![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wasn't it Patrick Dugan who wrote:
>I'm sorry the the picture didn't come through. Your example though looks
>like the same idea. Can you post any source showing how to do this or
>is there a tutorial somewhere? Thanks!
Source as requested, but you'll have to find your own figure to drape it
round.
location <0,.5,-0.8 >
look_at <0,0.34,0>
light_source { <-0.2 , 1 ,-3 > rgb 1.2}
light_source { <0.2 , 2 ,-1 > rgb 1}
background {rgb<0.5,0.5,0.7>}
// Insert your Poser model here
// The one I used (P3 nude female) was 0.695 units tall,
// had a neck line at y=0.56
// had just its hands outside a cylinder of radius 0.16
#declare Body = union {#include "Poser3.inc"}
object {Body}
// Can use other shapes as Base if you want the skirt to flare out
#declare Base = plane {y,-0.1 pigment {rgb 0}}
plane {y,0 pigment {rgb <.3,.6,.3>}}
#declare Umax=100; // Number of points to generate
#declare Vmax=100;
#declare Points = array [Umax+1][Vmax+1];
#declare Norms = array [Umax+1][Vmax+1];
#declare Norm=<0,0,0>;
#declare FNorm=<0,0,0>;
//Fudge factors. Becuase we're sampling at a finite number
// of points, if we try to fit the cloth *exactly* to the body,
// then there will be some places where the body will poke out
#declare M=0.003;
#declare MM=0.003;
#declare U=0;
#while (U<=Umax)
#declare OT=<0,0.58,0>;
#declare A=2*pi*U/Umax;
#declare V=0;
#while (V<=Vmax)
#declare R=0.16*V/Vmax;
#declare P=<R*cos(A), 0.58, R*sin(A)>;
#declare T=trace(Body, P, -y, Norm);
#declare F=trace(Base,P, -y, FNorm);
// If we missed or are below the base, use Base instead of Body
#if (vlength(Norm)=0 | T.y<F.y)
#declare T=F;
#declare Norm=FNorm;
//Store the result in an array
#declare Points[U][V] = T+Norm*M-z*MM;
#declare Norms[U][V] = Norm;
#declare OT=T;
#declare V=V+1;
#declare U=U+1;
#declare N=0;
#declare Robe = intersection {
// intersecting with cylinder to create the hemline
cylinder {<0,0.15,0><0,1,0>,1}
// the stored Points become a mesh2 object
mesh2 {
vertex_vectors { (Umax+1)*(Vmax),
#declare U=0;#while (U<=Umax) #declare V=0;#while (V<=Vmax-1)
Points[U][V],
#declare q=Points[U][V];
#declare N=N+1;
#declare V=V+1;#end #declare U=U+1;#end
normal_vectors { (Umax+1)*(Vmax),
Norms[U][V],
#declare N=N+1;
// omit the central region to create a neckline
#declare Start=floor(12/50*Vmax);
face_indices {
(Umax)*(Vmax-1-Start)*2,
#declare U=0;#while (U<Umax) #declare V=Start;#while (V<Vmax-1)
#declare p=U*(Vmax)+V;
<p,p+1,p+Vmax>, <p+1,p+Vmax,p+Vmax+1>,
//pigment {rgbt <1,1,1,0.3>} // see-through version
pigment {rgbt <1,1,1,0>}
object {Robe}
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thank you!
"Mike Williams" <mik### [at] nospam please> wrote in message
news:UF8### [at] econym demon co uk...
> round.
> camera {
> look_at <0,0.34,0>
> object {Body}
> #declare Vmax=100;
> #declare M=0.003;
> #declare MM=0.003;
> #declare U=0;
> #while (U<=Umax)
> #declare V=0;
> #while (V<=Vmax)
> #declare T=F;
> #end
> #declare OT=T;
> #declare V=V+1;
> #end
> #declare U=U+1;
> #end
> #declare N=0;
> mesh2 {
> Points[U][V],
> #declare N=N+1;
> Norms[U][V],
> #declare N=N+1;
> face_indices {
> object {Robe}
> Mike Williams
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
