POV-Ray : Newsgroups : povray.text.scene-files : Improvements to Field Camera macro Server Time
14 Dec 2025 16:53:35 EST (-0500)
  Improvements to Field Camera macro (Message 1 to 2 of 2)
Subject: Improvements to Field Camera macro
Date: 5 Jan 2003 06:35:03
Message: <web.3e181719eebaf7c4b29393de0@news.povray.org>
A few days ago I posted a macro which simulated the properties of an
architectural field camera. Following further testing and responding to
comments from friends who have viewed my test images, I have added a scaling
feature that has the effect of correcting the exaggeration of the apparent
vertical height of the objects being rendered. Mathematically, the theory
used seems sound and the results look good to me but YMMV; consequently, I
have put in a switch to turn the rescaling on and off.
Secondly, I have added error trapping to prevent the "divide by zero" errors
that would occur if the camera was to point parallel to the y-axis.
Finally, I haven't tested this but it seems to me that the "transform
{NoFall}" should be the penultimate and the "look_at CamLook" the final
items in the camera definition - especially if you're using "right
If_you_want".
// Don't forget to switch off Vista Buffers by using -uv on the command line
// or Vista_Buffer=0 in your .ini file before attempting to render your
image.
#macro FieldCam (CP, CL, RS)
 #local CD=CL-CP;
 #if (CD.x=0 & CD.z=0 & CD.y<0)
  #error "Your camera is pointing vertically down. Please adjust it."
 #else
  #if (CD.x=0 & CD.z=0 & CD.y>0)
   #error "Your camera is pointing vertically up. Please adjust it."
 #local HypoXZ=sqrt(pow(CD.x, 2)+pow(CD.z, 2));
 #local VCorr=vlength(CD)/HypoXZ;
 #local CosThetaX=CD.x/HypoXZ;
 #local CosThetaZ=CD.z/HypoXZ;
 #if (CD.x=0)
  #local ShearX=0;
 #else
  #local ShearX=(CD.y/CD.x)*pow(CosThetaX, 2);
 #if (CD.z=0)
  #local ShearZ=0;
 #else
  #local ShearZ=(CD.y/CD.z)*pow(CosThetaZ, 2);
 #if (RS=0)
  #declare NoFall=transform {
   matrix <1, 0, 0, ShearX, 1, ShearZ, 0, 0, 1, 0, 0, 0>
 #else
   matrix <1, 0, 0, ShearX, VCorr, ShearZ, 0, 0, 1, 0, 0, 0>
/*********************************USAGE**************************************
#declare CamPos=<Xc, Yc, Zc>;   //Just replace <Xc,Yc,Zc> with location
vector
#declare CamLook=<Xl, Yl, Zl>;  // -"-   -"-   <Xl,Yl,Zl> with look_at
vector
#declare Rescale=N              //N=1 turns rescaling on, N=0 turns it off
 FieldCam (CamPos, CamLook)
 perspective
 location CamPos
 [angle Whatever] // Not essential but can be used
 [right If_you_want] // Also not essential but can be used
 transform {NoFall}
 look_at CamLook
John
Run Fast
Run Free
Run Linux
Subject: Re: Improvements to Field Camera macro
Date: 5 Jan 2003 09:20:04
Message: <web.3e183efc669573dbb29393de0@news.povray.org>
Oops!
>camera {
> perspective
> location CamPos
I've just realised that I left out a bit....mea culpa, mea culpa, mea maxima
culpa.
  FieldCam (CamPos, CamLook, Rescale)
  perspective
etc.......
is how the example should read.
John
Run Fast
Run Free
Run Linux
