white fog to get a
'sudo' depth of field image.
Thanks for all your help!
Date: 25 Feb 2023 08:10:00
Message: <web.63fa079d1817a14a816b7cd96cde94f1@news.povray.org>
hi,
<https://wiki.povray.org/content/Reference:Image_Map#The_Filter_and_Transmit_Bitmap_Modifiers>
<https://wiki.povray.org/content/Reference:File_Output_Options>
regards, jr.
Date: 25 Feb 2023 11:05:00
Message: <web.63fa30461817a14aa30d213ddabc9342@news.povray.org>
"jr" <cre### [at] gmailcom> wrote:
> hi,
> regards, jr.
I skipped right over the 'background' filter when looking in the help files.
Excellent - forgot about the wiki. Great help.
....and sorry about typos. :)
