Here's the scene file for my ringworld attempt. Any suggestions? Especially on
how to make the atmosphere appear?
Mike
Download 'ringworld_new_scaled.pov.txt' (13 KB)
> Mike
Newest version.
http://isometricland.net
Download 'ringworld_new_smaller.pov.txt' (16 KB)
> Mike
Some panoramas:
http://isometricland.net/panorama/pannellum.htm?config=pano-ringworld-01.json
http://isometricland.net/panorama/pannellum.htm?config=pano-ringworld-02.json
Mike
Op 07/02/2021 om 02:53 schreef Mike Horvath:
>> Especially on
>> Mike
> Some panoramas:
> Mike
Nicely done indeed. Media should not pose too much of a problem in this
context as you are outside of the atmosphere.
Well, I am on hour 13 of my current render. About 35% done.
Mike
Op 07/02/2021 om 23:26 schreef Mike Horvath:
>> this context as you are outside of the atmosphere.
> Mike
I don't know. Just rendering your atmosphere, with a supporting ring
added, took me about 30 seconds. Probably other conditions prevail in
your scene (landscape? cloudscape? shadow squares? area_light sun?)
Yes, the sun is a 6x6 (probably excessive) area light.
Without the atmosphere the scene takes about 2 hours to render.
Mike
Op 08/02/2021 om 09:13 schreef Mike Horvath:
> Mike
I wonder if at that distance an area_light is really effective. A point
light (with parallel) would probably be much faster and without any
visual difference.
> visual difference.
The area light is necessary to create the fuzzy shadows. (Otherwise
shadows would have a sharp edge and the lighted regions would be larger
than the shadow regions IIRC.)
A 6x6 area light may be excessive though. Dunno.
Mike
What if you gave the shadow squares a bit of transparency at the edges to allow
the formation of a penumbra on the ring? It's a cheap cheat, but it may go
WAAAY faster.
Also Martijn just posted this recently:
https://www.shadertoy.com/view/WsyBDz
