POV-Ray : Newsgroups : povray.text.scene-files : Re: Twysted source (bug fixed) Server Time
19 Dec 2025 01:05:42 EST (-0500)
  Re: Twysted source (bug fixed) (Message 1 to 10 of 15)
Subject: Re: Twysted source (bug fixed)
Date: 13 Sep 1999 18:11:41
Message: <slrn7toed6.31.meneses@B52.net>
El Sun, 12 Sep 1999 10:27:38 -0500, Larry Fontaine escrivio estos
 fermosos latines:
>//The spike macro:
>//  twyst(1,2,3,4,5,6,7)
>//  1 = Height of spike
>//  2 = Sides on spike
>//  3 = Length of side at base
>//  4 = Rotation between two layers
>//  5 = Radius of rounded edge at base
>//  6 = Spacing ratio (should be almost 1)
>//      formula is height = (1-pow(Ratio,Layer))*Height
>//  7 = Number of layers, not enough will cut the spike short
>//         because of the spacing ratio
Why can't I compile this?
I only can get this error message:
----------8<------------------------8<------------------------8<---------
.............................   object { spike rotate <116.5651,108,0> }
object { spike rotate <116.5651,180,0> }
object { spike rotate <116.5651,252,0> }
object { spike rotate <116.5651,324,0> }
object { spike <----ERROR
spike.pov:61: error: Out of memory.  Cannot allocate 132 bytes for cone.
I'm currently running POV 3.1 on a linux machine with 48Mb RAM
 /____\  Manuel Moreno - Albacete - Spain
Date: 13 Sep 1999 18:17:06
Message: <37DD777C.B79A320A@pacbell.net>
>  fermosos latines:
  You don't have enough system memory to run this scene. If you can set up
swap file like windows has you might be able to continue. Otherwise you need
more ram on your system. I have 128 megs of physical ram and often have to
use my memory swap file for scenes like this.
Ken Tyler
See my 1000+ Povray and 3D Rendering and Raytracing Links at:
Date: 13 Sep 1999 19:21:32
Message: <37DD8694.28C861E2@pacbell.net>
> >  fermosos latines:
> Ken Tyler
I just rendered the scene. It has 120,000 objects and needs a total of 53 megs
of memory. You are out of memory !
Ken Tyler
Date: 14 Sep 1999 08:10:48
Message: <37de3b48@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: If you can set up swap file like windows has you might be able to continue.
  I didn't know that you can use linux without it using a swap file.
Date: 14 Sep 1999 08:40:38
Message: <37DE41D9.A8D4489B@pacbell.net>
I spoke out of ignorance. Forgive me.
Ken Tyler
Date: 14 Sep 1999 09:58:33
Message: <37de5489@news.povray.org>
Are you sure?  I'm pretty sure the OpenLinux 2.2 install lets you get away
with not specifying a swap partition.  Does it just go ahead and use a
file in that case?  What if I have more memory than HD (my current situation.)
Date: 14 Sep 1999 10:16:31
Message: <37de58bf@news.povray.org>
:>   I didn't know that you can use linux without it using a swap file.
: I spoke out of ignorance. Forgive me.
  Oh no, forgive me for the sarcastic comment. I'm sure that linux can be
used without swap files, but AFAIK it creates a swap partition by default.
Date: 14 Sep 1999 12:54:14
Message: <37DE7DBB.AF0ABD30@enst.fr>
	RedHat 5.1 works pretty well without a swap partition (and AFAIK it's
not possible to use a regular file for the swap...)
		Jerome
* they'll tell you what can't * mailto:ber### [at] inamecom
* be done and why...          * http://www.enst.fr/~jberger
* Then do it.                 *
Date: 14 Sep 1999 14:16:34
Message: <37DE920B.4D34B195@merlin.net.au>
>                 Jerome
> * Then do it.                 *
man mkswap ;-)
Cheers, PoD.
Date: 16 Sep 1999 18:24:01
Message: <slrn7u2pvd.cs.meneses@B52.net>
El Mon, 13 Sep 1999 15:15:24 -0700, Ken escrivio estos
 fermosos latines:
Thanks to all for your answers, I didn't imagine at a first sight
that such a small file could have so many objects.
Regarding to the linux swap matter, I've worked always without anyone
and this is the first time I find a problem with it. I use an old
slackware distribution (1995) and hope to fix this problem whith a new
hardrive and a more recent Debian.
