![](/i/fill.gif) |
See "'Artistic' Starfield" in povray.binaries.images.
This code produces an image that's identical to the last image that I
posted, but I've removed an inefficiency that I discovered when I was
making the code more presentable, and it renders twice as fast.
// Clumpy Star field
// Author: Mike Williams
// Date: 1-Jun-2005
// The basic trick is that the stars are scattered randomly
// across the field of view, but some of them are obscured by
// dark nebulae which leave small clumps of stars and gas cloud
// visible through the holes.
// This sort of thing sometimes happens with real star patterns.
#version 3.6;
global_settings {assumed_gamma 1.0}
camera {location <0,0,-10> look_at <0,0,0> angle 50}
// no light_source necessary
#declare Ang=30; // Adjust if the camera angle changes
#declare RR=seed(1234); // Gives different star patterns
#declare NebulaRot = <-15,7,0>; // Gives different nebula patterns
// The colour of the gas clouds
sky_sphere {
bozo
colour_map {
[ 0.1 rgb <0.05,0.05,0.2>]
[ 0.9 rgb <0.2,0.05,0.05>]
warp {turbulence 1}
scale 0.3
rotate NebulaRot
// A layer of 5000 spherical stars at distance 104
#declare N=0;
union {
#while (N<5000)
sphere {104*z, 0.2*rand(RR)
rotate <Ang*2*rand(RR)-Ang,Ang*2*rand(RR)-Ang,0>}
#declare N=N+1;
pigment {rgb 1.5}
finish {ambient 1}
// A dark nebula that obscures the spherical stars
sphere {0,102
leopard
colour_map {
[0.1 rgbt <0,0,0,0.0>]
[0.4 rgbt <0,0,0.0,1.0>]
warp {turbulence 0.8 omega 0.7}
scale 15
rotate NebulaRot
finish {ambient 1}
// A layer of smaller spherical stars at distance 100
#declare N=0;
union {
#while (N<50000)
sphere {100*z, 0.05*rand(RR)
#declare N=N+1;
pigment {rgb 1.5}
finish {ambient 1}
// A dark nebula that lets some light through the dark bits
// The pattern is the same as the first nebula, but it lets more
// light shine through, so we get just the small stars
// in the dark parts
sphere {0,98 pigment {
leopard
colour_map {
[0.1 rgbt <0,0,0,0.15>]
[0.4 rgbt <0,0,0,1.0>]
scale 15
rotate NebulaRot
finish {ambient 1}
![](/i/fill.gif) |
