POV-Ray : Newsgroups : povray.text.scene-files : Custom aquarium with overflow Server Time
14 Jul 2025 05:54:48 EDT (-0400)
  Custom aquarium with overflow (Message 1 to 1 of 1)
Subject: Custom aquarium with overflow
Date: 23 Jan 2002 19:38:28
Message: <Xns919FB375BDCD5spammindspringcom@204.213.191.226>
Here's the code for the aquarium I'd eventually like to have built for
me.  You can see a render of this in the images group, titled Dream Tank.
Any suggestions for speeding up the render, improving the textures, etc.,
will be greatly appreciated.
Rich Allen
(Remove SPAM from my address to reply by e-mail)
global_settings { max_trace_level 10 }
camera { location <-24,68,-96> right 1280/1024*x look_at <0,48,0> }
#declare MainLight  = <-5,72,-13>;
#declare BlueLight1 = < 1,72,-10>;
#declare BlueLight2 = <-7,72, -7>;
light_source { MainLight  color rgb <1, 1, 1.00> }
light_source { BlueLight1 color rgb <0, 0, 0.15> }
light_source { BlueLight2 color rgb <0, 0, 0.15> }
//TEXTURE DEFINITIONS
#declare glassTex = texture{
  pigment { rgbf <.99,.99,1.0,.99>}
  finish { reflection 0 }
#declare glassInt = interior{ ior 1.67 }
#declare waterTex = texture{
    pigment { color rgbf <0.9,0.9,1.0,0.995> }
    finish { reflection 0.2 }
#declare waterInt = interior { ior 1.33 caustics 1.5 }
#declare overflowTex = texture{
    pigment { color rgb 0 }
    finish { reflection 0.05 }
#declare sandTex = texture{
    granite
    color_map {
      [0.20 rgb 0.79]
      [0.23 rgb 0.00]
      [0.24 rgb 0.79]
      [0.50 rgb 0.70]
      [0.51 rgb 0.10]
      [0.53 rgb 0.70]
      [0.91 rgb 0.20]
      [0.91 rgb 0.70]
  finish { ambient .7 }
  scale <10,.1,10>
//OBJECT DEFINITIONS
#declare tank_solid = merge{
  intersection {
    cylinder { <0,0,0>, <0,28,0>, 28 }
    box { <0,0,0>, <-29,29,-29> }
  box { <-0.001,0,0>, <8,28,-28> }
#declare tank_inside = merge{
  intersection {
    cylinder { <0,0,0>, <0,28,0>, 27.5 }
  box { <-0.001,0,0>, <8,28,-27.5> }
  translate <-0.25,0.25,-0.25>
#declare tank = difference {
  object { tank_solid }
  object { tank_inside }
#declare overflow = intersection {
  difference {
    cylinder { <8,0,0>, <8,26,0>, 6 }
    cylinder { <8,0,0>, <8,28,0>, 5.75 }
  box { <0,0,0>, <8,26,-8> }
#declare sand = difference {
  intersection {
    height_field { function 200,200 { pattern { granite } } scale
<40,.75,40> translate <-30,3,-30> }
    object { tank_inside scale .999}
  cylinder { <8,0,0>, <8,6,0>, 6.001 }
#declare water = difference {
  intersection {
    height_field { function 200,200 { pattern { bozo scale .05 } } scale
<40,.75,40> translate <-30,26,-30> }
    object { tank_inside scale .9999 }
  cylinder { <8,0,0>, <8,29,0>, 6.001 }
//SCENE DEFINITION
sky_sphere { pigment { color rgb .6 } }
//tank
object { tank texture { glassTex } interior { glassInt } translate <-
0.5,36,-0.5> }
object { water texture { waterTex } interior { waterInt } translate <-
0.5,36,-0.5> }
object { overflow  texture { overflowTex } translate <-0.5,36,-0.5> }
object { sand texture { sandTex } translate <-0.5,36,-0.5> }
