POV-Ray : Newsgroups : povray.text.scene-files : Grid fade out with mask Server Time: 16 May 2008 07:12:07 GMT
  Grid fade out with mask (Message 1 to 1 of 1)
Subject: Grid fade out with mask
Date: 10 Jul 2006 12:53:48
Message: <pan.2006.07.10.12.46.42.773769@gmx.de>
Fade out of a grid with a semitransparent mask.
See the TRON Game Grid thread in p.newuser
Sebastian
#include "screen.inc"
#declare CLOCK = clock;
 *  Scene control settings
#declare ANIMATION = off;
#declare USE_PHOTONS = off;
#declare USE_RADIOSITY = off;
 *  Scene parameters
#declare G_W = 35;       // Width and depth for detailed ground
 *  Global settings
global_settings {
  charset utf8
  max_trace_level 16
  assumed_gamma 2.2
  #if (USE_RADIOSITY)
    radiosity {
      pretrace_start 0.08
      pretrace_end   0.04
      count 35
      nearest_count 5
      error_bound 1.8
      recursion_limit 1
      low_error_factor 0.5
      gray_threshold 0.0
      minimum_reuse 0.015
      brightness 1
      adc_bailout 0.01/2
  #if (USE_PHOTONS)
    photons {
      count 20000
      autostop 0
      jitter 0
background { rgb <1, 1, 1> }
 *  Camera
#declare cam_pos     = <-5, 4, -13>;
#declare cam_look_at = <1, 1.0, 0>;
#declare cam_angle   = 45;
#if(ANIMATION)
  #declare cam_pos     = vaxis_rotate(cam_pos,     <0,1,0>, CLOCK*360);
  #declare cam_look_at = vaxis_rotate(cam_look_at, <0,1,0>, CLOCK*360);
Set_Camera(cam_pos, cam_look_at, cam_angle) // set location, look_at and angle
Set_Camera_Aspect(16,9) // set width in relation to height
Set_Camera_Sky(<0,1,0>) // set the sky vector
 *  Static lightsources
light_source {
  <100, 200, -100> rgb <1, 1, 1>
  fade_distance 800
  fade_power 2
 * Objects
#declare O_Ground_Plane =
plane { y, 0 }
 * Textures
// Not used but intended for to be the
// center point of the fade-out mask
#declare ground_camera_focus =
trace(
  O_Ground_Plane,
  cam_pos,
  vnormalize(cam_look_at - cam_pos)
#declare grid_line_width     = 0.1;
#declare grid_line_col       = rgb  <0.95, 0.95, 1.00>;
#declare grid_area_col       = rgbt <0.00, 0.00, 0.10, 1.0>;
#declare grid_fade_disc_rad  = 40.0;
// #declare grid_fade_disc_pos  = ground_camera_focus;
   #declare grid_fade_disc_pos  = <cam_pos.x, 0, cam_pos.z>;
#declare P_Lines =
    gradient x
    color_map {
      [0.0             grid_line_col]
      [grid_line_width grid_line_col]
      [grid_line_width grid_area_col]
      [1.0             grid_area_col]
#declare T_Grid =
  texture { pigment {Black}   }
  texture { pigment {P_Lines} }
  texture { pigment {P_Lines rotate 90*y} }
#declare T_Actual_Grid =
  texture { T_Grid     finish {ambient 0.1}}
      cylindrical
      color_map {
        [0.0 rgb  grid_line_col]
        [1.0 rgbt 1.0]
      scale grid_fade_disc_rad
      translate grid_fade_disc_pos
 * Scene Object collection
sphere {
  0, 1/4
  pigment {Red}
object {
  O_Ground_Plane
    T_Actual_Grid
#declare w_dist = 50;
#declare O_Wall =
plane {
   -x, 0
   pigment {hexagon rgb 1.0, rgb 0.8, rgb 0.6 rotate 90*z}
   finish {ambient 0.45}
   translate w_dist*x
   no_shadow
object { O_Wall }
object { O_Wall rotate 90*y}
object { O_Wall rotate 180*y}
object { O_Wall rotate 270*y}
Copyright 1991-2004 POV-Team™
