POV-Ray : Newsgroups : povray.text.scene-files : Re: Twysted source (bug fixed) Server Time
18 Apr 2026 02:08:46 EDT (-0400)
  Re: Twysted source (bug fixed) (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Twysted source (bug fixed)
Date: 14 Sep 1999 09:58:33
Message: <37de5489@news.povray.org>
On 14 Sep 1999 08:10:48 -0400, Nieminen Juha wrote:
>Ken <tyl### [at] pacbellnet> wrote:
>: If you can set up swap file like windows has you might be able to continue.
>  I didn't know that you can use linux without it using a swap file.
Are you sure?  I'm pretty sure the OpenLinux 2.2 install lets you get away
with not specifying a swap partition.  Does it just go ahead and use a
file in that case?  What if I have more memory than HD (my current situation.)
Date: 14 Sep 1999 10:16:31
Message: <37de58bf@news.povray.org>
:>   I didn't know that you can use linux without it using a swap file.
: I spoke out of ignorance. Forgive me.
  Oh no, forgive me for the sarcastic comment. I'm sure that linux can be
used without swap files, but AFAIK it creates a swap partition by default.
Date: 14 Sep 1999 12:54:14
Message: <37DE7DBB.AF0ABD30@enst.fr>
	RedHat 5.1 works pretty well without a swap partition (and AFAIK it's
not possible to use a regular file for the swap...)
		Jerome
* they'll tell you what can't * mailto:ber### [at] inamecom
* be done and why...          * http://www.enst.fr/~jberger
* Then do it.                 *
Date: 14 Sep 1999 14:16:34
Message: <37DE920B.4D34B195@merlin.net.au>
>                 Jerome
> * Then do it.                 *
man mkswap ;-)
Cheers, PoD.
Date: 16 Sep 1999 18:24:01
Message: <slrn7u2pvd.cs.meneses@B52.net>
El Mon, 13 Sep 1999 15:15:24 -0700, Ken escrivio estos
 fermosos latines:
>> I'm currently running POV 3.1 on a linux machine with 48Mb RAM
>>  /____\  Manuel Moreno - Albacete - Spain
>  You don't have enough system memory to run this scene. If you can set up
>swap file like windows has you might be able to continue. Otherwise you need
>more ram on your system. I have 128 megs of physical ram and often have to
>use my memory swap file for scenes like this.
Thanks to all for your answers, I didn't imagine at a first sight
that such a small file could have so many objects.
Regarding to the linux swap matter, I've worked always without anyone
and this is the first time I find a problem with it. I use an old
slackware distribution (1995) and hope to fix this problem whith a new
hardrive and a more recent Debian.
Date: 16 Sep 1999 18:27:56
Message: <37E16E7E.7CF9C013@pacbell.net>
Welcome to POV-Ray - the most memory eating program I have ever used.
She is a hungry beast :)
Ken Tyler
See my 1000+ Povray and 3D Rendering and Raytracing Links at:
Date: 17 Sep 1999 04:18:54
Message: <37e1f96e@news.povray.org>
: Welcome to POV-Ray - the most memory eating program I have ever used.
: She is a hungry beast :)
  The only reason a bought 64 Megs more RAM (so now I have 128 Megs) was
povray. No joking. I don't have any other program that starts swapping with
64 Megs of memory.
Date: 17 Sep 1999 21:19:29
Message: <37e2e8a1@news.povray.org>
Wow, good thing I pitched in a few more pennies for 128 megs. . .
Heh. I really like this scene!  Thanks, David!
-Ian
> I just rendered the scene. It has 120,000 objects and needs a total of 53
megs
> of memory. You are out of memory !
> Ken Tyler
Date: 17 Sep 1999 21:21:45
Message: <37e2e929@news.povray.org>
Ditto.  That's the only reason I went to 128 megs directly (instead of my
dad's suggestion to buy 64 now and 64 later).  Also, I'm hoping to reach 1
GB some day!  (my board supports it!  w00!)
-Ian
with
> 64 Megs of memory.
Date: 19 Sep 1999 18:08:31
Message: <D17lNxgbWqu1JhddPK1vF5wDt2xX@4ax.com>
>64 Megs of memory.
  Same here, Warp. Nothing, and I mean NOTHING, else on my machine uses as
much memory or puts my hardware through a workout as much as POV-Ray. Even
the most of the latest PC games will run with headroom to spare if I had
invested in a nicer 3d video card, but it isn't that important to me.
Alan ---------------------------------------------------------------
news.povray.org - where POV-Ray enthusiasts around the world can get
together to exchange ideas, information, and experiences with others
