POV-Ray : Newsgroups : povray.text.scene-files : bounding box calculator Server Time
21 May 2024 13:51:39 EDT (-0400)
  bounding box calculator (Message 11 to 20 of 43)
Subject: Re: bounding box calculator
Date: 3 Nov 2019 09:50:00
Message: <web.5dbee8a834d8ef064eec112d0@news.povray.org>
> >> ... I wrote a macro which "scans" an object's BB ...
> > find attached an updated version of 'Bounder'.
So - those are pretty impressive differences between what POV-Ray does and what
you trim it down to!  :O
The methods I suggested are probably too complex to see any implementation any
time soon, but maybe if someone who reads and translates c++ or other languages
into SDL faster (and more accurately) than I can, converts a script or two -
then it would be a powerful tool for this as well as point clouds and other
tasks.
I doubt they'd be included into source - but I can dream a little.
I'm curious about how your BB compares to the native one aside from just size.
Does it shift?
Does the center move?  Is the space on either side equal for all 3 axes?
Presumably your bounding box is TIGHT - if you difference away an inverse box,
do you get points of overlap / coincident surfaces?
I'm just wondering if you ought to include a tiny buffer of 2x10E-6 or whatever
the safe distance is on either side, depending on usage.
Maybe have a switch in the macro call to omit or include that buffer space.
Perhaps an interesting addition would be to add an animation .ini file that
rotates the CSG object around an axis by some fraction of 45 degrees and then
does the analysis - to see if the _AA_BB gets any smaller.
Pretty nice work, and a striking demonstration of how much empty space an
automatically generated bounding box can have.
I knew there was some, but:   WOW.
I can see this being really useful for BB dependent operations like scanning
with trace (), and probably a few others that I can't clearly envision at the
moment.  Basically anywhere that a lot of ray-object intersections need to be
tested.
This is solid.
Date: 3 Nov 2019 10:45:00
Message: <web.5dbef50034d8ef06feeb22ff0@news.povray.org>
hi,
agree.  for the Boy's Surface which got me going, the BB went from 11^3 units to
8.2^3, a reduction of well over 50%.
> tasks.
as I wrote, I'm game for collaboration.  if you can express the spherical
bounding you're thinking off as "pseudo code" at least, I'm sure we could work
on something.
> Does it shift?
the algorithm goes something like this, for each axis:
  - using the resolution, work out the required axis scan increments.
  - work along the scan axis until you hit the object:
    - scan the "face" looking +axis.  if no inside() test succeeded, remember
      that face as outside.
    - scan the "face" looking -axis.  as above.
the advantage is that the last stored coords are always outside of the object.
the art, I guess, will be finding the lowest resolution "good" for the object.
(low res like for the Boy's Surface wouldn't work for, say, a model of a sea
urchin, where one would presumably miss many of the spikes)
the 'Bounder' is only meant to give you (the user) guide figures, by up to which
you can tighten the BB if useful.
that's an interesting thought, re-orienting the object.  need to think about
that.
yeah, Thomas's "reference"-style image did that for me too.  :-)
> tested.
gut feeling: scenes with a number of CSG shapes with "difficult" materials, like
glass, will benefit.  also, after a first glance, 'blob' shapes too look like
good candidates.
> This is solid.
merci bien.
regards, jr.
Date: 3 Nov 2019 12:45:00
Message: <web.5dbf11d834d8ef064eec112d0@news.povray.org>
> on something.
See below (*)
That sounds like something that one of those space-partitioning algorithms might
be useful for.
On the other hand - if the primitives are mathematical equations, then in thory
one should already know where the object is, and this searching in the dark with
rays is not the way to go.
How _exactly_ to do it differently might be why people have taken to ray
marching instead of raytracing.
I think we could use a hybrid to speed up the initial search with a ray march
type phase, and then do the fine tuning / final result with the ray tracing.
> that.
(*)  Well that's what I was getting at with the ellipsoid and the rotating
calipers.
Right now, you can imagine the the bounding box is determined in a very
hands-off kinda way.   If you took a book that was not axis-aligned, and
squeezed it with axis-aligned calipers, it would "straighten out" until it was
aligned with the minimal width parallel to the axis of measurement.
Of course, we can see how difficult it is for POV-Ray to even do the plain old
hands-off AABB determination, so how does one mathemagically determine not only
the bounding box - but one that is the tightest fit, given that the object may
be "UNaligned"?
The answer to that lies in what I envisioned, and has been worked out and
implemented by those clever people out there.
It has to do with analyzing the orientation of the vectors - the trace ()
results that you get from your "scan".
So, just think about how you'd center an off-axis sphere.
You'd add up the vectors to get an average, which would be the off-axis center
of the sphere, and then translate that in the opposite direction in order to
place it at the origin.
So far so good.
If we have a non symmetric shape, however, we need to also rotate it so that the
minimum widths (if there is one) are along the cardinal axes.
So now we just look for rotational fixes rather than a translational one.
Don't get bogged down in the details.  Just think about it like a linear
regression or a curve-fitting thing on a calculator or in a spreadsheet.
It works, it's used _all the time_ everywhere, from IQ scores to search engine
results, to Facebook and Twitter ranking algorithms, to product and video
suggestions, to facial recognition and machine learning.
The way to do this, unfortunately, or perhaps fortunately, is with matrices.
And I always return to these, I guess because they are so fundamental to what we
do with computer graphics and solid geometry.
So the gist is,
1. we enclose the CSG thing in a bounding sphere.
2. we then shrink an axis of the sphere until we touch the CSG
     but the narrowest part may not be on a principal axis,
     so we just do it until we get whatever axis is the narrowest way
     we can do it.
3. do that to the remaining axis (because the original sphere is already
     defined by the largest axis of the final ellipsoid
4. Now look at the rotation of those ellipsoidal axes and align them
     with x, y, and z
But it's accomplished in a much more straightforward manner using the raw
vectors.
This goes by many names, but I found Singular Value Decomposition (SVD)
but I guess there's Principal Component Analysis (PCA), Eigen Value
Decomposition, etc.  Which can be different but are more or less equivalent and
are often used interchangeably.
Over here (1/4 to 1/3 of the way down):
https://blog.statsbot.co/singular-value-decomposition-tutorial-52c695315254
he says, "Suppose we have two, two-dimensional vectors, x₁=(x₁,
y₁), and x₂=(x₂, y₂). We can fit an ellipse with major
axis, a, and minor axis, b, to these two vectors as shown in the figure."
And then look here at the 7:00 mark:
https://www.youtube.com/watch?v=_4jaLZCoLPI
https://www.youtube.com/watch?v=PFDu9oVAE-g&list=PLZHQObOWTQDPD3MizzM2xVFitgF8hE_ab&index=14
So apparently there are libraries that exist to do this reliably, and maybe just
a c++ script could be run to analyze the data and then spit out the rotation
vectors for POV-Ray to use in the scene.
Or some maniac could convert it to SDL just for funsies.
(This is usually where TOK pops in and mentions that he coded this on a lark way
back in 2004 and didn't think anyone would be interested or find it useful or
something...  ;)  )
"This is crazy, Bill."
(No it's not, Thomas - the dried frog pills are _working_!!!)
Well, yes - and no.  Because I can already see an application to your sphere
slicing troubles in POV-Ray, the existing root-finding problems that Bill
Pokorny is grappling with, and SVD.
If the problem with your sphere slicing arises from root-finding troubles that
POV-Ray experiences when trying to solve for rays that are parallel, or nearly
so, to the object surface, then maybe if you added a "wiggle" to the object,
solved for the root, and then unwiggled the intersection before rendering the
result - then you'd get better renders with less holes.
So if we implemented it in source - them maybe it could be applied to solve a
lot of long-standing, underlying problems.  Or something like it.
Essentially, why look at it parallel, when you could rotate it 90 degrees, look
at it perpendicularly, and then rotate it back.  I don't know if that possible
or realistic in the forest of the source code, but it's not far off from the
camera pigment function {} stuff that he's proposing.
So right now, I'm working off of this:
https://github.com/minillinim/ellipsoid/blob/master/ellipsoid.py
and this:
https://www.codeproject.com/Articles/1268576/Singular-Values-Decomposition-SVD-In-Cplusplus11-B
and one of the popular libraries used for this kind of thing is:
https://github.com/opencollab/arpack-ng
It's also available in numpy
https://towardsdatascience.com/pca-and-svd-explained-with-numpy-5d13b0d2a4d8
https://stats.stackexchange.com/questions/159325/what-fast-algorithms-exist-for-computing-truncated-svd
"All reasonable programming languages and statistic packages (Matlab, R, Python
numpy, you name it) use the same Fortran libraries to perform
eigen/singular-value decompositions. These are LAPACK and ARPACK. ARPACK stands
for ARnoldi PACKage, and it's all about Arnoldi/Lanczos iterations. E.g. in
Matlab there are two functions for SVD: svd performs full decomposition via
LAPACK, and svds computes a given number of singular vectors via ARPACK and it
is actually just a wrapper for an eigs call on the "square-ized" matrix."
Date: 3 Nov 2019 13:00:01
Message: <web.5dbf14f934d8ef064eec112d0@news.povray.org>
> on something.
So the issues I'm running into currently, are that SDL doesn't have the syntax
needed to replicate statements in python or c++, or POV-Ray simply doesn't have
the ability to perform certain of the operations.
So I need to interpret certain statements to first even understand what they do,
http://news.povray.org/povray.programming/thread/%3Cweb.5db79f027e60be924eec112d0%40news.povray.org%3E/
and then rewrite those parts in a way that can be performed in SDL.
for (std::uint32_t row = 0; row < m_size && (index % 100) == 0; row++)
m[row].resize(m[row].size() + 100);
etc.
That's why I figured using the existing, working, tested libraries in c++,
python, Fortran, Ruby, R, Matlab, etc. would be fastest and most reliable.
I mean I could be wrong, but I think it would pay dividends.
And I still can't understand why the value of the FFT isn't understood.  ALL of
the major graphics packages use FFT for myriad effects, edge detection, etc...
Date: 3 Nov 2019 13:35:00
Message: <web.5dbf1ce734d8ef06feeb22ff0@news.povray.org>
hi,
> > on something.
unfortunately I'll not be much help there, I do not speak c++ nor python.
however, the SDL is Turing complete aiui.  (though too cumbersome for all sorts
of stuff)
> etc.
what is it you're doing that requires a row to grow?
back to the subject on hand.  the problem would be having to scan points on the
surface of a sphere, with some precision/resolution, followed by consecutively
smaller spheres, until "contact".  what did I miss?
regards, jr.
Date: 4 Nov 2019 03:09:16
Message: <5dbfdcac$1@news.povray.org>
Op 03/11/2019 om 16:40 schreef jr:
> hi,
>> tasks.
> on something.
>> Does it shift?
> that.
>> tested.
> good candidates.
A few thoughts derived from this.
- rotating the object changes the 'tightness' of the standard BB. I did
that with a simple cylinder: when properly aligned along one of the
axis, the BB test is always optimal; rotate the cylinder (e.g.
<45,45,45>) and do the test, and the standard BB becomes too wide.
- the test is also useful with hyperboloid, superellipsoid, and
isosurface objects. Quartic and parametric objects do no comply,
probably they are not 'solid'? I did not test this thoroughly.
- I include the test scene file for you to play with.
Download 'utf-8' (9 KB)
Date: 4 Nov 2019 07:30:00
Message: <web.5dc018f534d8ef06feeb22ff0@news.povray.org>
hi,
need to let this info .. stew :-) for a while.  looks like BE's idea of an ini
driven animation to explore the possible orientations and post-process results
is a way to go.
great news.  I'd initially assumed the macro would be a .. single trick pony,
only good for CSG.
thank you v much for this.  not only do I get those natty presentation settings
:-), but looking at the code I surmise you replaced the 'local's of the
difference vectors with 'declare's?  that's given me another idea for an
improvement: create two variables, 'Bounder_{min,max}_diff' and export
('declare') them for in-scene use.  thoughts?
regards, jr.
Date: 4 Nov 2019 07:30:01
Message: <web.5dc018fe34d8ef06feeb22ff0@news.povray.org>
hi,
> > on something.
> > that.
> calipers.
off the top of my head, write out the points/vectors to a CSV format file, then
either use your spreadsheet-fu or describe the the necessary actions in kinda
pseudo code so we can discuss whether/how to implement as a script/compiled
utility.
quick viewed the vids.  agree with 3Blue1Brown that "confusion" arises from
having a "shaky" understanding of the basics.  :-)  (although a frown would be
more appropriate)
so, anything .. matrix you'd have to work through with me -- bite size.
chorus: "Oh no, they're not."  :-)
I can "see" the concept, and like it.  potential problem: registration, to get
exact re-alignment.
I'm working myself up to trying Bill P's custom POV-Ray soon.  but yes, support
in the program source sounds like the way forward.
regards, jr.
Date: 4 Nov 2019 09:10:00
Message: <web.5dc0308d34d8ef06feeb22ff0@news.povray.org>
d'oh!  finally got the "why".  :-)  with yr permission will add the calculator,
also will adopt the "proper" labelling in existing output.  thanks.
regards, jr.
Date: 4 Nov 2019 14:05:00
Message: <web.5dc0759f34d8ef064eec112d0@news.povray.org>
> is a way to go.
The ini was just to showcase what you've got and point out that the initial
object orientation might not yield the tightest bounding box possible.
As a tool, I'd probably do some sort of iteration with loops, first fixing one
axis, then another, then another, and then checking to see if there's any
improvement on a second go-'round.  If there is, repeat, if not, all done.
> only good for CSG.
Great job Thomas - those results are surprising, given the absolute mathematical
nature of those shapes.
I would have imagined that with something like a parametric, you'd be able to
cycle through u and v real quick, and get a min and max value for each axis to
use for the AABB dimensions.   I'm also still completely mystified as to why the
parametric is such a slow-to-render object, and why the triangle approximation
isn't a source-coded native primitive.
