POV-Ray : Newsgroups : povray.text.scene-files : isosurface bounding Server Time
14 Dec 2025 16:53:52 EST (-0500)
  isosurface bounding (Message 1 to 1 of 1)
Subject: isosurface bounding
Date: 27 Oct 2002 12:49:42
Message: <Xns92B4BF3FE20DFraf256com@204.213.191.226>
(explenation in general)
Init file for animation :
http://www.raf256.com/pov/iso_bound.ini.txt
mirror of this file :
http://www.raf256.com/pov/iso_bound.pov.txt
(if files will move, they will be somwhere on raf256.com/pov)
btw. am I posting messages here correctly, or should they be as .txt attachments ?
  Isosurface problem (bounding)
  2:4 ratio
  27.10.2002, last ver 0.01 27.10.2002 for 3.5win
  1 unit = 1 m (39.37 inch)
global_settings { assumed_gamma 2.0 max_trace_level 200 adc_bailout 1/64 }
  location <0,11,-10>*1.5 look_at  <0,1,1> angle 70
  up y   right x*2
light_source { <7,12,-10>*100 rgb 1 area_light x*10,y*10,5,5 orient circular adaptive
1 }
background { color rgb <.8,.8,1.0>*.3 }
plane { y,-20 pigment { checker rgb .8 rgb .9  scale 10 } }
// cointeiner size :
#local Clock = clock;
#local s = 2.0 + 4.0 * Clock;
#declare isos =
isosurface {
  function { x*x + y*y - 1 }
  contained_by { box { -s, +s } }
  accuracy 0.001
  max_gradient 4
  pigment { rgb <1,.2,.2> }
  finish { specular 1 roughness 0.03 reflection .5 }
object { isos translate -x*7 }
object { isos translate +x*7 }
// show cointainer :
union {
  #local a=s+0.001;
  #local r=0.08;
  box { -a, +a
    pigment { color rgbf <0.9,1.0,1.0, 0.8> }
    finish { specular 1 roughness 0.02 }
  cylinder { <-a,-a,-a> <+a,-a,-a> r } cylinder { <-a,-a,+a> <+a,-a,+a> r }
  cylinder { <-a,-a,-a> <-a,-a,+a> r } cylinder { <+a,-a,-a> <+a,-a,+a> r }
  cylinder { <-a,+a,-a> <+a,+a,-a> r } cylinder { <-a,+a,+a> <+a,+a,+a> r }
  cylinder { <-a,+a,-a> <-a,+a,+a> r } cylinder { <+a,+a,-a> <+a,+a,+a> r }
  cylinder { <-a,-a,-a> <-a,+a,-a> r } cylinder { <-a,-a,+a> <-a,+a,+a> r }
  cylinder { <+a,-a,-a> <+a,+a,-a> r } cylinder { <+a,-a,+a> <+a,+a,+a> r }
  sphere { <-a,-a,-a> r } sphere { <-a,-a,+a> r } sphere { <+a,-a,-a> r } sphere {
<+a,-a,+a> r }
  sphere { <-a,+a,-a> r } sphere { <-a,+a,+a> r } sphere { <+a,+a,-a> r } sphere {
<+a,+a,+a> r }
  pigment { color rgb <1,1,.2> }
  translate +x*7
//The counter :
text {
  ttf "timrom.ttf" concat("size=",str(s,3,3)) .1,0
  translate -x*2
  scale 5
  translate <0,1,7>
  pigment { rgb <.5,1.0,.5> }
  finish { ambient .3 }
  no_shadow
