POV-Ray : Newsgroups : povray.text.scene-files : Arabesque, take 2 Server Time
16 Apr 2026 15:46:06 EDT (-0400)
  Arabesque, take 2 (Message 1 to 5 of 5)
Subject: Arabesque, take 2
Date: 19 Apr 2001 11:48:25
Message: <slrn9du26b.eie.ron.parker@fwi.com>
In addition to playing with the random seed, try using different (small!)
values for j.
#macro Arabesque2( Param )
  #declare Sd = seed(Param);
  #declare Rv = <rand(Sd),rand(Sd),rand(Sd)>*500;
  #local C=pigment{crackle solid
    color_map{
      [1/12 red 1]
      [1/12 red 1 green 1][3/12 red 1 green 1]
      [3/12 green 1][5/12 green 1]
      [5/12 green 1 blue 1][7/12 green 1 blue 1]
      [7/12 blue 1][9/12 blue 1]
      [9/12 blue 1 red 1][11/12 blue 1 red 1]
      [11/12 red 1]
  #local G=pigment{crackle
    pigment_map{[.05 rgb 0][.05 C]}
    scale .1
    translate Rv
    warp {repeat 2*z flip z}
  radial
  pigment_map{
    #local i=0;
    #local j=8;
    #while(i<j)
      [i/j G rotate(180/j+360/j*i)*y]
      [(i+1)/j G rotate(180/j+360/j*i)*y]
      #local i=i+1;
  warp{repeat .5*x flip x}
  warp{repeat .5*z flip z}
plane {y 0 pigment {Arabesque2(8192)} finish {ambient 1}}
camera {location 3*y sky z look_at 0}
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Subject: Re: Arabesque, take 2
Date: 19 Apr 2001 13:56:54
Message: <3adf26e6@news.povray.org>
> values for j.
Yep.  When you posted the 12 sided thing, I saw exactly what you were doing,
and did this myself.  Kinda fun to try different shapes.  Larger than about
30 and things start to blend out, though.
Geoff
Date: 19 Apr 2001 14:15:48
Message: <slrn9duaqk.kd.ron.parker@fwi.com>
>> values for j.
This one's different, though.  This one has rectangular tiling, where the
other one was hexagonal.  The results are similar, though.
Date: 19 Apr 2001 14:18:41
Message: <3adf2c00@news.povray.org>
>>> values for j.
Ah, I see.  Yeah, neat.  Now do octagons and squares combined. ;)
Geoff
Date: 19 Apr 2001 14:32:02
Message: <slrn9dubp2.kd.ron.parker@fwi.com>
>>>> values for j.
That was what I tried to do with this, but I messed some things up.  Use
the definitions from before for Sd, Rv, and C and try this:
    scale .2
    translate Rv
  #local H=pigment {
    gradient x
    pigment_map {
      [.5 G][.5 G translate -.5*x scale <1-sqrt(2),1,1> translate .5*x]
  radial
  #local i=0;
  #local j=8;
  pigment_map{
    #while(i<j)
      [i/j H rotate(180/j+360/j*i)*y]
      [(i+1)/j H rotate(180/j+360/j*i)*y]
      #local i=i+1;
  rotate 180/j*y
