![](/i/fill.gif) |
From p.b.i, scene file demonstrating my corroded torus. Feel free to modify
and use as you see fit.
-tgq
//START
// Persistence of Vision Ray Tracer Scene Description File
// File: CorTor.pov
// Desc: Corroded torus
// Date: 16/11/06
// Auth: Trevor G Quayle
//#version unofficial megapov 1.1;
global_settings {
assumed_gamma 1.0
ambient_light 1
adc_bailout 0.001
max_trace_level 10
location <0,3,-3>*20
look_at <0,0,0>
#declare LB=
sphere{0 10 hollow no_image
photons {collect off pass_through}
texture{pigment{rgb 1} finish{ambient 25}}
light_source {
<5, 5, -5>*10
color rgb <1,1,1>
looks_like{LB}
light_source {
<-5, 1, -5>*10
color rgb <1,1,1>
looks_like{LB}
light_source {
<0,50,0>
color rgb <1,1,1>
looks_like{LB}
plane {
-y, 0.0 hollow
pigment {rgb 1}
finish {ambient 0 diffuse 0.6}
#declare TexOut= //Chrome texture
texture{
pigment{rgb 1}
finish{
conserve_energy
diffuse 0.0
ambient 0
reflection{0 1 fresnel on metallic 1}
#declare RSteel= //Rust texture
texture{
granite
color_map {
[0.20 rgb <0.89, 0.51, 0.28>]
[0.40 rgb <0.70, 0.13, 0.00>]
[0.60 rgb <0.69, 0.41, 0.08>]
[0.80 rgb <0.49, 0.31, 0.28>]
[1.00 rgb <0.89, 0.51, 0.28>]
normal{
average
normal_map{
[1 granite 1]
[2 granite 1 scale 1/10]
scale 2
#declare axis1=20; //major radius
#declare axis2=5; //minor radius
#declare mm=400; //mesh divisions around major axis
#declare nn=100; //mesh divisions around minor axis
#declare Cor=0.5; //Corrosion amount
#declare FF=function{pigment{granite colour_map{[(1-Cor) rgb 0][1.0 rgb 1]}
scale 15}} //Corrosion function
#declare Thk=0.01; //Thickness of outer material
#declare Tor1=torus{axis1,axis2-Thk}
#declare TorMat=
material{
texture{
object{
Tor1
texture{TexOut}
texture{RSteel}
interior{ior 25}
#declare OS=0.025;
#declare FF2=function(k){abs(pow(k,1)*(1+2*OS)-OS)-OS} //Creates a raised
ridge around corroded spots based on OS value
#macro Pont (m0,n0) //Calculate deformed vertices
#local
Norm=vnormalize(vaxis_rotate(vaxis_rotate(y*axis2,x,n0*360/nn),y,m0*360/mm));
#local
PT=vaxis_rotate(vaxis_rotate(y*axis2,x,n0*360/nn)+z*axis1,y,m0*360/mm);
PT-FF2(FF(PT.x,PT.y,PT.z).gray)*Norm*Cor*3
#declare PTt=array[3][3];
#declare Torus2=
mesh2 {
vertex_vectors {
mm*nn
#declare m=0; #while (m<mm)
#declare n=0; #while (n<nn)
,Pont(m,n)
#declare n=n+1;#end
#declare m=m+1;#end
normal_vectors {
mm*nn
#declare i=-1;#while (i<2)
#declare j=-1;#while (j<2)
#declare PTt[i+1][j+1]=Pont(mod(m+mm+i,mm),mod(n+nn+j,nn));
#declare j=j+1;#end
#declare i=i+1;#end
#declare V1=vnormalize(PTt[2][1]-PTt[1][1]);
#declare V2=vnormalize(PTt[1][2]-PTt[1][1]);
#declare V3=vnormalize(PTt[0][1]-PTt[1][1]);
#declare V4=vnormalize(PTt[1][0]-PTt[1][1]);
#declare N= vcross(V1,V2)*(vlength(V1)+vlength(V2));
#declare N=N+vcross(V2,V3)*(vlength(V2)+vlength(V3));
#declare N=N+vcross(V3,V4)*(vlength(V3)+vlength(V4));
#declare N=N+vcross(V4,V1)*(vlength(V4)+vlength(V1));
#declare
N=vnormalize(N/(2*(vlength(V1)+vlength(V2)+vlength(V3)+vlength(V4))));
,N
#declare n=n+1;#end
#declare m=m+1;#end
face_indices {
mm*nn*2
#declare m0=mod(m-1,mm);#declare m1=mod(m+1,mm);
#declare n0=mod(n-1,nn);#declare n1=mod(n+1,nn);
#declare F1=<m*nn+n,m*nn+n1,m1*nn+n>;
#declare F2=<m*nn+n1,m1*nn+n,m1*nn+n1>;
,F1,F2
#declare n=n+1;#end
#declare m=m+1;#end
normal_indices {
mm*nn*2
,F1,F2
#declare n=n+1;#end
#declare m=m+1;#end
material{TorMat}
object{Torus2 translate <0,axis2,0>}
//END
![](/i/fill.gif) |
