POV-Ray : Newsgroups : povray.text.scene-files : Tangents between circles Server Time
7 Apr 2026 12:34:11 EDT (-0400)
  Tangents between circles (Message 11 to 19 of 19)
Subject: Re: Tangents between circles
Date: 30 Nov 2019 07:10:00
Message: <web.5de25bdc1b345bf5feeb22ff0@news.povray.org>
hi,
"Leroy" <whe### [at] gmailcom> wrote:
> "jr" <cre### [at] gmailcom> wrote:
> > your code ...
> I need to clean it up a bit.
>  Right now I have several POV files. A few for placing and making pulleys and
> then of course the mesh belt.
>  I've been thinking of making a pulley belt system along the lines of Eagle
> started. The trouble with pulleys is that they really start with the
> belt/rope/chain they use. I've been playing with the standard V belt. There is a
> lot of files! I got to go to work Now. So I'll just drop a few here to make a
> mesh belt.
problem.  'V8dat.inc' is missing, so there's no 'Bpnts' array.  commented out
the 'Macs.inc' include too, what do you need that for?
regards, jr.
Date: 3 Dec 2019 16:20:01
Message: <web.5de6d1601b345bf5a564c1c0@news.povray.org>
just a little test sample while I clean up things
Download 'motor2.mp4.mpg' (77 KB)
Date: 4 Dec 2019 06:10:01
Message: <web.5de793031b345bf5feeb22ff0@news.povray.org>
hi,
natty.  made me think of a film projector.  :-)  what if the belt was replaced
with .. transparencies and a light shone through.  should work, no?
looking forward to seeing how it's done.
regards, jr.
Date: 9 Dec 2019 18:45:01
Message: <web.5deedbdf1b345bf54eec112d0@news.povray.org>
Current full WIP for your perusal.
In all it's glorious chaos.
I haven't worked much on this recently because I got sucked into hounding like a
dozen people about info on SVD, and so far I haven't gotten much except annoyed
and maybe a headache.    I think I do have some ideas - I just need to get some
time to hammer out some test code, etc.   Somehow I always have insights when
I'm trying to sleep, rather than when I'm in front of the keyboard.   :|
Download 'serpentinebeltprism_dev1.pov.txt' (44 KB)
Date: 10 Dec 2019 02:33:55
Message: <5def4a63$1@news.povray.org>
Op 10/12/2019 om 00:42 schreef Bald Eagle:
Ha! /That/, is a quite common phenomenon indeed. ;-)
Date: 26 Dec 2019 19:55:00
Message: <web.5e05550e1b345bf58c662f470@news.povray.org>
hi,
sorry for the delay, not forgotten, just occupied with fussing over a new
machine.  :-)  plus RL stuff.
phew, and I'm floundering..  :-(  cannot see how you've arrived at the data in
'CircleArray' elements 6 + 8/9.
(part of the confusion is that calculations and representation are so
intertwined, like when you use a colour ([n][6]) to select a tangent.  and what
is special about the order of indices in 'TangentList'?)
ideally, I would like only to input, per circle, centre, radius, and
(counter)clockwise direction.  choice of tangents and which part of
circumference to draw should be derived.
for instance, say three small circles forming a "nice" triangle.  if all three
run clockwise, it should render a triangular shape with rounded corners, but if
they run counterclockwise the triangle should have cut-out corners (bit like a
jigsaw piece).  iiuc, "inner tangents" would come into play when the next
circle's direction is the opposite of the current.
well, that is the idea(l).  Q - can you provide guidance, please?
this is just for drawing prisms, getting an understanding, really; ignore
pulleys for now.
and one more question, a prism made using just two circles, will that be doable
(wrt comment above 'ArrayIsLinear')?
thanks.
(the program working to satisfaction now, I take it)
regards, jr.
Date: 26 Dec 2019 20:20:00
Message: <web.5e055c201b345bf54eec112d0@news.povray.org>
An initial circle array should have everything defined with _All or _Both to
render a starting image to starting picking tangents and arcs.
All of the calculations should be nice and neat and tidy in the upper part of
the scene file. BezierArcs and analyticalTangents
The TangentList array takes the [named] numerical values that you use to select
the colored tangent lines and "converts"/indexes that to which tangents in the
AnalyticalTangent macro output array they correspond to.
I had this idea in mind - but it's never going to be quite that simple, and the
logic involved in doing that ---- it's going to be challenging.   I had started
to look into serpentine belt design software to see if I could deivine some
rules or see some code ---- but that is a LONG tangent [sic] that I thought best
not to pursue.  "Get the PRISM rendered." was the goal - and that took a mighty
effort.
Well, you'd have to flowchart it out and see what happens.  What happens if the
circles aren't laid out in the array just like that?  What happens if they
overlap or one is inside the other (just by mistake).  How do you determine
which tangent is the "outside" one - to give you the intended, desired "convex
hull" truncated/rounded triangle that we're talking about?  That seemed like an
unnecessary mountain to climb over.
> pulleys for now.
That was the idea.  I put that in there when considering just that - but I don't
know if I tested that out and saw if it worked properly or not.
Got some residual holiday / RL stuff to get out of the way and hopefully I willl
have a block of uninterrupted time and enough of an energy spurt to make another
meaningful contribution to this.
I would also like to see what Leroy has come up with - I'm not sure if his stuff
only runs under Windows or what...
Date: 26 Dec 2019 21:45:01
Message: <web.5e056fc91b345bf58c662f470@news.povray.org>
hi,
ah, that is multi-pass.
they are, and I've abstracted the "do work" macros in an .inc.  still 700+ lines
remaining after.  :-)
in other words, the values index the 'LastTangent' + 'CurrentTangent' arrays?
> effort.
from my (obviously) naive point of view, I thought re overlap, the circles are
in a plane and overlap can be calculated given centres and radii are known.  in
a macro, that would be part of checking the arguments beforehand.  wrt
determining which tangent, it should be selected from the combination of
respective directions and centres; I assume that one can deal in "quadrants" and
perhaps use some pre-calculated lookup table?
I suspect the climbing over is worth it though, given the existing "toolbox" of
macros.  you've done most of the sweat-work, now it's more (re)organising code
and writing "wrappers".
ok.
yeah, he posted a "teaser" (ie some core (array) missing).  I think it's an
..inc, anyway, too will have a look in the next few days or so.
regards, jr.
Date: 27 Dec 2019 20:05:01
Message: <web.5e06a9cf1b345bf54eec112d0@news.povray.org>
Right.  The idea was to have all of the rounded parts in place, the macros puked
out every possible tangent, and then you picked which one you wanted.
Right.  So if you follow the renders in the earlier development posts, you can't
really pick an arc until 2 tangents are picked.  Then one those two tangent line
endpoints are defined, you can then pick one or the other arc connecting the
two.
I think I already did that part and output some stuff to the debug stream.
There are also some flags that get set/unset to skip over nonexistent tangents
that would throw an error in the calculations.
> wrt
I don't really know what you mean.  I'd need pictures or something.  It would
probably be easy if all of your circle centers were describing a convex hull,
but once you get a concave spot, then it gets super tricky.
Just calculate a "centroid" of sorts by averaging all the center coordinates,
and pick which external tangent based on which endpoint is farthest away from
the centroid.
I just downloaded it, and haven't extracted the file to see what it is.
