POV-Ray : Newsgroups : povray.text.scene-files : test blob media for potential pattern Server Time
10 Dec 2025 06:33:17 EST (-0500)
  test blob media for potential pattern (Message 1 to 2 of 2)
Subject: test blob media for potential pattern
Date: 13 Oct 2016 16:40:01
Message: <web.57fff0f3d36b3cadb1933f770@news.povray.org>
/* testing 'potential' pattern for blob object
   reason for patch was for reflection blur
   didn't realize potential pattern was not part of unofficial (yet?) */
// cmd: +w320 +h240 +a +ki0 +kf1 +kfi1 +kff50 +sf14 +ef14
#version 3.71;
//#version unofficial patch 3.71;
//#patch "upov-reflection-roughness" 0.9;
global_settings
 assumed_gamma on
 max_trace_level 9
#declare Blur=no; // camera focus/defocus
#declare CutOut=no; // cut away part of blob with box
#declare Sturm=on;
background
 rgb 0
sky_sphere
 pigment
  function
   abs(y)
  color_map
   [0 rgb <0.9,0.4,0.1>/2]
   [0.3 rgb <0.3,0.5,1>/2]
   [0.9 rgb <0.2,0.4,0.9>/2]
  //turbulence 0.8
light_source
 -99*z, 1
 media_interaction on
 media_attenuation off
 rotate <60,-30,0>
camera
 location -9*z
 look_at <0.75,0.5,0>
 angle 50
 #if (Blur=yes)
 focal_point 0
 aperture 0.6
 blur_samples 30,60
 variance 0.005
 rotate <22.5,22.5,0>
// floor
box
 <-9,-4,-9>,<9,-3,9>
 pigment
  checker rgb 1 rgb 0
// reflective ball
sphere
 0,3
 scale <1,1,0.25>
 rotate <0,60,0>
 translate <4,0,1>
 material
  texture
   pigment
    rgb 0.4
   finish
    diffuse 0.1
    reflection
     0.2,0.8
     //roughness 0.05
// blob with media
#if (CutOut=yes)
difference
blob
 sphere
  <-1,-1,0>,1,2
 sphere
  <-1,1,0>,1,2
 sphere
  <1,1,0>,1,2
 sphere
  <1,-1,0>,1,2
 sphere
  0,1.5,1
 cylinder
  -x*(1+sin(clock*2*pi)),x*(1+sin(clock*2*pi)),0.75,2
 cylinder
  -y*(1+sin(clock*2*pi)),y*(1+sin(clock*2*pi)),0.75,2
 cylinder
  -z*(1+sin(clock*2*pi)),z*(1+sin(clock*2*pi)),0.75,2
 sturm
#if (CutOut=yes)
box
 <-1.75,-1.75,-1.5>,<1.75,1.75,0>
material
 texture
  pigment
   potential
    blob
     sphere
      <-1,-1,0>,1,2
     sphere
      <-1,1,0>,1,2
     sphere
      <1,1,0>,1,2
     sphere
      <1,-1,0>,1,2
     sphere // center
      0,1.5,1
 cylinder
 cylinder
 cylinder
 #if (Sturm=on) sturm #end
    } // blob
   } // potential
   threshold on
   color_map
    [0 red 1 transmit 0.99] [0.5 green 1 transmit 0.99] [1 blue 1 transmit 0.99]
  } // pigment
 } // texture
 interior
  media
   method 3
   samples 33
   jitter 0.9
   emission 0.4
   absorption 0.1
   scattering
    1, 0.6
  density
   potential
    blob
     sphere
      <-1,-1,0>,1,2
     sphere
      <-1,1,0>,1,2
     sphere
      <1,1,0>,1,2
     sphere
      <1,-1,0>,1,2
     sphere
      0,1.5,1
 cylinder
 cylinder
 cylinder
    } // blob
   } // potential
   threshold on
   density_map
    [0 red 1] [0.5 green 1] [1 blue 1]
  } // density
  } // media
 } // interior
} // material
rotate <0,clock*360,0>
hollow on
} // difference or blob
Subject: Re: test blob media for potential pattern
Date: 14 Oct 2016 02:30:01
Message: <web.58007af9302fb87eb1933f770@news.povray.org>
sorry, there's another thing I noticed looking at the scene file I have and had
put here.
sturm keyword was left by itself in the first blob statement. Sturm was intended
to also have the #if directive line same as those for the pigment and density
statements.
Please be aware sturm needs to be left out for a cleaner render, otherwise you
will see bad artifacts.
On another note, I am trying a pre-declared instance of the blob statement and
using it as:
object
 Blob
to replace each full statement. You can easily do the same by cutting and
pasting the first blob {...} portion and #declare Blob= blob {...}
This will work like before, no problem here with:
potential {object{Blob}}
