POV-Ray : Newsgroups : povray.text.scene-files : Ringworld scene Server Time
29 Apr 2024 00:52:03 EDT (-0400)
  Ringworld scene (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Ringworld scene
Date: 7 Feb 2021 02:41:48
Message: <601f99bc@news.povray.org>
Op 07/02/2021 om 02:53 schreef Mike Horvath:
> On 10/13/2013 2:18 AM, posfan12 wrote:
>> Here's the scene file for my ringworld attempt. Any suggestions?
>> Especially on
>> how to make the atmosphere appear?
>> Mike
> Some panoramas:
> http://isometricland.net/panorama/pannellum.htm?config=pano-ringworld-01.json
> http://isometricland.net/panorama/pannellum.htm?config=pano-ringworld-02.json
> Mike
Nicely done indeed. Media should not pose too much of a problem in this
context as you are outside of the atmosphere.
Date: 7 Feb 2021 17:26:09
Message: <60206901$1@news.povray.org>
Well, I am on hour 13 of my current render. About 35% done.
Mike
Date: 8 Feb 2021 02:35:06
Message: <6020e9aa$1@news.povray.org>
Op 07/02/2021 om 23:26 schreef Mike Horvath:
>> this context as you are outside of the atmosphere.
> Mike
I don't know. Just rendering your atmosphere, with a supporting ring
added, took me about 30 seconds. Probably other conditions prevail in
your scene (landscape? cloudscape? shadow squares? area_light sun?)
Date: 8 Feb 2021 03:13:48
Message: <6020f2bc$1@news.povray.org>
Yes, the sun is a 6x6 (probably excessive) area light.
Without the atmosphere the scene takes about 2 hours to render.
Mike
Date: 9 Feb 2021 02:36:21
Message: <60223b75$1@news.povray.org>
Op 08/02/2021 om 09:13 schreef Mike Horvath:
> Mike
I wonder if at that distance an area_light is really effective. A point
light (with parallel) would probably be much faster and without any
visual difference.
Date: 10 Feb 2021 05:29:54
Message: <6023b5a2$1@news.povray.org>
> visual difference.
The area light is necessary to create the fuzzy shadows. (Otherwise
shadows would have a sharp edge and the lighted regions would be larger
than the shadow regions IIRC.)
A 6x6 area light may be excessive though. Dunno.
Mike
Date: 10 Feb 2021 07:20:00
Message: <web.6023ce928a87fb261f9dae300@news.povray.org>
What if you gave the shadow squares a bit of transparency at the edges to allow
the formation of a penumbra on the ring?  It's a cheap cheat, but it may go
WAAAY faster.
Also Martijn just posted this recently:
https://www.shadertoy.com/view/WsyBDz
Date: 11 Feb 2021 02:28:16
Message: <6024dc90@news.povray.org>
Op 10/02/2021 om 11:29 schreef Mike Horvath:
>> point light (with parallel) would probably be much faster and without
>> any visual difference.
> Mike
Ah, yes. Forgot about the shadow squares indeed. I seem to remember now
that I had some trouble of the kind, back when I modelled the Ringworld
(ten years ago? I am not sure)
Date: 11 Feb 2021 11:12:24
Message: <60255768$1@news.povray.org>
> Mike
If using adaptive, that 6x6 become 9x9.
As for using parallel... That would only work for a small part of the
ring.  parallel can't be used when the light_source is surrounded by
shadow casting elements.
Date: 17 Feb 2021 19:37:45
Message: <602db6d9$1@news.povray.org>
> Here's the scene file for my ringworld attempt. Any suggestions? Especially on
> Mike
Latest code can be found here:
https://github.com/mjhorvath/Mike-Wikipedia-Illustrations/tree/master/Miscellaneous/ringworld
Mike
