POV-Ray : Newsgroups : povray.text.scene-files : Re: Draping cloth request Server Time
1 Feb 2026 16:49:20 EST (-0500)
  Re: Draping cloth request (Message 1 to 2 of 2)
Subject: Re: Draping cloth request
Date: 28 Mar 2002 13:01:31
Message: <UF8COCAbouo8Ewra@econym.demon.co.uk>
Wasn't it Patrick Dugan who wrote:
>I'm sorry the the picture didn't come through.  Your example though looks
>like the same idea.  Can you post any source showing how to do this or
>is there a tutorial somewhere?  Thanks!
Source as requested, but you'll have to find your own figure to drape it
round.
    location <0,.5,-0.8 >
    look_at <0,0.34,0>
light_source { <-0.2 , 1 ,-3 > rgb 1.2}
light_source { <0.2 , 2 ,-1 > rgb 1}
background {rgb<0.5,0.5,0.7>}
// Insert your Poser model here
// The one I used (P3 nude female) was 0.695 units tall,
//     had a neck line at y=0.56
//     had just its hands outside a cylinder of radius 0.16
#declare Body = union {#include "Poser3.inc"}
object {Body}
// Can use other shapes as Base if you want the skirt to flare out
#declare Base = plane {y,-0.1 pigment {rgb 0}}
plane {y,0 pigment {rgb <.3,.6,.3>}}
#declare Umax=100; // Number of points to generate
#declare Vmax=100;
#declare Points = array [Umax+1][Vmax+1];
#declare Norms  = array [Umax+1][Vmax+1];
#declare Norm=<0,0,0>;
#declare FNorm=<0,0,0>;
//Fudge factors. Becuase we're sampling at a finite number
// of points, if we try to fit the cloth *exactly* to the body,
// then there will be some places where the body will poke out
#declare M=0.003;
#declare MM=0.003;
#declare U=0;
#while (U<=Umax)
  #declare OT=<0,0.58,0>;
  #declare A=2*pi*U/Umax;
  #declare V=0;
  #while (V<=Vmax)
    #declare R=0.16*V/Vmax;
    #declare P=<R*cos(A), 0.58, R*sin(A)>;
    #declare T=trace(Body, P, -y, Norm);
    #declare F=trace(Base,P, -y, FNorm);
    // If we missed or are below the base, use Base instead of Body
    #if (vlength(Norm)=0 | T.y<F.y)
      #declare T=F;
      #declare Norm=FNorm;
    //Store the result in an array
    #declare Points[U][V] = T+Norm*M-z*MM;
    #declare Norms[U][V] = Norm;
    #declare OT=T;
    #declare V=V+1;
  #declare U=U+1;
#declare N=0;
#declare Robe = intersection {
  // intersecting with cylinder to create the hemline
  cylinder {<0,0.15,0><0,1,0>,1}
  // the stored Points become a mesh2 object
  mesh2 {
  vertex_vectors {  (Umax+1)*(Vmax),
    #declare U=0;#while (U<=Umax) #declare V=0;#while (V<=Vmax-1)
      Points[U][V],
      #declare q=Points[U][V];
      #declare N=N+1;
    #declare V=V+1;#end #declare U=U+1;#end
  normal_vectors {   (Umax+1)*(Vmax),
      Norms[U][V],
      #declare N=N+1;
  // omit the central region to create a neckline
  #declare Start=floor(12/50*Vmax);
  face_indices {
   (Umax)*(Vmax-1-Start)*2,
    #declare U=0;#while (U<Umax) #declare V=Start;#while (V<Vmax-1)
      #declare p=U*(Vmax)+V;
      <p,p+1,p+Vmax>, <p+1,p+Vmax,p+Vmax+1>,
  //pigment {rgbt <1,1,1,0.3>} // see-through version
  pigment {rgbt <1,1,1,0>}
object {Robe}
Mike Williams
Gentleman of Leisure
Date: 28 Mar 2002 14:49:23
Message: <3ca373c3$1@news.povray.org>
Thank you!
"Mike Williams" <mik### [at] nospamplease> wrote in message
news:UF8### [at] econymdemoncouk...
> round.
> camera {
>     look_at <0,0.34,0>
> object {Body}
> #declare Vmax=100;
> #declare M=0.003;
> #declare MM=0.003;
> #declare U=0;
> #while (U<=Umax)
>   #declare V=0;
>   #while (V<=Vmax)
>       #declare T=F;
>     #end
>     #declare OT=T;
>     #declare V=V+1;
>   #end
>   #declare U=U+1;
> #end
> #declare N=0;
>   mesh2 {
>       Points[U][V],
>       #declare N=N+1;
>       Norms[U][V],
>       #declare N=N+1;
>   face_indices {
> object {Robe}
> Mike Williams
