POV-Ray : Newsgroups : povray.text.scene-files : Rainbow lightbeam? Server Time
16 Apr 2026 10:04:35 EDT (-0400)
  Rainbow lightbeam? (Message 1 to 5 of 5)
Subject: Rainbow lightbeam?
Date: 18 Sep 2001 22:47:37
Message: <Xns9120E7AF3E32Bgarycramblittknilhtr@204.213.191.226>
Can someone post some code to produce a conical light beam in rainbow
colors.  A beam one might see coming from a prism, for example,  Note: not a
light source; a beam using scattering or emitting media.  For Win PovRay
3.1a.  Thanks.
Subject: Re: Rainbow lightbeam? Yes
Date: 19 Sep 2001 03:44:45
Message: <3ba84ced@news.povray.org>
 Here's a quick try at it.  If you use a cone instead of the box the thin
edges won't look right, I can tell you that without even having tried it in
this.  At least not without first narrowing its thickness.  In fact this one
doesn't look very spectrum like when oriented away from the camera.
 This should be okay for POV-Ray 3.1
 You'll need to work out the layout from what's in the comments and object
transformations in order to use it in other ways of your own.
// example of faked light spectrum from a prism
#declare Scale=5; // overall size
#declare Illum=2; // brightness
// prism paired with spectrum
union {
// prism
intersection {
        plane {x,.1}
        plane {x,.1 rotate 120*y}
        plane {x,.1 rotate 240*y}
        plane {-y,0}
        plane {+y,1}
 pigment {rgbf <0.8,1,0.9,1>}
 interior {ior 1.5}
   rotate -45*y scale <0.75,1,0.5> translate <-0.025,0,-0.025>
// media spectrum
box {0,1 hollow
        pigment {rgbt 1}
        interior {
                media {
                        emission 1
                       density { radial frequency 4
                         density_map {
                                [0 rgb <0,0,0>]
                                [0.1 rgb <1,0,0>*Illum/Scale]
                                [0.3 rgb <1,0.5,0>*Illum/Scale]
                                [0.4 rgb <1,1,0>*Illum/Scale]
                                [0.7 rgb <0,1,0>*Illum/Scale]
                                [0.85 rgb <0,1,1>*Illum/Scale]
                                [0.9 rgb <0,0,1>*Illum/Scale]
                                [1 rgb <0,0,0>]
                media {
                        absorption 1
                         density_map {
                                [0 rgb <0,0,0>] // adjust colors to liking
                                [1 rgb <0,0,0>]
 rotate 45*y scale <2,1,1>*Scale
  rotate -42*x // -45 to align with camera as is (perpendicular)
// end spectrum
light_source {
        0,0.5
        location <0,0,-10>
        look_at <2,0.5,0.5>
        angle 30
        rotate 42*x // +45 to be opposite the wedges upper face when as
above
// room
box {-15,15
        pigment {rgb 0.9}
        finish {ambient 0.1}
 inverse
Date: 19 Sep 2001 07:36:59
Message: <3ba8835b@news.povray.org>
hey thats cool!
I'm still amazed at the thing people can make this program do.
Gary
Bob H. <omn### [at] msncom> wrote in message
news:3ba84ced@news.povray.org...
in
one
> union {
> // prism
> intersection {
>         plane {x,.1}
>         plane {-y,0}
>         plane {+y,1}
>  interior {ior 1.5}
> // media spectrum
> box {0,1 hollow
>         pigment {rgbt 1}
>         interior {
>                 media {
>                         emission 1
>                          density_map {
>                                 [0 rgb <0,0,0>]
>                                 [1 rgb <0,0,0>]
>                 media {
>                         absorption 1
>                          density_map {
>                                 [1 rgb <0,0,0>]
> // end spectrum
> light_source {
>         0,0.5
> camera {
>         location <0,0,-10>
>         look_at <2,0.5,0.5>
>         angle 30
> above
> // room
> box {-15,15
>         pigment {rgb 0.9}
>  inverse
Date: 19 Sep 2001 21:02:19
Message: <Xns9121D5D29C23Fgarycramblittknilhtr@204.213.191.226>
Right on Bob! Just what I needed.  Thanks.
"Bob H." <omn### [at] msncom> wrote in news:3ba84ced@news.povray.org:
Date: 20 Sep 2001 02:56:42
Message: <3ba9932a@news.povray.org>
Welcome to it.  If I didn't have the help of everyone else myself it
wouldn't be as possible  :-)
Bob H.
"Gary Cramblitt" <NOS### [at] Homecom> wrote in message
